Steering Arms
Steering Arm UC HX
5 replies to this topic
#1 _HDT05_
_HDT05_
Posted 31 July 2017 - 05:55 PM
Just picked up this UC front for my LH project and it looks like it's had some work done to it a long time ago.
HX Girlock Calipers, HQ-HZ Stub axles, HQ Steering arms and 5 Stud on 4.25" PCD Ventilated Disc Rotors.
Anyone know if this combination actually works?
Thanks in advance
Regards Peter
Edited by HDT05, 31 July 2017 - 11:35 PM.
#2 76lxhatch
  • 7,207 posts
Posted 31 July 2017 - 06:28 PM
I tried some HQ steering arms when I was measuring bump steer. I didn't bother plotting them against the other arms since the numbers were so far out.
Unless something has been altered quite significantly it would be a bit dangerous. Maybe they just put them on there to make it easier to roll around?
#3 TerrA LX
Posted 31 July 2017 - 07:31 PM
There are two? different steering arms for the big brother, a long and a short?
P/S and non P/S?
#4 _HDT05_
_HDT05_
Posted 31 July 2017 - 11:32 PM
OK. That's really the answer I wanted/needed. If bump steer is an issue with these arms. It's a no brainer. They are extremely long as well and really doesn't make the rack look right. They have been on the car for a long time as I had to steam clean for an hour to get all the crap off it! Iv'e posted a plan view that shows the length of these arms!
Thank You
#5 76lxhatch
  • 7,207 posts
Posted 01 August 2017 - 05:30 AM
P/S and non P/S?
Yes for HJ-HZ (HQ got the short version for manual steer also). The short is ~90mm from tie rod end to front bolt and the long is ~120mm if I remember correctly, these look like the long ones from the overhead shot (which also push the tie rod end inboard a bit for wheel clearance). The long ones slow the steering ratio somewhat too, in this case you may possibly even have reduced lock/turning capacity.
The biggest issue for bump steer is the height of the tie rod end, they are dropped too low. Have seen/heard of tricks with bending the arms and using fancy brackets at the mounting bolts to alter the angle but its hardly worth the hassle if you're building a standard Torana front end.
#6 _HDT05_
_HDT05_
Posted 01 August 2017 - 07:00 AM
OK. From your description it sounds like the LONG steering arms are fitted here. I'll do a measure and confirm that.
I wont be screwing around with these arm. Much easier to simply replace with the right steering arms and fix the issue. I'll grab a set of the HARROP A9X aftermarket arms
Many thanks for your help
Also tagged with one or more of these keywords: Steering Arm, UC, HX
