T56 magnum with Bremer shifter? Do i need Mal wood tail mod
16 replies to this topic
#1 horsepowerhowie
horsepowerhowie
  • 90 posts
  • Name:Howie
Posted 13 November 2017 - 04:31 PM
Hey just needed some Help  ive decided to now run a manual T56 magnum behind a stock ls3 with this bremer sequential shifter https://www.bremershifters.com/ and it has an remote shift housing so i can run the shifter anywhere so just a few questions.
Does this mean i can now avoid the Mal wood tail mod due to postioning the shifter wherever?
Also with the magnum can i run a cable straight to original dash as it has the choice of mechanical outlet on box also?
And what gearbox/diff gearing should i look at for stock a ls3 18 inch rims?
IAny help would be great thanks Nathan.
#2 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 13 November 2017 - 05:15 PM
The only thing i could advise you on is, in my cluby std ls1, t56, rip shifter, i have 3.73:1 & they're great, sit on roughly 1780 revs in 6th @ 103kph on a 235/40/18 factory tyre.
I have 3.90:1 in my cammed ls1 ss on 20's with a t56 probably sit on 1850 revs @ 103kph
Andrew will know more about the cable set up, i presume that you are going to tune the Ls3, I'd cam it while it was out, but that's just me.
#3 Bigfella237
Posted 13 November 2017 - 06:18 PM
I was looking at those Bremer shifters and they look like a nice bit of kit... but the price... WOW!
With a synchro box you still have to depress the clutch anyway, which takes longer than actually moving the gear lever, although I did see an electric-over-hydraulic clutch master system somewhere in my travels that could be ECU-controlled, but that's another story.
There are only two gear sets available in the aftermarket T56 Magnum, a 2.97:1 first gear and a 2.66:1
Unless you were using a really tall diff gear (like a 2.60 A9X ratio) and needed the lower first gear to launch with, my money says you're much better off with the closer ratios of the latter version...
Note that the "TUET11009" is the GM version with the concentric throwout hydraulic clutch, I can't remember off-hand what part number the Ford version with the mechanical clutch is? Buggered if I know why they didn't just make it one-case-suits-all myself? Would've been a lot simpler.
There is also apparently a "Magnum XL" version with a much longer rear extension housing but I can't remember what clutch options were available, I think it only came in the Ford version (which suits your mechanical clutch setup anyway) when I was looking at them but they said GM version coming soon, so both may be available by now?
What size rear tyres are you running (the exact size not just the diameter)?
And what driveshaft?
#4 Bigfella237
Posted 13 November 2017 - 06:34 PM
Ah shit, I just re-read your post... you were talking about the SPEEDO cable weren't you, not the clutch cable...
You can run a mechanical speedo cable off a T56 Magnum if you have a custom cable made, but I've never heard of whether you can buy interchangeable speedo gears to make it read correctly or not?
There are a few other solutions, even keeping the original speedo, such as a Cable-X which drives an old-school cable from an electronic speed sensor, and is of course fully adjustable...
#5 neglectedtorana
neglectedtorana
  • 1,041 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 13 November 2017 - 07:13 PM
I have the Mal Wood extension housing and it has a cable output, Mal told me he has different gears to go in the box for correcting the speedo
If the Magnum has the same setup I would think you could correct the speedo, surely different gears are available in the States too
Regarding the other benefits the Mal Wood extension housing is shorter so does not require cutting and replacing the cross member under the floor, it is the long extension housing used in the Commodore that cause the clearance issue with the cross member, if the Magnum box is shorter it might fit
Think Big Kev has a Magnum box in his
#6 horsepowerhowie
horsepowerhowie
  • 90 posts
  • Name:Howie
Posted 13 November 2017 - 08:08 PM
Thanks for the replies fellas as im a beater and need help with the mechanical side.
Grumpy- yeah im just going to have a stock crate ls3 with just stainless extractors and tune thats plenty for someone never having an 8 before.
Big fella- Yeah shifters pricy but second i saw it ditched the auto for manual setup.Im getting hydraulic mal wood clutch setup and Im hoping to avoid spending money on extension housing which cost over 2 grand. My rears are 285/35 and keen on custom cable as less stuff to hide.
Neglected- yeah ill talk to Mal again about the gears but hes adamant about needing the housing even though i said i didnt mind cutting floor.
Im trying to get an idea bout these boxes cause i might just get 1 from USA but font wanna stuff up and end up forking out more to suit or jave problems and cant send back. But ill check kevs page out ive seen a couple but not his.
#7 Oversteer
Oversteer
  • 244 posts
  • Car:LH SLR5000
Posted 13 November 2017 - 10:09 PM
The Malwood extension housing makes the box so much easier to fit, its the main structural floor cross base that needs to be cut using a std T56....a hard thing to re-instate.
A non cammed ls3 would work well with a 3.7 rear diff....cam it a little in it will like a 3.9.
The Bremer shifter is a bit of a novelty thing.....on a std syncro t56 it would not really make shifts quicker, and would result in dead syncros and more if you tried !
"Sequential" shifters like that have been around for a long time, and anyone who is proficient at shifting cogs will say they can do it faster on a normal H pattern ! ,you can see and hear in the vids that the shifter is not one action like a proper shift drum sequential dog box, and you will feel the multiple actions and friction as you push the stick...which makes it slow, add that to the fact it couldn't be used like a proper sequential dog box with no lift, no clutch etc.
I have a street driven vehicle with a Modena sequential dog box, set-up with ecu flat shift etc....its a frOcking magic thing when you want to got fast, less than .15sec shifts, just pull the stick at WOT, but driving in traffic with a sequential shifter has knobs on it, having to rack down thru gears when you want to go from 5th to 1st is time consuming and annoying...and i can just smash the dogs at any speed rapidly, the Bremer thing would be way slower and get old reeeeal fast.
#8 myss427
myss427
  • 1,636 posts
Posted 14 November 2017 - 09:02 AM
Also you need the right angle speedo drive adapter from Mal to stop the cable running into the tunnel, very close around there.
#9 Bigfella237
Posted 14 November 2017 - 11:32 AM
I've run the numbers with those specific tyre sizes for you Howie...
Tyre size = 285/35R18
Tyre diameter = 657mm (25.85")
Tyre Revolutions = 484 per km
I don't know what speedo cable drive/driven gears are available for a T56 Magnum, but I can give you a ratio between the output shaft and the cable for a standard Torana speedo for your tyre size with a range of diff ratios and you can work it out with the supplier from there:
Output shaft : cable
3.00:1 diff = 9:21 (reads 99.5 @ 100)
3.36:1 diff = 9:23 (reads 101.7 @ 100)
3.55:1 diff = 8:22 (reads 99.9 @ 100)
3.70:1 diff = 8:23 (reads 99.6 @ 100)
3.90:1 diff = 8:24 (reads 100.6 @ 100)
4.11:1 diff = 7:22 (reads 101.2 @ 100)
So for example, a 9 tooth drive gear with a 21 tooth driven gear. If you go with a diff ratio or tyre size other than any above just let me know and I can run that too?
Now the engine RPM at 100km/h for a selection of diff ratios in 6th gear, firstly for the TUET11012:
Gear Ratio = 0.50:1
Diff Ratio 2.60:1 = 1049 engine RPM @ 100km/h
Diff Ratio 2.78:1 = 1121 engine RPM @ 100km/h
Diff Ratio 3.08:1 = 1242 engine RPM @ 100km/h
Diff Ratio 3.36:1 = 1355 engine RPM @ 100km/h
Diff Ratio 3.55:1 = 1432 engine RPM @ 100km/h
Diff Ratio 3.70:1 = 1492 engine RPM @ 100km/h
Diff Ratio 3.90:1 = 1573 engine RPM @ 100km/h
Diff Ratio 4.11:1 = 1658 engine RPM @ 100km/h
And for the TUET11009:
Gear Ratio = 0.63:1
Diff Ratio 2.60:1 = 1321 engine RPM @ 100km/h
Diff Ratio 2.78:1 = 1413 engine RPM @ 100km/h
Diff Ratio 3.08:1 = 1565 engine RPM @ 100km/h
Diff Ratio 3.36:1 = 1708 engine RPM @ 100km/h
Diff Ratio 3.55:1 = 1804 engine RPM @ 100km/h
Diff Ratio 3.70:1 = 1880 engine RPM @ 100km/h
Diff Ratio 3.90:1 = 1982 engine RPM @ 100km/h
Diff Ratio 4.11:1 = 2089 engine RPM @ 100km/h
Here's a couple of 'visual aids' with a 3.36:1 diff used for example (the speeds will obviously change for other diff ratios) and a shift point of 5000 rpm, firstly for the TUET11012:
Compared to the same shift points for the close ratio TUET11009:
You can clearly see (looking at the lower graph on each picture above) that the closer ratio gear set of the TUET11009 has a much nicer "even" spacing. 2nd gear is almost "optional" in the TUET11012.
And finally, driveshaft RPM @ 120km/h (cruising speed for ½ critical RPM):
Diff Ratio 2.60:1 = 2517 driveshaft RPM @ 120km/h
Diff Ratio 2.78:1 = 2691 driveshaft RPM @ 120km/h
Diff Ratio 3.08:1 = 2981 driveshaft RPM @ 120km/h
Diff Ratio 3.36:1 = 3252 driveshaft RPM @ 120km/h
Diff Ratio 3.55:1 = 3436 driveshaft RPM @ 120km/h
Diff Ratio 3.70:1 = 3582 driveshaft RPM @ 120km/h
Diff Ratio 3.90:1 = 3775 driveshaft RPM @ 120km/h
Diff Ratio 4.11:1 = 3978 driveshaft RPM @ 120km/h
And again @ 240km/h (theoretical top speed for critical RPM):
Diff Ratio 2.60:1 = 5034 driveshaft RPM @ 240km/h
Diff Ratio 2.78:1 = 5382 driveshaft RPM @ 240km/h
Diff Ratio 3.08:1 = 5963 driveshaft RPM @ 240km/h
Diff Ratio 3.36:1 = 6505 driveshaft RPM @ 240km/h
Diff Ratio 3.55:1 = 6873 driveshaft RPM @ 240km/h
Diff Ratio 3.70:1 = 7163 driveshaft RPM @ 240km/h
Diff Ratio 3.90:1 = 7550 driveshaft RPM @ 240km/h
Diff Ratio 4.11:1 = 7957 driveshaft RPM @ 240km/h
You need to know the critical speed for your exact driveshaft and stay below it, you also want to avoid sitting around ½ of that critical speed under normal driving conditions so you don't have excessive driveline vibrations.
Driveshaft critical speed is the speed at which the harmonics meet the natural resonance and the shaft shakes itself to pieces. Critical speed is determined by the length and diameter of the driveshaft, as well as it's rotating mass. The shorter the shaft, the higher the critical speed. Same goes for the diameter, bigger is better. And light-weight materials such as carbon fibre make a big difference too (although there are other considerations with that option too).
You really need to crunch the numbers on the particular driveshaft that you'll be using but as an example, a standard 5.0L V8 Torana driveshaft (2.75" dia, 49.95" long, 1310 unis) would have a critical speed of 7192rpm and a ½ true critical speed would be 3589rpm.
If this was the driveshaft you're going to use, you can see from the info above that you couldn't really go lower than a 3.70 diff gear, but again, with a T56 your driveshaft will likely be shorter and so will have a higher critical speed.
#10 neglectedtorana
neglectedtorana
  • 1,041 posts
  • Name:Tom
Posted 14 November 2017 - 07:46 PM
myss427 is right about the speedo cable clearance too, I had forgotten about that.
I have a right angle adapter on mine I got from Mal
The speedo cable is not very neat avoiding the tunnel but it works
#11 horsepowerhowie
horsepowerhowie
  • 90 posts
  • Name:Howie
Posted 15 November 2017 - 08:59 AM
Wow thanks heaps big fella really appreciate the help alot.
#12 adrianh08
adrianh08
  • 219 posts
  • Name:Adrian Haynes
  • Car:1974 LH
Posted 23 December 2017 - 08:49 PM
How did this work out for you mate? I’m looking at the mal wood magnum extension housing into a TR6060 box to solve the floor brac and shifter issues but the cost is astronomical. $2000+ for the housing conversion and probable the best part of another $2000 to get it done as the new output shaft to run a slip yoke instead of the tri flange is basically a complete rebuild of the box. I just can’t justify the cost. Be better off with a different gearbox.
#13 ozyozyozy
ozyozyozy
  • 950 posts
Posted 23 December 2017 - 10:08 PM
I agree with above, bit of a novelty.
Can see the syncros get destroyed, as they can only be shifted so fast.
Still alot of work to make those boxes fit in a torana.
If you want fast shifting gearbox it must be a dog ring box but these are not very user friendly on the street.
#14 axistr
axistr
  • 1,212 posts
Posted 24 December 2017 - 07:26 AM
I have a GM spec magnum box in the SLR. They shift so good I don't think you need any performance shifter as they just shift so good as they come out of the box. I didn't cut the tunnel and the box still fits in the tunnel reasonably well for a big box. My tail shaft angles aren't perfect but I don't have any issues. I got the box new straight from Summit racing in the states. Cost under $4,000 including freight which is still cheaper than specking a TR6060 commodore box. Purchased the correct speedo cable drive gear from Mal (speedo is reading correct ) and cross member from CRS. Running the electronic speed pickup for the engine ECM and concentric bearing for the clutch. I wish my Hatch had the same box, it has a TKO series which is good but feels a bit agricultural compared to the perfect shifting Magnum box.
#15 Oversteer
Oversteer
  • 244 posts
  • Car:LH SLR5000
Posted 24 December 2017 - 06:13 PM
I took my LH to the drags with the T56 Magnum, your right on the street its a nice shifting box, better than a factory 6060, but at the drags i was laughing at how much time was lost on shifts.... it was comical, car would unload fully on the suspension and then have to set back down by the time you could effect a shift lol. Car ran a 10.3 @ 141 Mph with out me getting too violent with the shifter(and being told to back off @1000ft mark or go home), would run well into the 9's all day long with an auto and better set-up chassis....couldn't go WOT till top of third with ET streets.
#16 ozyozyozy
ozyozyozy
  • 950 posts
Posted 25 December 2017 - 10:04 AM
If you want to go racing, want manual and are serious.
Dog box is the only way, they keep the car settled on shifts due to in most cases not using the clutch on up shift.
Generally the harder you drive them the easier they are to shift.
trade off is they are a pig on the street, can not lazy shift them ever or they bite you.
You can buy ex nascar versions for less than some of your tremecs, also good for 800hp
#17 cameron
cameron
  • 371 posts
  • Name:Cameron
  • Car:LX SS Hatchback
Posted 28 December 2017 - 12:32 PM
If you want to fast automate (140ms) your hyd clutch you use an electric-hydraulic master cyd. You can activate it via a load cell on your stick shift (or activate via analog paddles).
S1 out of Brisbane also do a sequential shifter for the magnum.
https://www.s1sequential.com/
https://www.facebook.com/s1sequential/
Cameron
