Battery in the boot
21 replies to this topic
#1 _Luke1981_
_Luke1981_
Posted 02 September 2018 - 02:36 PM
So I've put my battery in the boot of my LC but it's shorting out somewhere, anyone know how it should be wired up? I've earthed the block to the chassis and the battery negative in the boot to the chassis, the battery postive straight to the starter and the alternator to the starter as well.. where have a gone wrong?
#2 RallyRed
  • 8,117 posts
Posted 02 September 2018 - 03:39 PM
Disconnect the cable at the starter and alt.    Tape them up.
If it's still ""shorting"", its just the cable itself ,cut through the insulation, or similar, on its way from back to front of car.
are all your holes through bulkheads etc nicely bushed, to stop cuts?
#3 _Luke1981_
_Luke1981_
Posted 02 September 2018 - 04:01 PM
I've got heat shrink on all the connections and the insulation on the cable is fairly thick, i can't imagine it's cut through but I'll start with that cheers
#4 _Viper_
_Viper_
Posted 02 September 2018 - 05:49 PM
The way you have it connected is correct, Do as Col said... either a short in the cable somewhere or maybe where you had the lug on the starter or alternator it was touching the body of the starter/alternator.
#5 _Luke1981_
_Luke1981_
Posted 02 September 2018 - 06:18 PM
Ok thanks, I'll check it out
#6 rexy
rexy
  • 3,715 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 02 September 2018 - 07:03 PM
By shorting out do you mean it won’t crank? If so there are a few other things to look at other than those mentioned above.
#7 _Luke1981_
_Luke1981_
Posted 02 September 2018 - 08:39 PM
When i connected the battery it sparked and melted the battery terminal
#8 rodomo
  • 18,032 posts
Posted 02 September 2018 - 09:17 PM
Can you put up pics of the connection to the starter and alternator?
#9 _Luke1981_
_Luke1981_
Posted 02 September 2018 - 09:25 PM
I'll try put up pics tomorrow
#10 S pack
  • 15,694 posts
Posted 03 September 2018 - 07:55 AM
Agree, sounds like there is a short somewhere in the run of cable.
Perhaps it has been a while since installing the battery cable through the car and you have performed other assembly work since and penetrated the cable insulation with a screw or pinched/squashed the insulation on the metal bodywork?
Edited by S pack, 03 September 2018 - 07:57 AM.
#11 _Luke1981_
_Luke1981_
Posted 03 September 2018 - 08:36 AM
So if the lugs are touching the starter body that could cause it to short out? that might be the problem. should there be some sort of rubber washer type thing under the lugs to keep it off the starter body?
#12 RallyRed
  • 8,117 posts
Posted 03 September 2018 - 12:25 PM
yep...body = earth = short cct
#13 _Luke1981_
_Luke1981_
Posted 03 September 2018 - 12:45 PM
Ok cheers mate, i`ll look at that
#14 _Viper_
_Viper_
Posted 03 September 2018 - 06:04 PM
Usually its plastic surrounding the lugs but the actual body of the starter is nearby, It is possible for the lug to touch to body if the cables are not run to avoid it. Any part of the starter body is direct ground path.
#15 _Luke1981_
_Luke1981_
Posted 03 September 2018 - 07:17 PM
Ok thanks, there's a good chance that's my problem then as i can't see anything wrong with it
#16 S pack
  • 15,694 posts
Posted 03 September 2018 - 07:30 PM
It should be impossible for the circle terminal connectors to touch the starter body if you have them connected to the correct terminal which is the one on the solenoid furthermost from the starter motor.
The terminal with the longer thread at the top of the pic.
#17 Rockoz
Rockoz
  • 4,021 posts
  • Name:Rob
Posted 04 September 2018 - 07:28 AM
Take pics of each end, and show us how you have actually fixed the cable to the body.
#18 _Luke1981_
_Luke1981_
Posted 04 September 2018 - 10:05 AM
I checked it out last night and you`re right, i can`t see how it would touch the body of the starter.. BUT i`m starting to think maybe the lug on the alternator might be touching the alternator body, would that cause a short as the wire from the alternator goes to the starter which is connected to the positive on the battery?
#19 _Luke1981_
_Luke1981_
Posted 04 September 2018 - 10:08 AM
I`ll try get some good photos tonight and upload them
#20 S pack
  • 15,694 posts
Posted 04 September 2018 - 05:24 PM
I'd like to see a pic of the melted battery terminal please.
#21 _Luke1981_
_Luke1981_
Posted 04 September 2018 - 05:50 PM
Worked it out, stupid little washer that goes behind the lug on the alternator was missing so the lug was touching the alternator body. Found the washer and she's all good.. thank you all for your help
#22 RallyRed
  • 8,117 posts
Posted 04 September 2018 - 07:29 PM
winner winner..good work.
