KC Alloy V8 rocker covers
12 replies to this topic
#1 toryman76
toryman76
  • 1,082 posts
Posted 17 April 2018 - 06:10 PM
Can anyone help me with some info in how hard it is to fit the KC alloy rocker covers on early cast iron heads? Car is LX with standard heater box and fan but it has a9x style master cylinder with dual diaphragm booster. I'm mostly concerned about clearances etc... Thanks in advance.
#2 76lxhatch
  • 7,201 posts
Posted 17 April 2018 - 07:24 PM
Shouldn't be an issue, I had to re-make the clutch master cylinder line so I could actually remove the driver side cover but there's just enough room now
#3 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 17 April 2018 - 07:44 PM
I had to add a small bit of clearance to the very corner with a die grinder on mine when the YellaTerra-3 Heads went on, otherwise, they fit as in the above pic.
#4 toryman76
toryman76
  • 1,082 posts
Posted 17 April 2018 - 08:16 PM
Ok cool. I have converted to a full cable clutch so I think I will need to look at that. Can you still get the covers off for servicing? Looks very tight to the booster.
#5 toryman76
toryman76
  • 1,082 posts
Posted 17 April 2018 - 08:26 PM
Looks like my cable should be ok but looking at the height difference I might need to tweak or remake my driver front brake line.
#6 76lxhatch
  • 7,201 posts
Posted 18 April 2018 - 06:14 AM
Yes that's why the banjo fitting on the clutch master, it will come off if you roll it toward the passenger side. It never actually touches the booster
#7 koalasprint
koalasprint
  • 297 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 19 April 2018 - 04:22 PM
I have YT Alloy Dash 3 heads and Torana engine mounts. Had to modify the rocker cover to clear the booster. HQ mounts might have also worked, but didn't have any at the time.
#8 toryman76
toryman76
  • 1,082 posts
Posted 19 April 2018 - 05:17 PM
Yeah ok sweet. Pretty sure I have HQ mounts. The torviki page that used to have a photo of the different types no longer has the photo. Is the easiest way to pick the torana mounts is by the u-shape with a gusset joining it together?
#9 Ando
Ando
  • 527 posts
  • Car:6/'76 L32 SS white & black. 9/'76 L31 SS gold. 5/'77 L31 SS Chamois. 3/'79 UC SL Deluxe hatch.
Posted 19 April 2018 - 06:49 PM
I put a wedge plate between the fire wall & booster. Worked a treat!!
 Attached File  wedge pl 2.jpg   108.71K   10 downloads
#10 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 19 April 2018 - 08:02 PM
6+JIC+M+x+3+8+BSPP+M+90+Degree+Elbow_L.j
I used one of these types of 90deg fittings in my Clutch Master when I had the Top Loader in the car, original iron heads then, but the rocker cover came off as described above, certainly close to stuff but came off fine.
#11 _Mint_
_Mint_
Posted 20 April 2018 - 09:30 PM
Ive got the same room as pretty much everyone else tho id do have flexable brake lines i can unbolt the master cylinder and swing it out the way for extra clearance..
one thing i might add if your running big springs and retainers the will hit on the inside of the covers you will need to relieve them
photobucket
#12 _Mint_
_Mint_
Posted 20 April 2018 - 10:20 PM
#13 toryman76
toryman76
  • 1,082 posts
Posted 26 April 2018 - 06:05 PM
Hey ando. Did you paint these yourself or can you get them supplied painted red?
