would be more easy to use a cortina diff than a LX diff in a UC
Its a borgwarner 78 series modified for lx. I need the ratio for the rest of the conversion to work.
Posted 02 June 2017 - 06:19 PM
Posted 02 June 2017 - 06:55 PM
cortina diffs are 78s as well and closer top arm mounts to a UC than a LX
Posted 02 June 2017 - 08:11 PM
Posted 03 June 2017 - 12:03 PM
Posted 03 June 2017 - 11:57 PM
Posted 21 October 2018 - 09:27 PM
uc lower diff mount are not the same as lh,lx. on uc and a9x the hole in the bottom floor mount is 20mm back lower diff mount is more like hz if you use the wrong mounts your wheel is 20mm out if you have big wheels like 295/50/15 they will hard up on the body
