Tim's LJ - The Build Diary
#926
Posted 22 June 2021 - 06:14 PM
#927
Posted 23 June 2021 - 05:32 PM
Cleaned up my gearbox crossmember and finished modifying it to suit the Celica box
#928
Posted 24 June 2021 - 07:47 AM
You might find that the crossmember will flex or bend in the middle unless you've added some strength to the back side.
#929
Posted 24 June 2021 - 01:45 PM
#930
Posted 24 June 2021 - 03:03 PM
#931
Posted 24 June 2021 - 05:25 PM
The diff just needs to have the centre assembled and fitted, axles in etc etc. I'm not keen to do it myself and frOck it up, so I'll give it to the professionals.
#932
Posted 24 June 2021 - 05:57 PM
#933
Posted 25 June 2021 - 12:22 PM
Voila!
Also had to give it a little tickle to clear the speedo cable.
Now just for a squirt of underbody black and in she goes.
#934
Posted 25 June 2021 - 09:42 PM
Those sunnies aren't a welding mask dontcha know?
#935
Posted 29 June 2021 - 08:05 PM
Got the painters at work to give my diff a squirt of black... Shiniest thing on the car now!
#936
Posted 10 July 2021 - 07:11 PM
Got the GTS mirrors mounted.
Next step is to get the crossmember back in and trial fit the diff so I can get a tailshaft measurement, then send the diff off to get built and a tailshaft made.
Things are happening!
#937
Posted 10 July 2021 - 10:40 PM
Pic of GTS mirrors please?
#938
Posted 11 July 2021 - 02:12 PM
Just a note, if you mount them where the original mirrors mount, you won't be able to open the quarter windows.
#939
Posted 12 July 2021 - 12:23 AM
Thanks Tim
#940
Posted 13 July 2021 - 11:18 PM
Did b/w into gtr many years ago vaguely remember shocks were pita to fit due to caliper clearance so they went on first then brakes...larger tailshaft meant handbrake adjuster studs grinded on it & re-routed handbrake cables.
Should be fun to be back in a torrie..still regret taking mine off the road & letting life get in the way.
#941
Posted 14 July 2021 - 08:35 PM
#942
Posted 14 July 2021 - 08:46 PM
WUHAN style,
Posted 17 July 2021 - 07:03 PM
Seen some cars that moved lower mounting stud for shock absorber to face rearward...looks sthe impler way to go.
Mine barely fit but when we realised diff joint made diff wider than specified & tailshaft issues on first drive I had a dummy spit sent car off to get mini-tubbed etc lol
#944
Posted 29 July 2021 - 03:32 PM
Handbrake cable is getting sorted, Flexible Drive Agencies are going to make me up a new one at the right length with the right ends. Just need to move the mounts on the car to suit.
Now that the handbrake is sorted I can get the diff put together, get it back in, get the tailshaft in and then it's just brake lines and wheels...
There is now a mob in Adelaide building new billet Mawer centres, so I'll go with them.
Getting closer!
Oh I sorted out the speedo cable and clutch pedal/cable the other week too... Man it was a lost easier to play under the dash when I pulled this thing apart 15 years ago...
#945
Posted 29 July 2021 - 08:29 PM
Ya just getting old dude & no longer youthful contortionist.
Snapped a few speedo cables back in the day if they had slightest kink to them
#946
Posted 29 July 2021 - 08:41 PM
#947
Posted 29 July 2021 - 09:31 PM
It'll be a pretty simple fix with a custom cable.
#948
Posted 29 July 2021 - 10:48 PM
#949
Posted 02 August 2021 - 08:26 PM
No dramas with clearance on the brakes, the Falcon calipers are forward-mounted.
This, coupled with the fact that the Falcon rotor is heaps shallower than the Commodore setup, makes the Falcon BW78 a much more user-friendly diff if you want proper wheels on a Torana... And you get a better stud pattern as a bonus.
#950
Posted 10 August 2021 - 11:07 PM
Progress!
