Where does this part fit? SLR Cluster
slr slr cluster lh
8 replies to this topic
#1 _Eagle75au_
_Eagle75au_
Posted 22 April 2018 - 06:05 PM
Hi all,
I have an SLR Cluster which had a loose part bouncing around inside, opened it up and found the piece below but unsure where it fits, any ideas?
#2 _1965mjr_
_1965mjr_
Posted 22 April 2018 - 06:19 PM
Part of the tacho,I reckon.
#3 Rockoz
Rockoz
  • 4,033 posts
  • Name:Rob
Posted 23 April 2018 - 10:54 AM
Yep its an integral part of the tacho.
The tacho is useless without it.
Very common for them to come off.
#4 _Eagle75au_
_Eagle75au_
Posted 25 April 2018 - 04:45 PM
Thanks, Any idea of how it mounts? Doesn't look like there is anywhere on the tacho for it!
#5 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 25 April 2018 - 05:45 PM
here
#6 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 25 April 2018 - 05:51 PM
another angle
#7 _Eagle75au_
_Eagle75au_
Posted 25 April 2018 - 07:41 PM
Legend thank you
#8 Rockoz
Rockoz
  • 4,033 posts
  • Name:Rob
Posted 26 April 2018 - 11:23 AM
You will be very lucky if you manage to refit it.
The wire is very fragile.
You will need to try to get some out of the toroid to make a joint.
Then there will be the problem of cleaning the enamel of the wire before you attempt to solder it.
I tried with 3.
Im trained in this type of stuff.
I didnt succeed.
You can buy the toroid from a VDO distributor in Perth from memory.
#9 VDO
VDO
  • 187 posts
  • Name:Chris Curtis
Posted 27 April 2018 - 08:08 AM
It's the choke.
Filters out high frequency "noise", cleans up the signal to the tacho circuit.
Also tagged with one or more of these keywords: slr, slr cluster, lh
