Tim's LJ - The Build Diary
#376
Posted 16 October 2008 - 07:23 PM
Tim
#377
Posted 16 October 2008 - 07:26 PM
#378
Posted 16 October 2008 - 07:28 PM
Tim
#379
Posted 16 October 2008 - 07:30 PM
#380
Posted 16 October 2008 - 07:32 PM
Tim
#381
Posted 16 October 2008 - 07:34 PM
#382
Posted 16 October 2008 - 07:38 PM
oh, because I needed a set and they were cheaper than Rares.
Tim
#383
Posted 16 October 2008 - 08:01 PM
1. Finish Sanding rear quarter
2. Check if blue boot is straight
a. Strip and straighten it
b. Drill holes for �Torana� badge
c. Weld up �S� badge holes
i. Grind, bog, sand
3. Remove drivers door
a. Remove door trims
b. Fix rust in door
c. Get the door pin out!
4. Remove windscreens
a. Fix any rust under windscreens
i. Weld up rust holes in rear windscreen
ii. Grind, bog and sand around rear windscreen
iii. Sand and rust convert rust in front windscreen
5. Fix rust in rear window
6. Weld pin holes on front left guard
a. Grind, bog and sand over welds
7. Clean up welds in inner sill/inner guard
8. Cut out sill from shell
a. Fit new sill
9. Fix splash guard,
a. Refit
10. Fix drivers side sill
a. Grind/bog/clean up
11. Fit lower guard rust repair
12. Finish welding guard to A pillar
a. Bog/grind/clean up
13. Remove badges from drivers guard
14. Fix lower nosecone
15. Finish bogging/sanding nosecone
16. Baremetal the whole shebang, start getting some primer on ☺
17. Cut shifter hole
18. POR15/Sound deadener the floor
19. Roll the guards
20. Mask up dash
a. Paint dash
21. Prepare doors for fitment of GTS Mirrors
22. Paint door jams, tops of doors, under bonnet and boot, Mirrors
23. Block/sand/rub down etc panels, ready for primer
24. Prime
25. Paint
26. Straighten/clean up bumpers
27. Refit bumpers, grille, lights etc
28. Fit new rubbers
Tim
#384
_Patrick_
Posted 16 October 2008 - 08:03 PM
#385
Posted 16 October 2008 - 08:06 PM
Tim
#386
Posted 16 October 2008 - 08:09 PM
#387
Posted 16 October 2008 - 08:26 PM
#388
Posted 16 October 2008 - 08:30 PM
Tim
#389
Posted 16 October 2008 - 08:36 PM
I honestly reckon I can get it done in less... The race is on!
Tim
What are you waiting for tim! start now
#390
Posted 17 October 2008 - 06:34 PM
and his mate Smith said, "Murphy is an optimist" (Smith's corollory)
Edited by limo, 17 October 2008 - 06:35 PM.
#391
_waz355_
Posted 17 October 2008 - 06:40 PM
#392
Posted 17 October 2008 - 06:48 PM
Ken, you wouldn't happen to have a spare LC/LJ tacho around the place would you? Thanks for the advice, and trust me, I know Murphy's law all too well
Tim
#393
_PrincessBabydoll_
Posted 17 October 2008 - 07:06 PM
Here's the 'To Do' list, as it stands now... Things in Bold have already been done. Reckon I can do this in 30 days of work?
b. Drill holes for 'Torana' badge
c. Weld up 'S' badge holes
i. Grind, bog, sand
b. Fix rust in door
a. Fit new sill
a. Refit
19. Roll the guards
20. Mask up dash
a. Paint dash
24. Prime
25. Paint
28. Fit new rubbers
Tim
Prove em all wrong & do it!!
I have faith in you Tim haha
& OMG yours is ALMOST pink!! Like the pink font I use that you love so much!!
Good luck!!
#394
Posted 17 October 2008 - 08:09 PM
Thanks for the support
Tim
#395
_PrincessBabydoll_
Posted 17 October 2008 - 08:50 PM
I was waiting for you to point out that mine is almost pink, Leigh
Thanks for the support![]()
Tim
#396
Posted 17 October 2008 - 09:39 PM
Mort
Edited by Mort, 17 October 2008 - 09:39 PM.
#397
Posted 18 October 2008 - 01:52 AM
Tim
[/quote]
I have at least a half a dozen "spares" but the only ones I know work are in my cars, I tried a few for you last time you asked but didn't find a worker, bought some more since but untested
#398
Posted 18 October 2008 - 08:13 AM
Tim
#399
Posted 18 October 2008 - 08:31 AM
There is a reason for that. I hope your transaction goes to plan and then the company gets shut down lolI needed a set and they were cheaper than Rares.
#400
Posted 04 November 2008 - 09:07 PM
This morning I borrowed a MIG and got stuck into the drivers sill. I've fixed all of the rust and dents in that, now I just need to tidy it up a little bit more
I also filled up the couple of little rust holes in the rear windscreen, and a couple of badge holes. Oh, and I removed the drip rail trim (3/8 spanner worked a treat
Tomorrow I'll be having a go at the passengers side sill
EDIT: Also, my carpet and rubbers arrived
Tim
Edited by RIM-010, 04 November 2008 - 09:09 PM.
