Dipper switch differences.
23 replies to this topic
#1 Indy Orange
Indy Orange
  • 2,948 posts
  • Name:Paul
Posted 06 May 2018 - 03:17 PM
Hi all ,I have here two different dipper switches ,the smaller one I know comes off a 1969 LC 161, but not sure about the larger one ,both have the same part number? Which one is correct for a 1971 LC ?
#2 S pack
  • 15,726 posts
Posted 06 May 2018 - 04:08 PM
Hi Paul,
They both have the same Patent number which is not a part number.
The longer switch appears to be stamped with a date code? of L5. 1965 or 1975?
I'm guessing the longer dimmer switch is 1965 HD Holden vintage and your 1969 LC short switch is correct for all LC/LJ Torana.
#3 Indy Orange
Indy Orange
  • 2,948 posts
  • Name:Paul
Posted 06 May 2018 - 04:20 PM
Thanks Dave ,great help.I will use the smaller one.
#4 Dr Terry
Dr Terry
  • 3,325 posts
Posted 07 May 2018 - 07:35 AM
I believe it to be the longer one. The shorter one was fitted to EJ to HG models & the longer one was for Toranas & HQ onwards, possibly to allow for thicker carpet & under-felt (soundproofing) etc.
I think the other clue is the presence of the 2 little 'ears' which retain the clips of the connector plug. If your harness connector plug is the black style with these 2 'ears' then the longer one it is.
Dr Terry
#5 Indy Orange
Indy Orange
  • 2,948 posts
  • Name:Paul
Posted 07 May 2018 - 06:25 PM
Dr Terry,that smaller one came from a LC 1969 S ,4 door 161 ,one owner had been sitting for years .do you think they may have changed to the longer type later?
#6 Dr Terry
Dr Terry
  • 3,325 posts
Posted 07 May 2018 - 07:14 PM
Quite possibly, but as I said the switch should match the harness connector.
The harness connector is black in colour & has the 2 retainer lugs, then the longer one with the 2 ears is the one to use.\\
The older cars had a cream coloured plug without lugs.
Dr Terry
#7 lx308
lx308
  • 2,843 posts
  • Name:Tony
  • Car:Nuffin. Goin touring.
Posted 07 May 2018 - 07:21 PM
Paul, this is what came out of my 73 LJ883ffed733e1e3a3bb2f2bafaedd8c74.jpg06077b1ce6cf7dc646b52f145089ade6.jpg
#8 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 07 May 2018 - 07:28 PM
Can't edit posts here anymore. :<_<:
Have no clue if it's correct or not.
#9 Indy Orange
Indy Orange
  • 2,948 posts
  • Name:Paul
Posted 07 May 2018 - 08:24 PM
Thanks Dr Terry,I'll check the connectors.Tony that looks like the smaller one like the one out of the 69 LC.
#10 S pack
  • 15,726 posts
Posted 07 May 2018 - 08:34 PM
Part Numbers.
Dimmer Switch Pt No. 1997028  suits HK Holden.
Dimmer Switch Pt No. 1997037  suits LC, LJ & LH Torana.
#11 Dr Terry
Dr Terry
  • 3,325 posts
Posted 08 May 2018 - 07:41 AM
Part Numbers.
To expand on that. 1997028 suits EJ, EH, HD, HR, HK, HT & HG. The later 1997037 suits LC, LJ, TA, LH, HQ & HJ.
This is according to the parts catalogues, but they are often not 100% accurate. It seems odd that GM-H would use 2 different switches in the HT, LC, HG era, it could be that early LC use the older part number & this was updated to the HQ style in 1971, as many parts were.
My LJ parts catalogue is dated 73, so if LC Toranas were updated the very early print parts books may show the earlier number. Anyone out there with an early print LC parts catalogue ?
Dr Terry
#12 S pack
  • 15,726 posts
Posted 08 May 2018 - 07:57 AM
The earliest LC Catalogue I have is October 1971 in which 1997037 appears.
#13 LJ RB30
LJ RB30
  • 1,038 posts
  • Name:Trevor
Posted 08 May 2018 - 10:48 AM
LC catalogue M36771 (can’t find published date??) has 1997028
LJ catalogue M37608 effective June 1975 has 1997037
#14 Dr Terry
Dr Terry
  • 3,325 posts
Posted 08 May 2018 - 10:59 AM
Well there you go. It looks like GM-H changed from the earlier switch to the later one mid-LC production & my guess is around the July 71 (HQ) upgrade. At this time many other things were changed, like 161 to 173, Opel M20 to Aussie M20, accelerator pedal etc. etc.
Dr Terry
#15 Indy Orange
Indy Orange
  • 2,948 posts
  • Name:Paul
Posted 08 May 2018 - 06:07 PM
Thanks for clearing that up guys ,well done.
#16 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 08 May 2018 - 06:44 PM
Dr Terry
I would say you'd be on the money there abouts, Dr Terry & it clearly makes sense to me ! Gary.
#17 Indy Orange
Indy Orange
  • 2,948 posts
  • Name:Paul
Posted 08 May 2018 - 07:12 PM
Makes you wonder what other slight changes were made around that time?
#18 Indy Orange
Indy Orange
  • 2,948 posts
  • Name:Paul
Posted 08 May 2018 - 07:17 PM
Did the later LCs get the head rests ?
#19 _Housecat1977_
_Housecat1977_
Posted 08 May 2018 - 08:44 PM
Mines 9/71 LC and it has the headrests.
#20 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Location:Adelaide... city of... anyone know something good about it?
  • Car:UC hatch
Posted 08 May 2018 - 09:34 PM
The mere fact that they say "Made in Australia" makes them collectible.   :cry:
#21 Indy Orange
Indy Orange
  • 2,948 posts
  • Name:Paul
Posted 08 May 2018 - 10:56 PM
Yeah,which brings me to "where was the Delco Remy factory in Australia "
#22 Dr Terry
Dr Terry
  • 3,325 posts
Posted 09 May 2018 - 07:46 AM
I believe the 'Delco Remy' factory was in the Fishermens Bend complex. GM-H made a lot of this stuff in-house. GM-H had a factory referred to as 'Disco' where they made there own (AC branded) spark plugs & many other electrical items.
This was the era where the cars were 99.99% local content. Even car radios were made in Melbourne (albeit not in-house), not Asia which became the norm by the mid-70s.
Dr Terry
#23 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 09 May 2018 - 06:19 PM
I know of 2, 10th 71 ck's with no headrests, (brisbane built) so the headrests may be hit & miss, in the early car's. Gary.
#24 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 09 May 2018 - 06:56 PM
Id say it was an option back then.
