What colour is it going to be Mitch?
SLR in the making
#51
Posted 24 September 2018 - 09:12 PM
#52
Posted 24 September 2018 - 10:37 PM
looks like it was a fairly rust free shell , which is rare these days
you have done a great job so far
Posted 24 September 2018 - 11:06 PM
Hey ShineyWhat colour is it going to be Mitch?
Barbados green has always been the plan!!
I wanna have the black bonnet a9x style but i want the blacked out rear end l34 style. Figured its not an original i can get away with having the best of both worlds.
I plan to do all the primer stages but I want the colour done professionally.
Sent from my SM-G930F using Tapatalk
Thanks matelooks like it was a fairly rust free shell , which is rare these days
I panel at a time
#55
Posted 25 September 2018 - 02:34 PM
Not to burst your bubble but with a 10 spline input shaft it can't be an M22, will be an early M20 or M21. Good box regardless though.The guy said it was an m21 but after looking online at how to determine your muncie and counting the splines and looking at the gears it looks like its an m22 rock crusher. What a steal.
Looks like you're making quick progress.
#56
Posted 25 September 2018 - 02:46 PM
Really? Im confusedNot to burst your bubble but with a 10 spline input shaft it can't be an M22, will be an early M20 or M21. Good box regardless though.
Just going off the super chevy forum/website info
As u can see in the pic no rings - 10 spline input m22 1967-1970
Thats what my one counts.
Is there another way to tell?
Ill take a photo of the gears and see what u think.
#57
Posted 26 September 2018 - 06:02 AM
It won't bother you unless you have a big block anyway, as I said still a good box. Ideally you don't want the very early M20 as it has a smaller layshaft but pretty much every variation is better than the Saginaw and especially the Aussie 4 speed originally used by Holden.
#58
Posted 01 October 2018 - 10:45 PM
#59
Posted 02 October 2018 - 10:36 AM
Nice work fella
If you want be sure on the gearbox, open up the side cover and post a photo of the gears. M21 Muncie is still a great transmission, hurst still sells great shifters for them.
#60
Posted 03 October 2018 - 07:08 AM
Cheers mateNice work fella
I will do next week when im back in town.
Keen to see the verdict
#61
Posted 13 October 2018 - 07:15 AM
#62
Posted 13 October 2018 - 06:07 PM
Edited by Lima31, 13 October 2018 - 06:09 PM.
#63
Posted 13 October 2018 - 06:38 PM
Looks like an M21 gearset. Still a great transmission, I have one.
The casing should have a serial stamping starting with P and ending with B if it came out of the factory that way.
See http://www.5speeds.c...tion/id-basics/ for more info.
#64
Posted 01 November 2018 - 05:31 AM
Thanks LimaLooks like an M21 gearset. Still a great transmission, I have one.
#65
Posted 24 March 2019 - 11:02 PM
I am accident prone!
I broke my left thumb playing cricket on new years day and haven't really touched the car since last year. The Chrissy rush and been so busy To start the year off.
I finally rolled the old girl out today and literally spent all day with a wire brush on a grinder knocking off the 3 - 4 month's worth of surface rust from all.of my exposed bare metal which I didn't treat properly
Sent from my SM-G965F using Tapatalk
#66
Posted 24 March 2019 - 11:06 PM
I also spent over an hour panel beating the top bonnet rail/radiator rail back to straight
It had more hits than Elvis.
Got it pretty good I think
#67
Posted 24 March 2019 - 11:08 PM
#68
Posted 24 March 2019 - 11:10 PM
I've been told it was done to my car in order to fit a hq radiator at some point in it's life.
I have heated it up and bent it back to straight. Should I weld it up or is that too risky with the chassis stamp there?
Help ?
#69
Posted 25 March 2019 - 08:54 AM
I would cut a small bit of plate to put under it first. That way you can keep the weld nice and hot and do the job in one pass. You should be able to keep the bead nice and flat so you don't need to go near it with a grinder. Some of the spatter prevention paint on the chassis number wouldn't go astray either. (Disclaimer... I'm just a farmer who usually fixes stuff with fencing wire and big hammers!!!)
#70
Posted 25 March 2019 - 03:14 PM
It depends on: 1) how good a welder you are; and 2) how fussy you are about hiding those cuts?
If you only have a MIG, I'd be tempted to just spot weld the outer edges of the lip to add a little strength to the middle tab and not weld anywhere near the chassis number. You will still have the open slots but at least you have a plausible excuse for why the stamping was damaged when Mr Plod raises his eyebrow. Whereas if you burn out half the "B" or cover it in 'bird poop' weld then it may look like someone was trying to alter the number and, at the very least, you may have to get a police number issued and re-stamped?
If you have a TIG then you may be able to sneak up on the stamping with a very low heat, and then maybe try to carefully repair the "B" by hand once everything else is cleaned up?
Or if you wanted to do it 'proper' then you would need to unpick that entire panel, then do the repair on the chassis rail separately to the upper panel, then spot weld it back on?
If this is a genuine SL/R then I would do everything I could to try to keep the original number intact, but if it's just a poverty pack on the tags then it likely won't affect the value that much.
#71
Posted 25 March 2019 - 09:30 PM
Get close with mig then bog would be my tip.
Strong enough and no heat (grinder) to clean up.
Edited by rodomo, 25 March 2019 - 09:30 PM.
#72
Posted 25 March 2019 - 10:38 PM
Thanks for the advice big fella. It's not an original SLR so I won't be doing the unpicking method that's for sure.
Thanks mateGet close with mig then bog would be my tip.
That is what i am leaning towards to be honest.
#73
Posted 26 March 2019 - 09:42 AM
Find a bit of copper pipe and hammer it flat.
Put thet under the cuts before you weld them.
Will help make it neater.
Bits of copper pipe are handy for many little welding jobs.
#74
Posted 26 March 2019 - 09:53 AM
For mig Rob?
#75
Posted 26 March 2019 - 08:55 PM
Thanks budFind a bit of copper pipe and hammer it flat.
I'm all over that one
Been using that trick since the start - been plenty of holes etc haha
