SLR in the making
#426
Posted 16 August 2020 - 12:59 PM
#427
Posted 16 August 2020 - 01:01 PM
Great Job Mitch, your underneath looks as bashed up as mine is.
I'll annoy my neighbours for days/weeks when I sand blast mine.
Marty
#428
Posted 16 August 2020 - 02:36 PM
I did have a crack with my little one but I accepted defeat 2 weekends ago. Not powerful enough and all the wheel arches sound deadener takes way too long and too much sand to come away.
That would have taken me 6 months working on saturdays to strip all that back seriously.
Well worth the money. He started the machine up at 8.30am and it went until 4.30pm crazy day. They earn there money let me tell ya.
I been out there for another 2 hours leaning the yard today, wifes not happy hahaa.
I'd highly recommend him he was a champion.
It was cheaper than hiring a more powerful,larger machine and buying all the sand to do it.
My underside is a bit bashed up and my chassis rails need a bit of panel beating also.
I will have a go on all of them repairs next Saturday and hope to prep the underside all ready to paint the following Saturday.
Plan is to KBS rust seal 2 x coats then paint over that with the Raptor bed liner that I have got delivered now also.
Hoping that hides alot of the imperfections for me
Motivated to get it down asap haha
Sent from my SM-G965F using Tapatalk
#429
Posted 16 August 2020 - 04:06 PM
Struggling to find info on it. It does say you can paint straight over after wax and grease.
I need to do welding, grinding and panel beating to the undedside and a little on the floors inside before paint.
So after repairs Should I still do the degrease then rust blast before I apply the rust seal paint?
Or as it is now in bonderite doni just wax and grease remover then paint KBS?
#430
Posted 16 August 2020 - 04:19 PM
#431
Posted 16 August 2020 - 04:23 PM
Looks like an easy way to get it cleaned up.
What did he charge you?
Was it an hourly deal, or a fixed price?
Was looking a buying a dustless blaster when my health gets better.
Rob
#432
Posted 16 August 2020 - 04:43 PM
#433
Posted 16 August 2020 - 05:15 PM
#434
Posted 16 August 2020 - 07:47 PM
All that for $1000Looks like an easy way to get it cleaned up.
Rob
Plus he sprayed the entire car with bonderite 253.
I got quoted $700 just to hire a machine to do it.
Then factor in the sand and going to pick it up and drop it off. Then I would of had to do it all.
Well worth it mate.
The strip discs were just pushing all the deadener around when I was doing it.I only use blasting in the awkward corners. Otherwise strip disc and wire wheel. Yes it takes time but can be enjoyable.
#435
Posted 16 August 2020 - 10:26 PM
#436
Posted 17 August 2020 - 12:25 AM
#437
Posted 17 August 2020 - 11:43 AM
#438
Posted 17 August 2020 - 11:53 AM
#439
Posted 17 August 2020 - 10:20 PM
Tip with the deadner.
Use a heat gun and a wood chisel to scrape 90% off then hit it with the nylon disc.
Marty
#440
Posted 17 August 2020 - 10:26 PM
Cheers mate.Is that raptor liner the kit with hardener with it? The one with hardener is great, leaves a good finish that u can wipe down nice, make sure u put plenty on, a little tip if u want a really nice finish use a primer gun with a decent size needle and cap, it comes out finer and really even. If it doesn’t have hardener I would 2pac paint over it, so much easier the clean when the cars all finished. Just suggestions though. Cheers
Yeah I got the one with the hardener in it.
I got the tintable version aswell and it came with the Schultz gun.
Im pumped to spray it on and am hoping it hides alot of the imperfections on the underside.
#441
Posted 17 August 2020 - 10:28 PM
So I rang KBS today and the guy was familiar with the bonderite 253 product and said he had been asked this exact question in the past from a guy doing the same thing as me with his project car.Not familiar with the particular product Mitch, but if it were me I would sand off as you do the rust, leaving the rest in place until you are ready to start surface prep. Then key with 240 trying to take most of it off before metal prep or rust blast and paint.
He told me to do all my repairs to the floor etc then complete the 3 step KBS.
Don't miss any step.
#442
Posted 17 August 2020 - 10:38 PM
#443
Posted 17 August 2020 - 10:55 PM
10ft beast from HawaiiLove the big Mal hangin on the wall
#444
Posted 23 August 2020 - 09:06 AM
#445
Posted 30 August 2020 - 08:23 AM
The arse fell out my make shift trolley so I finally brought a real welding trolley.
Also got my brake booster, brake master and proportioning valve all reconditioned
#446
Posted 30 August 2020 - 08:30 AM
I decided to stitch weld the entire chassis and diff arm mounts. What a mission. Ran out of gas half way through aswell coukdnt believe it.
Happy i did it all and that Its over now.
Dad and I also got the entire inside and bottom of the car KBS degreased and KBS Rust blasted.
We did it on the grass and got bogged haha
Had to tow it out with the ute hahaa.
Pumped to finally be at paint bottom and inside stage next Saturday.
2 years to get to this point so far
#447
Posted 30 August 2020 - 09:33 AM
#448
Posted 30 August 2020 - 11:22 AM
Looking good, Mitch.
I love seeing a true back yard build!
Any reason you went for a 6 cylinder brake booster? (The V8 equivalent of a VH271 should be a VH329)
~ Also got my brake booster, brake master and proportioning valve all reconditioned ~
#449
Posted 30 August 2020 - 11:41 AM
Thanks mateVery cool you’ve got the old boy on team Mitch. Your welding looks very good. Will improve rigidity and handling no end.
My engine guy suggested I do it.
I decided not to do the chassis extensions in the end but I am happy I did this stitch welding/strengthening. Apparently that's how they were in the Bathurst days? Someone told me the A9Xs were seam welded?
I Made sure I got good penetration, was alot of work bud, happy with the end result
Cant wait till its rolling now
#450
Posted 30 August 2020 - 11:45 AM
Cheers big fella.Looking good, Mitch.
Is there a difference?
That means the bloke at the brake shop told me a porky.
This is the booster that was on the car with HQ brake set up all around.
He told me they upgraded the entire internals of the system.
