L34 - HO - carby etc
14 replies to this topic
#1 RallyRed
  • 8,150 posts
Posted 26 June 2017 - 07:37 AM
Hi,
I recieved this request the other day...can anyone help.  Ta.    ( p.s. ""members"" means HVTC members)
Hi....Long shot...but here goes.....Would any of your members have or know off any pictures of the Carby used on the HO option Torana..I believe it was a 780 Vac sec Holley....(same as GTHO)...wondering if it was set up the same eg. Balance tube running down drivers side ,front to rear bowl...and 1 fuel inlet on passenger side...
#2 myss427
myss427
  • 1,636 posts
Posted 26 June 2017 - 09:49 AM
Yes, was a 780, Ford one looked like a 780 but was slightly different, smaller. Different part number, very valuable now!
#3 Shiney005
  • 9,603 posts
  • Car:Toyota Mirai
Posted 27 June 2017 - 09:14 AM
Different part number for sure. The one on ebay at the moment is Ford. I will put up some pics when I get home on Wednesday.
#4 RallyRed
  • 8,150 posts
Posted 27 June 2017 - 08:59 PM
Thanks Laurie.
#5 Shiney005
  • 9,603 posts
  • Car:Toyota Mirai
Posted 30 June 2017 - 08:28 PM
The carbys that came with the HO kit were a bit like the camshafts. It seems that they could either be changed by customer order, or the factory changed suppliers as they went. Unclefesta knows of brand new L34s with 650 spreadbores, and I know personally of one fitted with the DOZF 780 as fitted to the Fords with the Ford part number, and one fitted with the universal 780 as fitted new to some Chevs.
As far as the 780s go, they should have the down leg boosters and the older rounded fuel bowls.
The following photos are the DOZF 9510-Z as used on the HO Falcons.
Attached File  780 boss 302 1.PNG   876.22K   11 downloads
Attached File  780 boss 302 2.JPG   84.97K   6 downloads
Attached File  780 boss 302 phase4 3.JPG   66.34K   9 downloads
Attached File  780 boss 302 phase4 4.JPG   61.65K   9 downloads
Attached File  780 boss 302 phase4 5.JPG   55.96K   5 downloads
Attached File  780 boss 302 phase4 6.JPG   55.39K   5 downloads
And the Chev version.
Attached File  780 L34 (3).jpg   131.53K   12 downloads
Attached File  780 L34 (4).jpg   173.33K   17 downloads
Attached File  780 L34 (5).jpg   186.36K   15 downloads
Attached File  780 L34 (6).jpg   110.96K   12 downloads
Attached File  780 L34 (7).jpg   174.28K   13 downloads
There is also the auto choke version. DOZF 9510-U  The photo below claims it is factory fitment from a 396 Chevelle so the L34 wasn't the first GM product to carry a carby with a Ford part number. (The vacuum port is another giveaway that it was fitted to a Chev.)
#6 Shiney005
  • 9,603 posts
  • Car:Toyota Mirai
Posted 30 June 2017 - 08:36 PM
Attached File  780 universal5.jpg   40.97K   8 downloads
The Ford version has a three digit date code of Week / Month / Year and the Chev / Universal is a four digit code with the first three numbers being the day of the year, and the last number is the year.
Exploded view from L34 parts supplement.
Attached File  L34 Carby.jpg   98K   14 downloads
Attached File  780 L34.jpg   28.97K   21 downloads
I should also mention that I am not an expert. I think the experts have all left the building.
#7 Shiney005
  • 9,603 posts
  • Car:Toyota Mirai
Posted 30 June 2017 - 09:17 PM
Almost forgot. The HO option also included the spacer for the square bore 780 to fit the Holden spreadbore manifold.
Attached File  Carby spacer.jpg   167.25K   22 downloads
#8 RallyRed
  • 8,150 posts
Posted 30 June 2017 - 09:48 PM
Great work Laurie..appreciate the effort mate,  ...looks like a bit of a mixed bag there?
Regards
Col
Edited by RallyRed, 30 June 2017 - 09:54 PM.
#9 Shiney005
  • 9,603 posts
  • Car:Toyota Mirai
Posted 01 July 2017 - 10:17 AM
This is the factory SL/R mule used for developing the L34. You can clearly see it is a manual choke vacuum secondary square bore.
This also shows the air horn used as the standard aircleaner wouldn't clear the float adjusting screws on the fuel bowls. (Mine has had two small holes cut into the aircleaner body and patches welded in.)
Attached File  L34 mule (3).jpg   431.96K   28 downloads
Attached File  L34 mule (6).jpg   357.62K   12 downloads
This picture may predate the L34. It is a bit hard to see in this scan, but when you look at the original poster you can see this carby is a vacuum squarebore, but the fuel feed is only on one side.
Attached File  350_Z_S.jpg   492.95K   10 downloads
This near new L34 race car has the fuel feed on the opposite side. It has the same oil cooler as mine so I assume it has the GMH HO kit.
Attached File  post-6990-0-07295300-1405130006.jpg   99.67K   17 downloads
Edited by Shiney005, 01 July 2017 - 10:20 AM.
#10 _malprac69_
_malprac69_
Posted 01 July 2017 - 10:36 AM
and the carb is back to front.....Secondaries facing front?
#11 Shiney005
  • 9,603 posts
  • Car:Toyota Mirai
Posted 04 July 2017 - 01:30 PM
Ha! Well bugger me. I can't believe I didn't notice. Why would you do that?
#12 Shiney005
  • 9,603 posts
  • Car:Toyota Mirai
Posted 04 July 2017 - 01:35 PM
This is the same car with the Carby the right way round. This 780 is still sporting its standard duel feed line on the right hand side. I can't for the life of me remember whos car this was. I think I got the pics from the forum somewhere.
Attached File  post-6990-0-57429000-1405129973.jpg   90.96K   13 downloads
#13 _malprac69_
_malprac69_
Posted 23 October 2017 - 05:55 PM
Hey Guy's   Carby all finished....any body interested in buying it....customer never came to pick it up....3310-2 (750) converted to 4150(rear metering block) Old school Holley front bowl , drilled and tapped to be dual feed....running stock jets (72 Pri + 75 Sec)....65 PV.....fully tested.....
Edited by malprac69, 23 October 2017 - 06:00 PM.
#14 Shiney005
  • 9,603 posts
  • Car:Toyota Mirai
Posted 23 October 2017 - 10:18 PM
Wait.
#15 Shiney005
  • 9,603 posts
  • Car:Toyota Mirai
Posted 24 October 2017 - 12:42 AM
False alarm. He has got hold of one.
