SLR in the making
653 replies to this topic
#151 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 28 January 2020 - 03:24 PM
Awesome work mate just about to start my build and reading how you done yours has give me heaps of info
Stick with barbados green mate always looks good
Thanks bud.
One job at a time hey haha
Still got alot to do.
I do love Barbados green!
Sent from my SM-G965F using Tapatalk
#152 Cook
Cook
  • 1,531 posts
Posted 28 January 2020 - 04:06 PM
Hate to say it Mitch but looks like the old man has been doing all the work while you are taking the photos lol.  Good progress.  Cheers Ron
#153 claysummers
claysummers
  • 3,664 posts
  • Name:Clay
Posted 28 January 2020 - 05:05 PM
Nice rotisserie. Good to see you’ve got the old boy on the job. Now get stuck in to it. 8)8)
#154 308 Sunbird
308 Sunbird
  • 975 posts
  • Name:Stuart
Posted 29 January 2020 - 07:30 AM
That's gunna make life a lot easier Mitch.
#155 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 29 January 2020 - 07:57 PM
Made up and welded extra plate onto each arm on the rear of the rottisserie. Prob a bit over the top but let's be honest it will be on here for a while. Now I can sleep better 77f03b994ec2e17aea02f3e5e3aac6b9.jpgadfa51fa8e82ca6bdcaccf269eba985c.jpg
#156 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 29 January 2020 - 08:05 PM
Pics of my diff currently on my back lawn until the Mrs kicks up a stink.
Anyone know what the brakes are off of?
Confirm what diff it is? 276cef6d76a43a1cbf4a5c78fb8333be.jpg225ebbceab9f0c7a9f1407889af0eac8.jpg383bed86134b728e649f7ecf9063fab2.jpg
#157 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 29 January 2020 - 08:16 PM
Can anyone tell me what these flares are that came off of my car? L34?
I want the wider rear flares. On the repliglass website it shows them being 90mm out from the car. Mine read nearly that when laid flat on the ground.
Also the rear spoiler is cracked and I don't think it is worth fixing. The front is also a little damaged but the flares seem ok, or are the holes too big in them? The dick before has butchered the car and also used metal screws to screw them on.
Any advice or help on this would be much appreciated.
#158 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 29 January 2020 - 08:19 PM
The first photo with the tape measure is from the center of the front flare
The second one is the rear flare reading 90mmb65dc65fa831e0c1f2593d20667e854b.jpg2ff0de9483d805c945c32cd13cd25ac7.jpg00b584ec85158fcb20b0a9a878eb0309.jpg5f750aa8457ccc40230b11ebc9f2122b.jpg9452e3b062d5668825abb2762b6501e5.jpg9f1bb293c06a38ef7c462e53f4e5169d.jpg6eb086f58ed1e874507737182385a178.jpg368f0433070da571e0e3c3b43a2e493d.jpg40ac42606de77d419757d248d6c7f668.jpgf9e579e67ddded8285b4d3596732ab33.jpg0bf8c034e97e5d9642740e02747dcb9d.jpg5235be501e718f7975e953847c5860ed.jpg21c95767e75f02d0ee3dbf71b6ec14a8.jpg6e0d45352e72102a3cd2e3d53951c8f5.jpg
#159 Shiney005
  • 9,720 posts
Posted 30 January 2020 - 12:54 AM
The rear spoiler sort of looks factory. Plastic, holes in the underside in the correct position, and they all cracked through the keyhole. The flares and front spoiler may as well go in the bin.
#160 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 30 January 2020 - 08:06 PM
Thanks Shiney.
I didn't think they were any good. Didn't know if they were worth fixing.
Do you think the spoilers worth fixing? or should I just get a whole new kit?
Is repliglass the best kit going around atm?
#161 oh five
oh five
  • 15 posts
Posted 30 January 2020 - 09:07 PM
Hi Mitch, I just fitted an ernicks kit with a rare spares plastic rear spoiler to my l34 rep.
The fit was very good with minor tweaking only. I'd highly recommend them.
BTW great job
#162 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 31 January 2020 - 09:37 AM
My guess is a statesman?? HX / Z
Have a check of the yoke size as they come in a 6 cyl and an 8 - if your putting any HP through it you would want to stick with the larger size
Edited by Swarbs, 31 January 2020 - 09:40 AM.
#163 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 31 January 2020 - 10:33 AM
Isnt that a complete uc torana disc rear end end jncluding brakes? Is it torana stud pattern?
#164 308 Sunbird
308 Sunbird
  • 975 posts
  • Name:Stuart
Posted 31 January 2020 - 04:24 PM
Looks like the larger V8 Salisbury to me, possibly from a Tonner or Commodore due to a lack of "ears"
cast onto the carrier housing. The Torana top mounts have then been welded on later which is an awkward
job to do because they position half on the cast carrier and half on the axle tubes in a LH/X. Looks like someone has
gone to a lot of trouble with this diff. It's been shortened and the other mounts attached and the brakes look like
HZ or WB. I've heard of shortened Tonner or 28 spline 9 inch axles being used.All in all a pretty good A9X diff copy.
#165 claysummers
claysummers
  • 3,664 posts
  • Name:Clay
Posted 01 February 2020 - 06:41 AM
The flexible hose looks a bit stressed with the tight bends in it. Might want to revise the mount, source something shorter, or change to a solid tube possibly?
Looks like a good setup otherwise. So what stud pattern is it?
#166 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 01 February 2020 - 09:14 AM
 Just looking at the photo's of the way the caliper is mounted - cant say i have ever seen one mounted directly to the end of the tube
Please correct me if ii am wrong but there should be a "hat" that bolts to the end of the tube flange and the caliper bolts onto  that
The dust cover for the disc also bolts to it
with the current set up under full braking load, that is a hell of a strain on such a small thin area
The "hats" i am talking about are in the photo below
The 4 holes with the funny offset bolt to the end of the tube flange  and the caliper bolts to the other end - you can see the mounting holes at the top
Attached File  rear disc set up.png   458.42K   10 downloads
The brake hose bracket bolts onto one of the dust cover mounting holes on the "hat" -- this would eliminate that severe bend in it
Edited by Swarbs, 01 February 2020 - 09:16 AM.
#167 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 01 February 2020 - 03:21 PM
Yes i agree. I have hz rear discs and they have the hats above.
#168 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 03 February 2020 - 01:33 PM
BTW great job
Thanks bud.
I will Definetly hit them up as they are in Sydney. Do they do the wider rear flares? L34 are wider or is it a9x? Ive read so many different things
#169 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 03 February 2020 - 01:37 PM
I am unsure about stud pattern.
I will remove the wheel and repost some pics on the weekend for you guys to have a look/inspection.
It is all new to me, could you guys send me a pic of your set up for me to compare too. After you see mine anyways.
Cheers guys
#170 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 03 February 2020 - 01:39 PM
Cheers bud
The guy I brought it off of said it had a 454 in it and it was all set up like a race car as you see from the initial pics.
Hopefully I can get it fixed up as I dont like the idea of putting Ford parts in a Holden
#171 Shiney005
  • 9,720 posts
Posted 04 February 2020 - 08:52 AM
Thanks bud.
A9X flares are the wider ones, but in my opinion, the L34 ones look better.
#172 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 04 February 2020 - 11:10 AM
Thanks Shiney.
Are the flares on this blue one L34 style?
That's exactly what I want mine to look like.
#173 Shiney005
  • 9,720 posts
Posted 04 February 2020 - 12:04 PM
I think that is Greg Manion's car, in which case they are the A9X bolt pattern flare, but they don't look as wide as the original ones.
The colour is Casino Blue.
Attached File  Greg Manion Casino Blue.jpg   164.68K   12 downloads
This gives you an idea of the size of the originals. (10 inch rims)
Attached File  aa.jpg   69.46K   13 downloads
#174 Statler
  • 6,326 posts
Posted 04 February 2020 - 05:45 PM
There were only 2 models 'factory' fitted with flares.
The LH Option L34
The LX Option A9X.
No LH's had A9X flare kits & no LX's had L34 flare kits.
Simples :)
Now factor in 45 years of aftermarket manufacturers all proclaiming their parts to be as good as genuine , yet all fitting just a little bit more wrong each time .  :furious:
:deal: Disclaimer : May contain traces of nuts. Do not operate heavy machinery after consumption .
#175 Shiney005
  • 9,720 posts
Posted 04 February 2020 - 05:57 PM
The first A9X sedans did get the L34 rear flares Col. The wider ones were homologated just in time for Bathurst.
