LC Torana 2 Door
199 replies to this topic
#51 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 04 November 2017 - 09:48 AM
What do you guys usually do with the wiring?
I'm thinking I'll pull it all out but keep it, especially the connectors etc, so it can be re-wired in the future.
Just want to get it out of the way so I can start cleaning up the engine bay etc
Edited by Gatti, 04 November 2017 - 09:49 AM.
#52 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 20 November 2017 - 01:37 PM
I also picked up some headlight surrounds.
I'll end up getting the grille and surrounds restored but put them on the car jus to have a look at it.
#53 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 10 February 2018 - 04:36 PM
Started to sand it back today and below are the results.
As mentioned this is my first rebuild so forgive the questions.
Is the cream colour body filler?
It’s only a very thin layer. I have heard of people ‘skimming’ a panel so it can be sanded smooth.
Is this normal or is it a sign of things to come and I have a lot of work ahead??
Edited by Gatti, 10 February 2018 - 05:39 PM.
#54 _Caustic_
_Caustic_
Posted 11 February 2018 - 09:17 AM
Keep at it mate,love the flares.
#55 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 12 February 2018 - 08:39 AM
I also cut the floorpan out the other week.
Just need to work on my welding skills before I fit the new pan.
#56 _markstone_
_markstone_
Posted 25 February 2018 - 11:30 PM
4qlKvz4.jpgi hope you have new floor pan in hand and havent cut it back to far
#57 purrlx
purrlx
  • 1,332 posts
  • Name:Danny
  • Car:LX hatch
Posted 26 February 2018 - 12:51 AM
In my opinion if you are sanding it back that far to expose bog skim. I would go back to bare metal as a start then you know exactly what you have.
#58 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 27 February 2018 - 01:18 PM
The black texter marking is the outside edge of the replacement pan.
I had to cut a fair bit out as it was pretty rusted.
Yeah I think I'll go all the way around the car to nearly bare metal to have a look first and then go around again right back to metal and re-primer as I go.
#59 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 04 March 2018 - 07:27 PM
Did some more stripping today. So far it's looking pretty good with no big filler sections or bad rust. The lower sections of the panels seem pretty good so far as well.
#60 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 26 March 2018 - 08:50 AM
Got some more done over the weekend 542ed2be721cf2e0aab5d21561c5e9f4.jpgfbc7afcc4675f0d5a38887dcdb979e71.jpg
#61 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 23 April 2018 - 10:29 PM
I decided to make life a bit easier for myself so bought a rotisserie for the car for easy access.
Just need to remove the front end and diff and work out the best way to mount the shell.
I've started another thread in 'General Discussion' about how I should mount it.
#62 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 25 April 2018 - 08:36 PM
Had my first big try of welding today and make a bracket for the front of the car to mount it onto the rotisserie.
I used square tube to go inside the frame of the car and it will be bolted to the inside of the brackets for the rotisserie.
It then bolts into the holes for the bonnet latch
It turned out pretty well and I'm happy with it for a first attempt.
#63 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 25 April 2018 - 09:34 PM
I hate to tell you, but with the amount of paint thickness on the vehicle as posted on your YouTube, you really don't have an option bar bare metal, or you'll most certainly have issues for sure. Right at the start i gave you a guide to run with, if you stick with that, you won't have an issue. Yes, you can definitely do 1 or 2 panels at a time & use a good quality epoxy etch primer. I'd focus on having the whole shell & swinging panels in epoxy first & do all the repairs before high build, re epoxy over all your repairs as you finish them. Good luck
#64 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 25 April 2018 - 10:18 PM
I see where your coming from Gaz.i think Gatti wants
to do a qik fix and get it on the road and get back to
the body in 5+ yrs time?..its going to cost quite abit
all the gear hes going to need if he goes back to metal. And specially if you havent any gear to start with.
It will amount to thousands..
Maybe it should b asked ..do you want a qik fix or in it
for the long haul..
#65 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 25 April 2018 - 10:21 PM
Hmm cant edit Wtf..i was thinking is there a sealer
gaz he could use
#66 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 03 May 2018 - 07:06 PM
I don't really endorse it, but the only other thing he could do is, Wizz it all down with 180 free cut on a good da sander, till it's fully feathered smooth, do any additional repairs, etch those area's, & apply a polyester resin kit, you need to spray them whilst it's cool, or it drys in the gun, with a 2.5mm tip, leave it for around 2 weeks, block it with 180, then 240, then shoot it with hi build, leave it for 4 weeks, then block that as normal & top coat, it's not the correct way to do it, but with a car like that with all that paint & repairs it's the only way to get a decent job & buy some time, yes maz, it acts a bit like an isolator aswell. It's not the professional way to do it. But it will do what he needs, stops the painting walking on each level as much as it can, that's the main problem with paint thickness, hence why you bare metal strip. Gary.
#67 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 07 May 2018 - 11:11 AM
Thanks for the comments fellas.
Now that the car is on a rotisserie I'll rub it right back to metal.
#68 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 07 May 2018 - 11:14 AM
Mounted the car on the rotisserie on the weekend and my brackets are holding up fine.
I'll pull the diff and front end out of it next weekend and get into cleaning it up.
#69 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 14 May 2018 - 02:25 PM
I didn't have much time to work on the car last weekend with Mother's Day etc, but I dropped out the K Frame today.
#70 Heath
  • 18,403 posts
Posted 14 May 2018 - 04:35 PM
Nice work Matt.
#71 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 25 May 2018 - 10:55 AM
I am planning on hitting it with some paint stripper to get it back to metal.
My only concern is will the paint stripper damage the fibreglass flares??
#72 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 25 May 2018 - 06:16 PM
Best to go right back to bare metal everywhere mate, including under the fibreglass. You're probably going to find things you didn't want to see though i think. They're glassed over the top of the steel aren't they, not a fiberglass flare added & glassed into the body ?
#73 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 07 June 2018 - 03:49 PM
Now the old girl is on the rotisserie I have found some more rust sections. (to be expected)
This is on the drivers side up inside the guard. I'm thinking I will cut a lower section out of the guard to give me access in here to repair it then weld the section back in afterwards?
The issue I have is if I pull the guards off it will break the fibreglass flares which would mean removing them from the rear as well which is a much bigger can of worms than I really want to open with my skill level.
This is the sill and lower guard section on the passenger side. Not sure how to tackle this yet...
Anyway, at least I should hopefully be a decent welder by the time its all replaced :)
#74 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 08 June 2018 - 11:06 AM
So my plan is to cutaway the lower sections of the front guards (like Marty did in his thread) as the bottoms of them are rusted out and it will also give me access to repair the rust on the drivers side as shown above.
I'll then replace the lower sections with new ones from Resto Country.
That's my plan anyway, I'll see how I go   :spoton:
Marty's car
#75 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 08 June 2018 - 11:51 PM
I realised I had a couple of rollers back to front on the rotisserie so I pulled it all apart and fixed it as it was making it hard to adjust the height.
I also adjusted it all for a better centre of gravity.
3 and a half hours (and several beers) later and it rotates much easier.
Friday night well spent.
https://youtu.be/moaN5m6YZng
<iframe width="560" height="315" src="https://www.youtube....bed/moaN5m6YZng" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
