* * * * - 2 votes
LH Gpack
150 replies to this topic
#26 Statler
  • 6,309 posts
Posted 16 June 2019 - 08:56 AM
Looks like the temp/fuel gauge is fried.
Also has a SLR speedo.
#27 Covert
Covert
  • 1,987 posts
  • Car:LH
Posted 16 June 2019 - 10:10 PM
Have got all the hanging panels repaired and primed ready for paint. Decided to use stripper for the shell, started today and got a bit done attachicon.gifIMG_0061.jpgattachicon.gifIMG_0062.jpg
Good old paint stripper, great for the sinuses :)
Your doors look mint
#28 Shiney005
  • 9,537 posts
  • Car:Toyota Mirai
Posted 17 June 2019 - 09:10 AM
This was all G-Pak's though wasn't it?
#29 Bigfella237
Posted 17 June 2019 - 11:32 AM
According to the parts cattledog there were only two different speedos for the whole LH model, VS12406 and VS12417
One had a 6 figure odometer, and the other with a 7 figure odometer, but I'm not sure which is which.
It says all L34's got the 6 figure type, so I assume the 7 figure type came later?
But aside from that, there's no mention of 8VD69 models getting a different speedo to everything else?
#30 Statler
  • 6,309 posts
Posted 17 June 2019 - 01:14 PM
I'm sure someone will correct me if the i'm wrong .
I'm of the impression that the Slackpack had a 190 kph speedo & the SL/R has a 200.
#31 Shiney005
  • 9,537 posts
  • Car:Toyota Mirai
Posted 17 June 2019 - 03:02 PM
In the advertising blurb, it stated that it came with "full sports instrumentation, including tacho, kilo speedo, oil, temperature and fuel gauges". I would reckon that would be the full SL/R dash.
I have just been doing a bit of research into the tacho's on LH Toranas, and no 4 cyl ever had them fitted. (So why the 4 cyl switch on the back?) The sports dash also wasn't available through NASCO as an option on any LH that didn't come with one from factory. As far as I could make out, only the Gpak and SL/R's had them. I can't confirm it, but I am sure all dash's with full instrumentation would have had the 200 kph speedo in lieu of the 160 kph speedo.
#32 Dr Terry
Dr Terry
  • 3,324 posts
Posted 17 June 2019 - 03:05 PM
I believe that the SL/R got the 200 km/h speedo & the S & SL got the 160 km/h version.
From memory they changed from a 6-digit odo to a 7-digit in early 1975. HJ changed around the same time.
Dr Terry
#33 Dr Terry
Dr Terry
  • 3,324 posts
Posted 17 June 2019 - 03:43 PM
They list part numbers for gauges & their senders for 4-cyls in the parts catalogues.
The L34 will use a 4-cyl sitting for the tacho because of the twin point set-up. It has effectively got 2 separate 4-cyl ignition systems.
The think that the G-Pak should have the 160 km/h speedo.
Firstly that's the way the parts catalogue reads & secondly that's how HJs work. i.e. if you got a sports dash in a non-GTS in HJ it had the lower spec speedo. I think GTS got 220 km/h & the others got 200 km/h.
Dr Terry
#34 _imj411_
_imj411_
Posted 17 June 2019 - 07:34 PM
The Gpak had a 200kph Speedo. Some LH Speedos had mph as well as kph, cheers Aaron.
#35 snuff1966
snuff1966
  • 186 posts
  • Car:LH G pack
Posted 17 June 2019 - 08:20 PM
Pretty sure It's the original dash in my car, it was only a two owner car that had been in a shed for a fair while.
#36 Shiney005
  • 9,537 posts
  • Car:Toyota Mirai
Posted 18 June 2019 - 08:43 AM
The L34 tacho is unique to that model Dr Terry. There is no switch at all on the rear of the gauge.
Attached File  Tacho 1.jpg   50.35K   22 downloads
Edited by Shiney005, 18 June 2019 - 08:47 AM.
#37 CYCO355
CYCO355
  • 152 posts
  • Name:Cameron
  • Car:G PAK and a LH sl, VS Senator, VE SSV sedan
Posted 18 June 2019 - 08:34 PM
As far as I know this is the original one out of my 2/75 g pak 5fef866041aa94af0cbb82757dae7ae6.jpg23426a164910517d60682388730106eb.jpg
#38 Shiney005
  • 9,537 posts
  • Car:Toyota Mirai
Posted 18 June 2019 - 10:21 PM
I have been chatting to a couple of owners over in Facebookland, and the consensus is that they had the 200 kph speedo.  This is from a two owner car.
Attached File  Speedo Gpak 1.jpg   42.28K   16 downloads
#39 koalasprint
koalasprint
  • 297 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 25 June 2019 - 09:13 AM
An original taco has the 4/6/8 "switch" on the circuit board. It is on the track side, not the component side. If the taco has been refurbished then there is no switch, just a trim pot that is good enough to cover the range required for calibration.
Pics show an old circuit board (original) and the new replacement version with just a trim pot. Now change to how it looks from the back of the cluster.
Cheers, Steve.
#40 Shiney005
  • 9,537 posts
  • Car:Toyota Mirai
Posted 26 June 2019 - 08:23 AM
Steve, I have seen a few from L34s now, and they are all the same. There is no cutout in the plastic housing for the switch lever at all, and the ones I've seen have been in the cars since 1974.
Attached File  L34 dash with no lever on tacho.jpg   44.07K   15 downloads
#41 snuff1966
snuff1966
  • 186 posts
  • Car:LH G pack
Posted 10 August 2019 - 05:57 PM
Got the red oxide off today, a bit more of a rub and a wipe over with some rust converter and some etch and we’ll be ready for a few repairsAttached File  IMG_0072.jpg   274.51K   23 downloadsAttached File  IMG_0073.jpg   302.94K   22 downloads
#42 purrlx
purrlx
  • 1,332 posts
  • Name:Danny
  • Car:LX hatch
Posted 10 August 2019 - 06:19 PM
That looks good, nice work stripping it back
#43 snuff1966
snuff1966
  • 186 posts
  • Car:LH G pack
Posted 24 August 2019 - 01:11 PM
A bit more done today Attached File  IMG_0077.jpg   515.71K   10 downloads
Attached File  IMG_0078.jpg   272.7K   11 downloadsStarted to repair around the window
Attached File  IMG_0076.jpg   361.12K   11 downloadsAttached File  IMG_0079.jpg   466.53K   10 downloads
Got some panels on to check some gaps
#44 Shiney005
  • 9,537 posts
  • Car:Toyota Mirai
Posted 24 August 2019 - 01:55 PM
That white rim on the rear right....... is that Monaro??  I thought I heard once that the ones with the 8 slots were.
#45 snuff1966
snuff1966
  • 186 posts
  • Car:LH G pack
Posted 24 August 2019 - 04:23 PM
Just a standard HK 5.5"  The Monaro ones are the same only 6"
#46 mandytory
mandytory
  • 101 posts
  • Name:peter
  • Car:lh sedan gpac, uc hatch
Posted 24 August 2019 - 06:35 PM
My Gpac has 200 kph speedo. My brother had bog stock lx S povo sedan and it had the sport dash fitted standard .
#47 rodomo
  • 18,032 posts
Posted 24 August 2019 - 11:21 PM
HK had the slots regardless of Monaro. HT and HG didn't.
#48 claysummers
claysummers
  • 3,601 posts
  • Name:Clay
Posted 25 August 2019 - 12:33 AM
HK rims were the last made by Holden. HT and LC on were ROH and had different nut taper. Don’t use those rims on the road unless you match the wheel nuts.
#49 Kevrev
Kevrev
  • 420 posts
  • Name:Kevin
  • Car:73 LJ GTR, 77 LX SS 253 Manual
Posted 28 August 2019 - 06:04 PM
HK standard rims are 5”, V8 and later GTS 6”
There were slotted HT/HG rims, fitted only on manual 350 Monaro’s
#50 snuff1966
snuff1966
  • 186 posts
  • Car:LH G pack
Posted 07 September 2019 - 10:08 PM
Attached File  IMG_0081.JPG   271.19K   13 downloadsAttached File  IMG_0080.JPG   290.26K   15 downloads
Got the shell in primer, got to get the boot and engine bay rubbed back now
