Tim's LJ - The Build Diary
#151
_JBird_
Posted 20 January 2007 - 12:55 PM
#152
Posted 20 January 2007 - 09:42 PM
postal_dood, I haven't got the wheels yet, theyre just what I want.
RIM
#153
Posted 26 January 2007 - 09:50 PM
Rear quarter before -
During -
and After -
Its not finished yet, obviously, but atleast we have the metal covered.
and now, to the thinking part. I measured up the front seats in my cousin's Toyota Soarer. They're 550 wide x 600 long on the base, and 930 from the bottom of the base to the top of the headrest. A standard LJ Seat is about 550x550 base, and about 880 tall. The Soarer seats are bloody narrow, but really supportive and comfy. Sam reckons they can be picked up for about $100/pair, and come in either Electric or Manual.
Unfortunately, Dad's not keen to install a set
And, the rest of the thinking went into the electrics. The tacho has been pissing me off, it jumps straight to full revs as soon as you start the car, and stays there wether you accelerate or not. It is all wired up properly, so the gauge itself must be screwed...
Next bit of thinking - Because I have 'Huge plates'o meat', My foot doesnt fit real well between the Clutch pedal and the trans tunnel, which is where the high beam switch lies. I am thinking of relocating the switch to the console, when I build it. Simple job, really, just need to sort out a suitable switch.
Cheers, Look forward to feedback.
RIM
#154
_Flamenco_
Posted 26 January 2007 - 10:06 PM
Not sure about the seats - if you take out the seats you'll see the floor doesn't sit level on both sides - I would think the soarer ones probably will. Won;t be a problem if you install the non electric ones because you can just use the LJ's runners. I'm sure you know the high beam switch is just 2 selftappers and could be moved anywhere by extending the wires.
#155
Posted 26 January 2007 - 10:09 PM
Yes, I know that the high beam switch is only screwed in with 2 screws. I'd hardly even have to extend the wires!
RIM
#156
_Flamenco_
Posted 26 January 2007 - 10:13 PM
#157
Posted 27 January 2007 - 09:36 AM
I love Photoshop
Waddya Reckon?
RIM
#158
Posted 27 January 2007 - 05:41 PM
Mick.
#159
_Monkey_
Posted 27 January 2007 - 05:43 PM
Convo's FTW.
#160
Posted 27 January 2007 - 08:27 PM
Started with this -
and figured that the box on the left hand side would be a waste of space. I was gunna use that to keep the Jack, oil, wheel brace etc in. Instead, I used my geniusness and came up with this:
EITHER - Cut the spare wheel well out of a shell and weld it into the LHS boot floor, and use it as a toolbox.
OR - Fabricate a similar sized box out of sheetmetal and weld it into the LHS boot floor, creating a toolbox.
What do you guys reckon? Will there be any legal violations in doing this? I won't be cutting into the chassis or anythin, just cutting a hole probably 200x300 in the boot floor.
RIM
#161
Posted 06 February 2007 - 09:22 PM
RIM
#162
Posted 07 February 2007 - 11:52 AM
#163
_73LJWhiteSL_
Posted 07 February 2007 - 12:59 PM
Steve
#164
Posted 07 February 2007 - 03:10 PM
Steve, Gas is for BBQ's, not Torana's...
Cheers guys.
RIM
#165
Posted 07 February 2007 - 04:01 PM
#166
Posted 07 February 2007 - 06:12 PM
Nah, If it was an LH/LX I'd run it on LPG... From what I've seen, Gas bottles don't fit too awesomely in LC/LJ Boots...
RIM
#167
Posted 07 February 2007 - 07:05 PM
I'd just keep the boot standard, keep the LJ on petrol, put the radio head unit in the console and keep the original seats (just get them retrimmed). Will save alot of money and effort.
Cheers Mick.
#168
Posted 07 February 2007 - 07:23 PM
I know I create alot of work for my self, it's because I spend too much time thinking about the car and not enough time working on it (and there's SFA I can do about that ATM...)
I want to atleast weld a box into the boot for tools. Piss easy to do (famous last words), as far as I can see it, and will create a neater boot.
Oh, and we've decided that it won't be near ready for my P's
RIM
Edited by RIM-010, 07 February 2007 - 07:24 PM.
#169
Posted 07 February 2007 - 07:32 PM
Keep up the good work.
Mick.
#170
Posted 07 February 2007 - 07:37 PM
Maybe when I put a 1JZ/2JZ in it, I'll drop a set of Soarer seats in. Or is that getting too Toyota-ish?
RIM
#171
Posted 07 February 2007 - 08:32 PM
And he now has an original Radio and Speakers.
Cheers for that mate.
RIM
#172
_jake_
Posted 07 February 2007 - 09:33 PM
#173
Posted 07 February 2007 - 10:39 PM
It was registered before I started pulling it down. I couldve left it how it was, and drive it around like it was. But that's just dodgy. I don't want to rush it just so I can have it ready for my P's, and I just won't have the time between now and September to do it! I'll be home for a total of about 70 days between now and September.
RIM
#174
_73LJWhiteSL_
Posted 08 February 2007 - 11:34 AM
Tell me about it... But it sure eases the pain at the fuel pump I will tell you that. I love the fact it only cost me at most $35 to fill a tank, and thats good for around 500ksGas bottles don't fit too awesomely in LC/LJ Boots...
Steve
#175
Posted 08 February 2007 - 08:08 PM
No probs mateAnd, thanks to Loui, I know have a set of Headlight surrounds and a decent grille
RIM
You will be wishing you had'nt swapped when ive got talkback radio pumping as im cruising the streets
Loui
