Bat's 71 gtr
178 replies to this topic
#126 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 07 May 2020 - 06:36 PM
yes it is a sgnature , Tod was very help full , only make them to order
about 6 weeks before it arrived  cost $468.50 delivered
they also make them for all makes including canam spyder which i have
cheers  bat
#127 Ice
  • 15,202 posts
Posted 07 May 2020 - 06:58 PM
Wow they gone up l suppose its cheaper than Merrick still
#128 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 07 May 2020 - 07:14 PM
dunno i checked some old posts ( for fittment ) in 2013 signature were selling them $380
#129 Indy Orange
Indy Orange
  • 2,944 posts
  • Name:Paul
Posted 07 May 2020 - 07:41 PM
I received mine last year ,haven't fitted it yet ,about $500 to my door,cheaper than an original one and stronger.
#130 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 04 May 2021 - 01:41 PM
Well finally received new cam cogs and lifters from Clive b53b611861f2bf29c5b0e83b60899b23.jpg
Found a motor right date standed bore no lip
Still looking for a head 2811929 early 71
Just a hone if standed pistons are available
#131 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 07 May 2021 - 12:19 PM
G’day all ready to build my engine
Probably being discussed a 100 times
But after the colour , I think I have the original sump
As per photo being a CF is that right
Thanks bat
#132 claysummers
claysummers
  • 3,635 posts
  • Name:Clay
Posted 07 May 2021 - 12:30 PM
KBS have an engine enamel, Motor Coater. Rocket Red appears very close to the early red motor colour 64 through HKTG at least. It is almost orange really.cb48832df6f7daa1e56400993d4f2a83.jpg
early Holden nut
#133 71xu1
71xu1
    Dave
  • 1,275 posts
  • Car:LC GTR XU1
Posted 08 May 2021 - 01:23 AM
+ 1 Rocket Red, use hi temp primer, white and your colour will sing.
#134 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 14 May 2021 - 03:02 PM
g'day all
found a head e 17 1  so now to rebuild the engine so what are the valve size for the CF engine
thanks bat
#135 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 17 May 2021 - 03:02 PM
G,day all
Can’t decide on valve springs standed or heavier
What I have read is that the 161s and the 173 s are the same cam and use v8 springs
So is this right
#136 S pack
  • 15,723 posts
Posted 17 May 2021 - 05:56 PM
AFAIK the LC GTR did not use V8 valve springs. The XU1 did however the 186S, 2600S & 2850S did use valve springs that were better than the std offering.
#137 claysummers
claysummers
  • 3,635 posts
  • Name:Clay
Posted 17 May 2021 - 07:58 PM
Even a stock six benefits from fitting so called double valve springs. Which is why they were fitted to blue and black motors from factory. Eliminates valve bounce.
#138 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 17 May 2021 - 08:48 PM
thanks boys
specs for the 173s are
lenght & load -ins . @lbs
valve closed 1.513@ 68 / 76
valve open 1.175 @ 177/193
these are the specs that i have been given to do with the 173s
so what would you's recomend since the cam is slightly bigger
Edited by bat 53, 17 May 2021 - 08:50 PM.
#139 S pack
  • 15,723 posts
Posted 17 May 2021 - 08:54 PM
thanks boys
length & load -ins . @lbs
That is 100% correct and exactly the same for the 2600S.
#140 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 22 May 2021 - 11:59 AM
Ok according to other posts on here
Rocket red is the right colour vht Sp119 is the go
So what does everyone think !!!
#141 71xu1
71xu1
    Dave
  • 1,275 posts
  • Car:LC GTR XU1
Posted 23 May 2021 - 01:17 AM
Perfect
#142 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 23 May 2021 - 09:44 AM
thank's dave
#143 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 23 May 2021 - 07:09 PM
G,day all this is the spec,s for the new cam 195a747e33b54c996a6d00e46abdad8b.jpgCan’t decide on valve springs standed or heavier What I have read is that the 161s and the 173 s are the same cam and use v8 springsSo is this right Sent from my iPad using Tapatalk
Clive Cams would have supplied Valve Springs to suit your cam if you requested.
#144 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 24 May 2021 - 10:14 AM
spoke to him about the springs , never said he could supply :mellow:
#145 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 24 May 2021 - 12:39 PM
just spoke to clive ,
asked about suppling springs , they don't supply but will recomend strength
told him the 173s specs , he stated that i would be crazy to go any stronger
as the standard 173s spec is more than ample
#146 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 24 May 2021 - 12:49 PM
Thats Interesting....because 2 cam shafts i have bought from Clive, i have requested he supply valve springs to suit and lifters, all have come supplied by Clive Cams.
Im not saying he is the Manufacturer of the springs....
#147 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 24 May 2021 - 12:58 PM
Extract below, from last year email.
As requested, please find attached spec sheet for the Wade 391 profile on a Holden 6 cyl camshaft.
Prices are as follows:
Holden 6 Cyl Cam Billet $Xxx.00
Set of Cam Followers $Xxx.00
Set of Valve Springs $Xxx.00
Maybe he has stopped supplying springs.
#148 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 31 May 2021 - 05:21 PM
another question
does anyone have a photo of the starter motor
getting mine refurbished like to know what is shiny what is black
thanks  bat
#149 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 02 November 2022 - 06:29 PM
Bolting spare. Bits on so I don,t. Paint the gaskets.
Then will assemble
#150 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 15 December 2023 - 09:12 AM
g'day all
good news santa left me an early chrissy present
photos to come :lock:
