186 xu1
2 replies to this topic
#1 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 13 January 2019 - 10:27 AM
g'day all
dose any have the specs [valve sizes ] and cam for the 186 xu1 engine
thinking about building the 173 to those specs
cheers  bat
#2 S pack
  • 15,726 posts
Posted 13 January 2019 - 11:07 AM
Hi Albert
The 186X valve sizes were:
Inlet           1.622" - 1.626"
Exhaust     1.411" - 1.417"
Which altered slightly with the CK Prefix 186X to:
Inlet           1.619" - 1.629"
Exhaust     1.404" - 1.417"
The 186X timing specs were:
Inlet valve opens BTC            23 deg
Inlet valve closes  ABC           65 deg
Duration                                268 deg
Lift @ valve                          .345"
Exhaust Valve opens BBC      58 deg
Exhaust Valve closes ATC      30 deg
Duration                                268 deg
Lift @ valve                          .345"
Valve open overlap                 53 deg
The CK prefix 186X timing specs were:
Inlet valve opens BTC            38 deg
Inlet valve closes  ABC           86 deg
Duration                                304 deg
Lift @ valve                          .429"
Exhaust Valve opens BBC      77 deg
Exhaust Valve closes ATC      46 deg
Duration                                304 deg
Lift @ valve                          .429"
Valve open overlap                 84 deg
I have the original 173S timing specs if you want those too.
Dave.
#3 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 13 January 2019 - 01:19 PM
thanks dave
yes the 173s specs would be handy as well  :spoton:
cheers  bat
