LX Hatch Complete Restoration
475 replies to this topic
#26 myss427
myss427
  • 1,636 posts
Posted 04 April 2019 - 08:14 AM
One thing to watch with the extractors, fuel injection does not go well with slip on collectors, I had major issues with overly rich readings because of very slight air leaks with the slip on collectors. Fixed the problem by welding them on.
#27 jeffblanco
jeffblanco
  • 387 posts
  • Name:Mando
Posted 04 April 2019 - 02:04 PM
Nice', the crossmember came from Dellows in Sydney. It wasn't that much dearer than the normal steel one.
myss 427, someone else pointed this out to me in an earlier post. Checked with my tuner and sure enough I'm screwed.
I've solved the problem of the O2 sensors being in the wrong place but I'm still working on the slip on collector problem.
As I said earlier, you would think someone who only builds extractors and exhaust would have known this like the back of his hand.
Regards Mando.
Edited by jeffblanco, 04 April 2019 - 02:05 PM.
#28 myss427
myss427
  • 1,636 posts
Posted 04 April 2019 - 02:39 PM
Just get him to weld them on no biggy, by the looks of them, he's no too bad at welding.
#29 Heath
  • 18,393 posts
Posted 14 April 2019 - 10:49 PM
Jesus.
Plenty of gear here.
#30 jeffblanco
jeffblanco
  • 387 posts
  • Name:Mando
Posted 22 April 2019 - 05:55 PM
Finished the brake lines. The only one left is the one that goes across the diff.
Attached File  DSCN0341.jpg   135.82K   30 downloads
Attached File  IMG_0105.jpg   140.59K   28 downloads
Attached File  IMG_0107.jpg   162.2K   32 downloads
Attached File  DSCN0344.jpg   184.51K   28 downloads
Attached File  DSCN0345 (1).jpg   126.67K   31 downloads
Attached File  DSCN0340 (1).jpg   124.83K   27 downloads
Regards Mando.
#31 jeffblanco
jeffblanco
  • 387 posts
  • Name:Mando
Posted 22 April 2019 - 06:18 PM
Finished the brackets for the sway bar links.
Attached File  IMG_0111 (1).jpg   135.12K   30 downloads
Attached File  IMG_0112.jpg   159K   27 downloads
Attached File  DSCN0337 (1).jpg   117.35K   25 downloads
Attached File  DSCN0339 (1).jpg   142.38K   25 downloads
Attached File  DSCN0337 (1).jpg   117.35K   22 downloads
Attached File  DSCN0343.jpg   147.37K   23 downloads
Attached File  DSCN0347 (1).jpg   138.09K   21 downloads
Got the condenser in and all the hard lines made.
Attached File  DSCN0349 (1).jpg   211.18K   25 downloads
Attached File  DSCN0351 (1).jpg   163.17K   20 downloads
Attached File  DSCN0348 (1).jpg   187.4K   22 downloads
Attached File  DSCN0350 (1).jpg   165.29K   21 downloads
Regards Mando
Edited by jeffblanco, 22 April 2019 - 06:20 PM.
#32 HDT166
HDT166
  • 115 posts
  • Name:Aaron
  • Car:Lx 2 door, VC HDT
Posted 04 May 2019 - 11:21 AM
Your Hotwire s look near on perfect ! Are you running standard length diff ? What sort of back spacing did you use ?
#33 jeffblanco
jeffblanco
  • 387 posts
  • Name:Mando
Posted 05 May 2019 - 08:02 AM
I'm not sure if this answers your question, but the first thing I did was buy the rims 10x17's and 8x17's and asked for as much dish as possible to look like the hot-wires you would see back in the day without going crazy.
Then I sat them under the car where I thought they should sit, and measured from rim to rim.
Rodtech in Adelaide did the rest with the diff.
Regards Mando.
#34 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 05 May 2019 - 10:30 AM
Hi Mando,
I see you are getting ahead with brake lines etc. under the car.
are you going to fit any chassis strengthening? I am not an expert but believe it adds a lot to the cars rigidity which is needed when you add HP. might be worth considering, I used a CRS chassis kit and had to make my brake lines fit around it.
there are other ways to do it by joining the box section chassis tubes under the car, depends how much fabrication you want to do. Rod Tech would probably be able to help with advice
Love the car your building and great fast progress
Cheers, Tom
#35 jeffblanco
jeffblanco
  • 387 posts
  • Name:Mando
Posted 05 May 2019 - 08:45 PM
Tom, Tom, Tom, I was afraid someone here was going to ask THAT question.
I have been avoiding looking at the problem hoping it would go away and I would have to do anything.
I will do a little homework tomorrow to see what can be done without going for the full chassis kit.
Do you have any pictures of what was done to your car?
Regards Mando.
#36 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 05 May 2019 - 09:09 PM
Sorry to be the one to ask,
Might also be worth asking your certifying engineer if he wants something fitted.
I used the kit below, it does have cut outs for brake and fuel lines, I did have to modify mine a bit for front wheel clearance.
https://www.rodshop....hassis-kit.html
Hopefully the link below is my modification for the front wheel clearance
http://www.gmh-toran...read/?p=1026086
And this one is for the cable
http://www.gmh-toran...read/?p=1001198
#37 jeffblanco
jeffblanco
  • 387 posts
  • Name:Mando
Posted 06 May 2019 - 12:16 PM
Your pictures help a lot.
Does the Rod Shop kit affect any part of the stabilising arms that come of the K-Frame?
I noticed a switch on your air/con receiver. When I bought mine I got a Trinary switch supplied, but I've seen Binary switches as when.
Do you know the difference?
Regards Mando.
#38 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 06 May 2019 - 10:05 PM
The rod shop kit fwd attachment point is the aft end of the k frame arms, I think that is the bit your talking about. Doesn't really affect them too much, I did have some clearance issues where I trimmed the corner of the box section
That bit is sometimes referred to as the outriggers
My air con switch is binary. It is open circuit when pressure in the system is either too low or too high.
I think trinary is pretty much the same with an option for it to also activate a fan for the condenser
My fans run from the ECM so I don't need the trinary
#39 jeffblanco
jeffblanco
  • 387 posts
  • Name:Mando
Posted 06 May 2019 - 10:20 PM
Thanks for that.
Regards Mando.
#40 jeffblanco
jeffblanco
  • 387 posts
  • Name:Mando
Posted 12 June 2019 - 10:06 PM
Hi Guy's,
can anyone let me know what the threaded bolt through the firewall and
the hole above it with black paint around it is for?
Attached File  DSCN0411.jpg   162.63K   19 downloads
Attached File  DSCN0412.jpg   118.91K   16 downloads
Regards Mando.
Edited by jeffblanco, 12 June 2019 - 10:11 PM.
#41 hanra
  • 10,973 posts
Posted 12 June 2019 - 10:16 PM
Clutch cable.
#42 jeffblanco
jeffblanco
  • 387 posts
  • Name:Mando
Posted 12 June 2019 - 10:59 PM
Thanks Brad,
would anyone be able to post a picture of what this setup looks like?
Regards Mando.
#43 jeffblanco
jeffblanco
  • 387 posts
  • Name:Mando
Posted 12 June 2019 - 11:13 PM
Attached File  IMG_0127.jpg   151.67K   18 downloads
Got some parts back from the painter so I started putting things together.
I think I'm jumping the gun since they haven't even started stripping the paint from the body yet.
Regards Mando.
#44 hanra
  • 10,973 posts
Posted 12 June 2019 - 11:33 PM
#45 hanra
  • 10,973 posts
Posted 12 June 2019 - 11:37 PM
https://1drv.ms/b/s!...jX6yg20Y7KUwAtJ
#46 Ice
  • 15,201 posts
Posted 13 June 2019 - 12:33 AM
Wow those fans look cool any info on them Mando
#47 Bigfella237
Posted 13 June 2019 - 02:12 AM
Only V8 manuals had the hole bored for the cable (between the stud and the threaded hole) during "drilling operations" very early on the production line.
6 cylinders manuals had the rat trap coming through the steering column fixing plate; and of course autos had no holes at all.
#48 jeffblanco
jeffblanco
  • 387 posts
  • Name:Mando
Posted 13 June 2019 - 02:58 PM
Thanks for all your'e help guy's.
Brad, the Manuel  will help me a lot since I bought my car completely in pieces. Just what I need.
Andrew, from what your'e telling me my car started life as an auto.
Gene, the fans come from Entropy Radiators in Illinois and the radiator from DeWitts Radiators in Michigan.
I made the shroud to fit the fans to the radiator.
Regards Mando.
#49 Bigfella237
Posted 13 June 2019 - 07:00 PM
Or it wasn't a V8? Or someone's replaced that panel? (although that seems unlikely)
Do you have the Compliance, VIN and Build Plates off that shell?
#50 jeffblanco
jeffblanco
  • 387 posts
  • Name:Mando
Posted 13 June 2019 - 10:16 PM
Andrew,
the panel looks original even though someone has welded up the heater holes, but I think your'e right the car started life as a six.
Iv'e got the plates put away, so I'll see if I can post a picture.
Regards mando.
