Pilbara Tunna
14 replies to this topic
#1 _pilbara-torana_
_pilbara-torana_
Posted 01 November 2018 - 02:51 AM
Been a while since I posted here but have been busy with another project to keep busy with..
Bought this HJ 1 Tonner back in early 2000 and offloaded it to the old man whilist the Torana was getting panel and paint..
Dad painted it Midnight Blue added gas to the 253 and used it to get to work...
When I was in Newman I needed a 2nd car so bought it back off Dad... Did a couple of little mods
#2 _pilbara-torana_
_pilbara-torana_
Posted 01 November 2018 - 03:00 AM
Decided to do the Sea change to Wickham in 2012 so shipped the Torana back to mum and dads (as I had no where to store)..
Umm and arrrd with what to do with the tunna as we settled into Wickham, Lucky enough we was able to build a shed so in it went and the rebuild began..
#3 Shiney005
  • 9,479 posts
  • Car:Toyota Mirai
Posted 01 November 2018 - 11:08 PM
Those "QuickGrips" are a great little invention, right up until you start welding the bits you are holding with them!!! I wish they would make them out of steel.
What is with the 44 full of arrows? Enduro???
#4 _pilbara-torana_
_pilbara-torana_
Posted 01 November 2018 - 11:45 PM
Yeah definetly good until the heat kills the plastic. they are still being used now so they do last.
Arrows are for enduro marking in Newman was one of the last tracks I marked out. Plenty of good riding up here.
#5 _pilbara-torana_
_pilbara-torana_
Posted 01 November 2018 - 11:53 PM
So it time to have a play with the tray. So got some 3 inch pipe for the head board and 12 inch rolled mudguards. At this stage is when I wished I got all new steel as the tray wasn't square at all. But a cut here there got it pretty good in the end
  • Attached File  7.jpeg   132.03K   3 downloads
  • Attached File  8.jpeg   142.99K   3 downloads
  • Attached File  9.jpeg   72.45K   3 downloads
  • Attached File  10.jpeg   88.31K   4 downloads
  • Attached File  11.jpeg   79.91K   4 downloads
  • Attached File  12.jpeg   61.77K   3 downloads
  • Attached File  13.jpeg   184.8K   3 downloads
#6 _pilbara-torana_
_pilbara-torana_
Posted 02 November 2018 - 12:01 AM
Then it was off with cab. One those jobs I didn't really want to do but made it easier to fix the sills and floors.
So goodbye 253 and lift the cab
  • Attached File  14.jpeg   207.69K   4 downloads
  • Attached File  15.jpeg   196.31K   3 downloads
  • Attached File  17.jpeg   185.76K   3 downloads
#7 _pilbara-torana_
_pilbara-torana_
Posted 02 November 2018 - 12:04 AM
Freshen up the chassis with some paint and all new suspension gear thanks to Kingswood country kit (burger with the lot) now able to move around again.
  • Attached File  16.jpeg   203.97K   4 downloads
  • Attached File  18.jpeg   167.4K   4 downloads
#8 shanegtr
shanegtr
  • 533 posts
  • Name:Shane
  • Car:LJ 2 door
Posted 03 November 2018 - 11:46 AM
Good to see some other Pilbara people here - although I don't plan to be here for much longer as a move back to Perth in on the cards for the start of next year.
The project is looking good however
#9 _pilbara-torana_
_pilbara-torana_
Posted 10 November 2018 - 04:22 AM
Cheers ShaneGTR, There are a few nice Cars up this way.
Next job was the Cab, With no decent spare Cabs around I jumped in the deep end and persevered with what I had.
So the was rust quite a bit of it, the plenum was a headache.
  • Attached File  24.jpeg   184.58K   4 downloads
  • Attached File  25.jpeg   95.57K   4 downloads
  • Attached File  20.jpeg   120.09K   3 downloads
#10 _pilbara-torana_
_pilbara-torana_
Posted 21 November 2018 - 05:36 AM
So there was a bit work that went into this plenum, I had to remove the old one and replace the rusty bits with some new steel.
Was able to source a decent plenum from a wreck so unpicked it and replaced the corner and welded into place. By this time I was over grinding.
#11 _pilbara-torana_
_pilbara-torana_
Posted 21 November 2018 - 05:54 AM
Sorted the firewall out, Preped the floor and inside. Gave a primer and finished off with some Black paint.
Then it was time to seal the cab and install it back on the chassis
#12 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 21 November 2018 - 05:56 PM
Looking good
#13 Shiney005
  • 9,479 posts
  • Car:Toyota Mirai
Posted 23 November 2018 - 08:38 AM
When I see this picture it makes me realise just how much good stuff I used to throw into the tip.
Attached File  .1.JPG   120.55K   2 downloads
#14 _pilbara-torana_
_pilbara-torana_
Posted 30 November 2018 - 01:10 AM
The drivers guard needed some work and I had 3 to choose from yet all were not the best, so I made 1 decent guard out off 2. Welded in some GTS flutes and etched primed.
#15 _pilbara-torana_
_pilbara-torana_
Posted 30 November 2018 - 01:21 AM
Moved onto the passenger side guard, Front corner needed a small amount off tapping to get its shape back. Stripped back the Stato nosecone and sealed.
