KBS PROBLEM
43 replies to this topic
#26 Bigfella237
Posted 06 January 2018 - 10:41 AM
FWIW I was just reading another thread  "Paint grip 253" (sorry can't copy the link) and it refers to the browning of the metal as the reaction and not rust.  Interesting produt by the way.  Cheers Ron
http://www.gmh-toran...paint-grip-253/
also see:
http://www.gmh-toran...tal-protection/
Edited by Bigfella237, 06 January 2018 - 10:52 AM.
#27 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 06 January 2018 - 11:21 AM
I had this guard blasted about 4 months ago and coated with paint grip . It’s got a few scratches on it from being moved around but the scratches are still shiny metal too. Soon to be coated with epoxy , paint guy tells me run it back with a scotch pad then prepsol and paint
#28 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 06 January 2018 - 12:34 PM
Thanks for the info guys was just thinking I'm doing something wrong because it kept coming up with a brown stain that looks like Flash rusting or surface rust.
From what everyone is saying I must have done it right the first time just weird how it looks that's all.
#29 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 06 January 2018 - 12:40 PM
As Bomber said what you see is quite normal, . I've used both the KBS and POR versions and they both do the same thing. I think the websites even describe the brown rusty look. But if the steel was sandblasted you're far better just painting it straight away with the KBS, it sticks to the rough surface incredibly well, the rust blast is only needed to be used on rust or smooth clean shiny steel as it etches the surface for the KBS to attach to.
I just had 2 door shells minus skins blasted and picked them up and drove straight home and painted the inside with KBS satin on the fresh clean blasted surface, went on nice and smooth with a brush. Had a couple of little dents I didn't notice on bottom of door and gave them a few hits with a hammer and dolly and didn't even mark the KBS.
From website. Nothing about brown stains.
#30 Rockoz
Rockoz
  • 4,035 posts
  • Name:Rob
Posted 06 January 2018 - 12:45 PM
The white residue being zinc phosphate probably wont happen after blasting as most if not all of the zinc treatment would have been removed by the blasting process.
#31 S pack
  • 15,727 posts
Posted 06 January 2018 - 01:58 PM
Try diluting the rustblast at 5:1 ratio. 5 parts water to 1 part Rustblast. Apply with a scotchbrite pad or 00 steel wool and leave on panel only for as long as reqd to remove the rust then rinse off with clean water and immediately dry the panel out with clean dry rags and compressed air.
Just a thought.
#32 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 06 January 2018 - 02:52 PM
Yeah I see that, I may have seen it on a youtube video or the KBS guy told me over the phone as I spoke to them a couple of times and remember that the brown stain or flash rust was normal, I got it everytime I used it on fresh steel, never tried it on the sandblasted stuff as I painted straight onto it. And the POR 15 stuff does exact same thing as I used it last time as I couldn't get any KBS
#33 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 06 January 2018 - 03:23 PM
I even spoke with two different KBS distributors and they have both said to me that I have done something wrong to end up with Flash rusted / Brown stain on the steel. Don't know not worried anymore will just go back to doing it how I've always done it sandblast prepsol paint
Edited by Shtstr, 06 January 2018 - 03:24 PM.
#34 _Bomber Watson_
Posted 06 January 2018 - 04:37 PM
Report the distributors to the mother company, they are  either not actually certified by the company or seriously undertrained. See if you can get some free swag for them leading you astray.
#35 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 06 January 2018 - 06:37 PM
I’ve only ever spoken to the KBS guys , used to be up Newcastle way but now in Wollongong , they know their stuff.
#36 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 06 January 2018 - 07:37 PM
I miss the old days of a rep being trade qualified, not a counter jockey with a piece of paper who can meet the kpi's so he holds a job. There lies some of the issues ! I'd just stick to sand blast, blow off prepsol & paint. Always works well. Gary.
#37 _Bomber Watson_
Posted 06 January 2018 - 08:52 PM
Yes and no, with alkyd resins like KBS and POR you really need the phosphate from the rust blast.
If your using a ZP primer like epotec 408 then you dont.
Just my opinion.
#38 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 07 January 2018 - 02:05 AM
Buggered if i could prepsol after blasting
lol.cloth stuck to panel like shit on a
blanket..maybe you used something other
than garnet and aluminium oxide 80-120 grit
Gaz.. i ended up using a scotch brite pad
to take the edge off the blasted area so i
could just clean dust off.
Edited by madtoranajzedded, 07 January 2018 - 02:16 AM.
#39 _Bomber Watson_
Posted 07 January 2018 - 08:40 AM
I never prepsol after blasting, just handle the parts correctly.
If your not blasting them yourself then this can be more problematic.
#40 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 08 January 2018 - 11:23 AM
Ok so I spoke with KBS direct this morning as bomber said what I had is normal. So much for the rep at Napa and Moss Street.
#41 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 08 January 2018 - 08:10 PM
Counter jockey with a sheet of paper telling him what to do & say, I'd guess mate.
#42 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 09 January 2018 - 09:04 AM
That's how mine came out and is how it's meant to look with an orange tinge in places.  As Bomber said, it was right the first time.
I rust Blasted my whole shell 4.5 years ago then painted and it still looks great.
Marty
You are bad mouthing a product that is performing perfectly?
FFS it was fine to coat the the first time you did it.
It was fine to coat the second time you did it.
It was fine to coat the third, fourth, and fifth times you did it.
How the hell is this KBS's fault?
#43 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 18 January 2018 - 09:00 PM
Yer was given incorrect info from rep at napa. All sorted now.
#44 TerrA LX
Posted 18 January 2018 - 11:59 PM
You sure it's surface rust your getting or are you seeing the conditioning of the bare metal after the acid?
it leaves a gold coloured hue...
