LC GTR distributor identification
_bunkerjest_
Posted 15 August 2018 - 07:31 AM
Posted 15 August 2018 - 07:40 AM
Distributor Part No. 7448948 - suits all LC Torana 2600 & 2600S engines.
Seeing as it was a fairly common part it should be relatively cheaper than an XU1 dissy.
Posted 15 August 2018 - 08:10 AM
S pack is correct, the LC GTR distributor isn't unique to GTRs, it's just the regular issue 2600 (161) item (9230062601 Bosch).
As a matter of fact it's also the same as HK/T/G 161/186/186S.
The 2850 & 2850S (173/173S) late LC use the regular HQ dissy, 2820111 (9230062612 Bosch)
Oddly the 2250 engine used 2810081 (9230062607 Bosch) which is virtually identical & even GM-H listed this as a replacement for 2600 engines in the later 1973 parts catalogue.
Dr Terry
Posted 15 August 2018 - 03:55 PM
Dr Terry
Actually it is the other way around Dr Terry.
The Oct 71 LC Parts Catalogue lists the following:
Distributor Assy ......2250, 2600, excl 'S' eng .............................................2810081
Distributor Assy ......2600 'S' eng ...............................................................7448948
The April 73 LC Parts Catalogue lists the following:
Distributor Assy ......2250 eng .....................................................................2810081
Distributor Assy ......2600 eng .....................................................................7448948
_LONA-CK_
Posted 16 August 2018 - 07:03 AM
I have plenty if anyone needs them, $80 to your doorstep
Cheers gong
