Waterless Coolants
work??
30 replies to this topic
#26 UCgazman
UCgazman
    UC's FTW!
  • 1,342 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 11 July 2018 - 07:10 PM
We used to use Water Wetter in our skid cars, you just mix it with water in the radiator. It does basically the same thing and was effective for us - burnout cars get very hot very quickly and this was one of our secrets for keeping them from boiling. Also cheap and easy so might be worth a try? I think you can get it at Repco etc...
#27 RallyRed
  • 8,081 posts
Posted 12 July 2018 - 04:40 PM
Ok, just to close the loop...used  3 bottles of the Prep. fluid and then 3 bottles of the Waterless Coolant, to "convert " the cooling system from water.
Remembering that this task was not about the engine , or overheating of the engine, or trying to mask a dud cooling system, or corrosion, or pressure buildup , or if water is better, or that water has been around for ever etc etc...it was about dealing with localised boiling at the turbo cooling line after turn off.
Outcome - appears to have solved the issue. Early days, but so far = good.
Thanks for the feedback  too guys. Appreciate it. It is much more $$ than tap water, so it took a bit to get it over the line here.
#28 Bigfella237
Posted 12 July 2018 - 05:02 PM
So which product did you go with in the end?
#29 RallyRed
  • 8,081 posts
Posted 12 July 2018 - 05:08 PM
The Evans stuff
#30 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 13 July 2018 - 06:47 PM
Good work Col, hopefully you're all good now mate, Gary.
#31 RallyRed
  • 8,081 posts
Posted 22 July 2018 - 11:40 AM
End story..... .a week or so later. Car has been driven hard, stuck in traffic, commuted, full noise skids etc..no probs at all. Happy.
