Hi all.
I've had my master cylinder rebuilt using 1 of these kits, http://www.earlyhold...-torana-square/
Screenshot_20180917-071719.png 861.83K 12 downloads
Needed the correct primary piston from the kit as the 1 I had wasn't correct.
Now, the original primary piston has holes in it behind the cup & washer, the piston in the kit doesn't. We're thinking this is vital, but not sure, as we're having trouble achieving an acceptable brake pedal after bleeding the brakes. Photo below shows the holes depicted in the piston (number 3) from the parts book.
We've bench bled the master.
20180917_071118.png 580.14K 10 downloads
