Hoodlining padding
18 replies to this topic
#1 Indy Orange
Indy Orange
  • 2,945 posts
  • Name:Paul
Posted 17 January 2019 - 06:39 PM
Hi all,I'm soon to install my Hoodlining into my LC ,according to workshop manual to roof structure has padding along the first roof brace ,I'm wanting to know if the padding extends all the way along or just in one place .Thanks Paul.
#2 Indy Orange
Indy Orange
  • 2,945 posts
  • Name:Paul
Posted 17 January 2019 - 08:52 PM
Anyone noticed where the padding sits in this area when doing Hoodlining?
#3 S pack
  • 15,726 posts
Posted 17 January 2019 - 10:12 PM
Don't remember ever seeing any padding there in my LJ when I had the headling out in '96, so I went and had a feel along that rail and there is no padding.
#4 _SableMet7/73_
_SableMet7/73_
Posted 17 January 2019 - 10:44 PM
I'm with Dave, none there on my LJ either.
Only padding was on the C pillar.
#5 _mikecatts_
_mikecatts_
Posted 18 January 2019 - 06:51 AM
yes it did on LJ and LC.... as per my pics will be ok..
#6 S pack
  • 15,726 posts
Posted 18 January 2019 - 07:19 AM
Perhaps another Adelaide v Brisbane thing or the padding was dropped in production in '73?
Edit: Actually, it would make sense if the padding became redundant when the energy absorbing sun visors were introduced into production.
Edited by S pack, 18 January 2019 - 07:23 AM.
#7 Indy Orange
Indy Orange
  • 2,945 posts
  • Name:Paul
Posted 18 January 2019 - 05:39 PM
Thanks Mike.That's why this site is so invaluable,often the workshop manuals don't show the full extent of what you want ,cheers chaps!
#8 Indy Orange
Indy Orange
  • 2,945 posts
  • Name:Paul
Posted 19 January 2019 - 01:54 PM
Thanks for that ,
#9 Indy Orange
Indy Orange
  • 2,945 posts
  • Name:Paul
Posted 19 January 2019 - 02:00 PM
I seem to remember removing a rear parcel shelf cover board and having padding underneath that scored piece which kicks up at the bottom of the rear windscreen,maybe to stop vibration.
#10 jd lj
jd lj
  • 2,113 posts
  • Name:James D
  • Car:LJ SVO
Posted 20 January 2019 - 05:45 AM
That's correct. Perhaps though it's more to lift the back so that it sits just tucked under the rear windscreen rubber with no gap.
#11 S pack
  • 15,726 posts
Posted 20 January 2019 - 07:42 AM
Hi James, out of interest, does your LJ have those pads on the roof rail above the visors?
Dave.
#12 jd lj
jd lj
  • 2,113 posts
  • Name:James D
  • Car:LJ SVO
Posted 20 January 2019 - 12:19 PM
I'll have to check but I'm 99% sure that it doesn't. I can probably check my friends LC GTR too over the next few days.
#13 jd lj
jd lj
  • 2,113 posts
  • Name:James D
  • Car:LJ SVO
Posted 21 January 2019 - 05:43 PM
My 7/73 Adelaide built LJ doesn't have the padding near the sunvisors. I also checked a 3100X LC XU-1 Brisbane built which doesn't have it either but that car has been rebuilt in the past so it's not a clear indication like my own car is.
#14 Kevrev
Kevrev
  • 420 posts
  • Name:Kevin
  • Car:73 LJ GTR, 77 LX SS 253 Manual
Posted 21 January 2019 - 07:38 PM
The 9/73 LJ Adelaide 4 door untouched one owner original  car I wrecked a few years ago had no padding, nor did my 12/73 Brisbane GTR, but the GTR has been through  a few rebuilds.
#15 Indy Orange
Indy Orange
  • 2,945 posts
  • Name:Paul
Posted 21 January 2019 - 07:57 PM
I think you could be right Dave,I think LCs had it before the ADR change,the rear roof rail on mine also had two small pads on each side where the rail joins.
#16 S pack
  • 15,726 posts
Posted 21 January 2019 - 08:03 PM
I have found out an original unrestored LC CK XU1 with no front roof rail pads either.
#17 Indy Orange
Indy Orange
  • 2,945 posts
  • Name:Paul
Posted 21 January 2019 - 08:06 PM
Well there goes that theory.
#18 craigcn27
craigcn27
  • 12 posts
  • Name:craig
  • Car:lc
Posted 07 November 2023 - 07:45 PM
Just checked my original roof lining for my 10/70 brisbane built car. You can see the whiter area at the front of the roof lining where the foam was touching confirming in my case it did have the foam as per LC manual
#19 S pack
  • 15,726 posts
Posted 07 November 2023 - 08:09 PM
I doubt it was a foam type material. Would have been more like that straw coloured matted hemp type padding material that GMH commonly used back in the day.
Edited by S pack, 07 November 2023 - 08:10 PM.
