Tim's LJ - The Build Diary
#201
Posted 23 April 2007 - 04:34 PM
#202
Posted 23 April 2007 - 05:06 PM
I'll let the pics do the talking...
^ That bit was a rust repair patch we put in. Yes, there is metal under the filler, the bog is just there to seal it.
Now I have the panels dummy fitted, for welding tomorrow!
Tim
#203
Posted 23 April 2007 - 05:17 PM
#204
Posted 23 April 2007 - 05:23 PM
#205
_northy_
Posted 23 April 2007 - 05:32 PM
#206
Posted 23 April 2007 - 05:49 PM
#207
_jake_
Posted 23 April 2007 - 06:11 PM
#208
Posted 23 April 2007 - 08:25 PM
#209
Posted 24 April 2007 - 08:25 AM
Cheers guys, much appreciated.
Tim
#210
Posted 24 April 2007 - 08:39 AM
#211
Posted 24 April 2007 - 10:51 AM
#212
Posted 24 April 2007 - 12:51 PM
#213
Posted 24 April 2007 - 02:42 PM
Mick.
#214
Posted 24 April 2007 - 03:37 PM
More pics soon...
Tim
#215
Posted 24 April 2007 - 04:00 PM
#216
Posted 24 April 2007 - 05:03 PM
#217
Posted 24 April 2007 - 05:05 PM
Which I found here -
Bit annoyed about it. Would've been easy to knoock out with the panel off of the car, but now that it's welded in it's a bit of a task.
Welded down the gaurd -
Patched up the aerial hole -
and with a coat of metallic bog, you'd never know it was ever there! -
Bit more of said metallic bog on the corner here, to cover the weld and get it smoooth. -
And here -
And here -
Got a bit more to do, cleaning up welds etc.
Tim
#218
_hatcheddan_
Posted 24 April 2007 - 05:53 PM
#219
_HatchmanSS76_
Posted 24 April 2007 - 07:25 PM
#220
_Keithy's_UC_
Posted 24 April 2007 - 07:41 PM
Keith
#221
Posted 19 May 2007 - 11:06 AM
The little bolt on panel that holds the light surrounds and grille in place doesn't fit too well. Bolt one end on, and you have to twist it to bolt the other end on. Any ideas?
Then there's this bit I need to fix -
Cheers, Tim
#222
Posted 19 May 2007 - 03:29 PM
thats my only thought on the matter.
i reckon heaths spidey sence may have been very wrong. I havent seen anything done to his car for AAAAAGGGEEEES! id say its a race!
#223
Posted 19 May 2007 - 08:53 PM
I'll probably just oblong one of the holes to get it to fit straight...
I too believe that it may be a fair race between Heath and I
Tim
#224
Posted 22 May 2007 - 03:59 PM
#225
Posted 22 May 2007 - 04:04 PM
Elongate both holes if necessary, but make it central to the car.We didn't trial fit this, unfortunately...
Tim
