LX Tacho Gradually reads higher and higher
13 replies to this topic
#1 CI 0308
CI 0308
  • 736 posts
  • Car:77 LX SS, VX SS
Posted 01 June 2017 - 05:59 PM
This has been asked before but there was never an answer given. My Original LX SS Tacho starts off reading ok but after about half an hour starts to read higher and higher until it sits around 6000rpm at idle. park it up over night start up the next day all is fine for half an hour of driving then the same thing happens.
I have replaced the voltage regulator with the Jaycar DC to DC regulator and set at 5 volts, soldered a wire bridge across where the selector switch usually goes. checked all wiring and all other gauges read fine. no the needle hasnt been painted etc. checked wiring through to negative side of standard style coil. runs an old school SBC with standard distributor.
anyone have any ideas as there isn't much more I can think of.
cheers Brett
Edited by CI 0308, 01 June 2017 - 06:00 PM.
#2 VDO
VDO
  • 187 posts
  • Name:Chris Curtis
Posted 02 June 2017 - 07:48 AM
Circuit board is dying.  The components are changing values as the circuit warms.  Usually the resistors are fattening (increasing value) and the capacitors.
#3 CI 0308
CI 0308
  • 736 posts
Posted 02 June 2017 - 08:06 AM
Thanks VDO. I'll pull it out and check it. Hopefully I can change out the components with a bit of luck. Or is there a better way.
Sent from my Redmi Note 4 using Tapatalk
#4 VDO
VDO
  • 187 posts
  • Name:Chris Curtis
Posted 02 June 2017 - 09:55 AM
Replacement circuit boards can be bought.  Or the internals can be replaced with the same from another particular vehicle.
#5 deauville
deauville
  • 12 posts
Posted 16 September 2021 - 07:55 AM
 Dads  original untouched Feb75 built LH SLR/5000 did this  exact thing  "Gradually the tacho would read 1000rpm high then idle would be at 3500 then finally at idle 6000rpm showing and at the same time the neddle would be "EXTRA BOUNCY" .   It was a build up of HEAT that seemed to affect the tachos movement.
We put a coduit black plastic tube around the tan tacho wire near where it ran past  the wiper motor.This really didn't help much.
Often wondered why ,No one ever explained it to me.
#6 VDO
VDO
  • 187 posts
  • Name:Chris Curtis
Posted 16 September 2021 - 08:28 AM
You can try re-working the solder joints on the tacho circuit board, but it probably won't make much difference in this case.  The most common culprit is the choke (on the circuit board) which often becomes intermittent due to flimsy wiring and eventually just falls off the board.  It looks like a small puck.
#7 Rockoz
Rockoz
  • 4,008 posts
  • Name:Rob
Posted 16 September 2021 - 02:57 PM
I went through about 4 tachos about 10 years ago.
The choke had fallen off on all of them.
I did find a replacement choke from I think VDO in Western Australia.
But to be honest I reckon a replacement circuit board would be better than trying to fix the old one.
I think you do this dont you Chris?
I know there was someone doing it anyway.
Rob
#8 VDO
VDO
  • 187 posts
  • Name:Chris Curtis
Posted 16 September 2021 - 03:02 PM
Rob
Hi Rob.
Yes I do.  In my opinion, it's best to replace the circuit board.
I'm in QLD.
#9 Stevo75
Stevo75
  • 70 posts
  • Name:Steve
  • Car:LH Torana, HSV R8
Posted 16 January 2022 - 01:57 PM
Hi Rob.
I'm in QLD.
Hi VDO
I’m just fixing up my dash cluster and found the same issue you talk about with the tachometer choke fallen off.
I’ve attached a couple of photos below. I assume it’s the black circular piece at the bottom of the first photo.
Do you know where I can source a new circuit board from. I’m over in NZ, but guessing I’d need to get something posted from Aus.
Also, is there a way I can test the gauge cluster off the car. Keen to see what is working and what isn’t if possible.
TIA
Steve
#10 VDO
VDO
  • 187 posts
  • Name:Chris Curtis
Posted 16 January 2022 - 03:24 PM
Hi VDO
TIA
Steve
Steve, you'll need an array of equipment to test the cluster.  A range of resistors, Waveform generator and a bench speedo drive and the experience to us them.  Not trying to sound like a smart arse, but that's the truth mostly.  If your tacho stopped working because the ridiculous ferrite choke fell off the board, just go to where the choke was connected and bridge solder those two points together and the tacho should work again.  The choke isn't needed for the tachos operation, it's only there to reduce line interference, but there isn't that much interference around that would mess up the tacho operation.  If anyone here needs a replacement tacho board specific to the Torana, let me know and I can order through my supplier.  The supplier won't sell to public, only to approved instrument techs, or I would direct you to them.  The part number is TC1020.
Edited by VDO, 16 January 2022 - 03:25 PM.
#11 Stevo75
Stevo75
  • 70 posts
  • Name:Steve
Posted 16 January 2022 - 04:49 PM
Thanks VDO
I’ll try bridging the wires where the choke was. Sounds like a plan. Those wires on the choke itself are ridiculously tiny aye.
How much are the new tacho circuit boards out of interest?
Steve
#12 VDO
VDO
  • 187 posts
  • Name:Chris Curtis
Posted 16 January 2022 - 05:53 PM
Thanks VDO
Steve
I'll call them tomorrow and get the current price, I can't remember it off the top of my head.  Maybe around $130.
#13 Stevo75
Stevo75
  • 70 posts
  • Name:Steve
Posted 16 January 2022 - 06:33 PM
Thanks again VDO
$130, that’s not too bad. Another quick question for you. I came across a couple sites mentioning that it’s best to replace the voltage regulator at the back of the gauge cluster with a new style aftermarket one. What is your experience with that.
Steve
#14 antelopeslr5000
antelopeslr5000
  • 1,022 posts
  • Car:1977 LX SL/R 5000
Posted 16 January 2022 - 06:50 PM
Thanks again VDO
Steve
It can't hurt while the cluster is out. The old voltage regulator is a bimetallic type and can lose accuracy over time, affecting the accuracy of the quad gauges. A solid state voltage regulator will be more stable.
