LX Hatch Complete Restoration
477 replies to this topic
#251 hanra
  • 10,975 posts
Posted 10 August 2021 - 08:23 AM
Is this the same shell? Fitted well back then?
#252 hanra
  • 10,975 posts
Posted 10 August 2021 - 08:26 AM
Maybe the entire nose cone, guards and bonnet need to be shuffled backwards a bit which will in turn bring the latch closer to the radiator support?
#253 Shiney005
  • 9,604 posts
  • Car:Toyota Mirai
Posted 10 August 2021 - 09:47 AM
It all needs to work forward of the cowl. How is the gap between the cowl and the bonnet?
#254 Bigfella237
Posted 10 August 2021 - 11:16 AM
Yep, you need to fit/gap all the panels without the latch fitted to the bonnet, then adjust the latch so it closes without altering the gaps.
You do know the latch on the bonnet is adjustable, don't you Mando?
I can see the slot in yours under the bolt head so it must have a fair bit of backward adjustment left in it.
Regards Mando.
#255 rexy
rexy
  • 3,740 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 10 August 2021 - 02:52 PM
It’s got a lip though that limits rearward movement. You could always trim that off.
Maybe it’s parallax error but it looks like the top of the radiator support is bowed backwards in the centre?
Love the colour!
#256 jeffblanco
jeffblanco
  • 388 posts
  • Name:Mando
Posted 10 August 2021 - 03:26 PM
Brad / Laurie / Hanra,
the gaps all around the bonnet are good.
The shell in your post Brad is the first body I had which was stolen.
This is a picture of my second car which is the orange one you see below.
Attached File  DSCN0476.jpg   342.38K   6 downloads
Rexy,
I could mill the lip from the bracket but I decided my solution was going to be easier.
Andrew,
I had those holes elongated, a little to much as you can see.
The bracket is hard up against the bonnet.
Attached File  IMG_0777.jpg   103.19K   7 downloads
Attached File  IMG_0778.jpg   98.81K   6 downloads
Attached File  IMG_0779.jpg   76.8K   6 downloads
Attached File  IMG_0780.jpg   140.66K   6 downloads
Regards Mando.
Edited by jeffblanco, 10 August 2021 - 03:28 PM.
#257 hanra
  • 10,975 posts
Posted 10 August 2021 - 03:54 PM
Im thinking the guards need to shuffle rearward a little to allow the nosecone to also move back a tad. Then you may be left with the 3mm or so gap that the finger guard would have taken up.
#258 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 10 August 2021 - 05:37 PM
May need to move the doors back then? Stunning finish mando.
#259 Ice
  • 15,202 posts
Posted 10 August 2021 - 06:41 PM
Great detail Mando
#260 jeffblanco
jeffblanco
  • 388 posts
  • Name:Mando
Posted 10 August 2021 - 07:59 PM
Brad,
the radiator support probably has a slight 2 mm bow in the centre.
The bolts on the left and the right of the front panel went through the front panel
and into the radiator support without touching the sides of the holes.
The bolts on the far left and right also went through the front panel through the holes
in the guards and into the radiator support without any interference what so ever.
2 mm from the guards being to far forward, 3 mm for the thickness of the finger guard
add another 2 mm from the radiator support have a slight bend in it gives me 7 mm
which are the size of my spacers.
My head is starting to hurt.
Regards Mando.
#261 hanra
  • 10,975 posts
Posted 14 August 2021 - 07:45 PM
The fan finger guard is 3mm thick.
#262 hanra
  • 10,975 posts
Posted 14 August 2021 - 07:48 PM
But in saying that. It sort of kicks forwards at the top. Which prob moves the bonnet latch another 1-2mm forward.
#263 rexy
rexy
  • 3,740 posts
  • Name:Rexy
Posted 15 August 2021 - 12:46 PM
As you can see it can all fit without the finger guard or a spacer. As long as the car is all gapped nicely it doesn’t really matter much.
You could try bending the radiator support forward, they aren’t very stiff.
If the aesthetics bother you, you could always modify the striker (easy) or the latch (harder). No one would ever notice the striker plate mod.
#264 jeffblanco
jeffblanco
  • 388 posts
  • Name:Mando
Posted 15 August 2021 - 05:39 PM
Thanks Brad,
your plate measures 11.7 cms at the top and mine measures 11 cms at the top.
There's my 7mm right there.
I have two plates from two different cars and they measure the same.
Brad,
I understand what your saying regarding gaps, but my car has consistent gaps throughout including around the doors and bonnet,
even though I specifically asked the panel guy to leave the gaps the way they came and not make them perfect.
I wanted the car to look like it would have when it was made in the seventies, with orange peel paint finish
and gaps that look normal, but no where near perfect.
Regards Mando.
#265 Bigfella237
Posted 15 August 2021 - 06:54 PM
If you could find and fit a fan guard then you'd only need 4mm spacers and you could paint 'em black and put 'em between the radiator support and the fan guard... In other words, you'd be lucky to even tell they were there!
#266 jeffblanco
jeffblanco
  • 388 posts
  • Name:Mando
Posted 16 August 2021 - 01:08 PM
I would like to install a fan guard Andrew, I really like how they look.
My problem is the fan guard would not look right due to the twin thermos against the radiator.
The spacers I had made are not my first choice,
but when you look from the front of the car you can hardly notice them.
Regards Mando.
#267 Heath
  • 18,393 posts
Posted 16 August 2021 - 01:24 PM
The spacers look fine, I wouldn't fret any further about it if you can get everything to bolt up and gap up nice with them, just leave it I reckon.
#268 hanra
  • 10,975 posts
Posted 16 August 2021 - 01:36 PM
So with the spacers fitted, does the bonnet still not latch down?
#269 jeffblanco
jeffblanco
  • 388 posts
  • Name:Mando
Posted 16 August 2021 - 03:57 PM
Brad,
with the spacers installed, the bonnet shuts beautifully.
Regards Mando.
#270 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 16 August 2021 - 04:37 PM
Not even drill some more holes to lighten them heath?
early Holden nut
#271 hanra
  • 10,975 posts
Posted 16 August 2021 - 07:29 PM
Brad,
Regards Mando.
Nice. Just leave it as is. Looks fine as is. Or fit a fan guard with smaller spacers.
#272 Hatchback13
Hatchback13
  • 181 posts
  • Car:1976 SS hatchback mint julep
Posted 17 August 2021 - 06:57 AM
Looks great to me, I do agree with Clay I recon Heath would do some drillium, engineer a double fan guard also with drillium and some technical fandangleism.
Haha 😂
By the way I noticed street machine got onto to you Heath everyone looking at your fine work.
Great work Marty can’t wait to see this thing lighting up the Adelaide streets. Cheers.
#273 Heath
  • 18,393 posts
Posted 17 August 2021 - 10:28 AM
lol, of course.
#274 Joe
Joe
  • 25 posts
  • Name:Joe
  • Car:LX Torana
Posted 28 August 2021 - 11:11 PM
HI Jeff,
What brand of the sway bar you're using for the rear and front?
Cheers,
Joe
#275 jeffblanco
jeffblanco
  • 388 posts
  • Name:Mando
Posted 29 August 2021 - 04:54 PM
Hi Joe,
I'm fairly sure they were K-Mac.
I made new brackets for the front.
The welding and painting weren't the best, and I had the bars powder coated.
Regards Mando.
