Rear interior light Lx Hatchback
8 replies to this topic
#1 _Hilta_
_Hilta_
Posted 12 March 2019 - 12:24 PM
Hi, anyone got some pics of the rear courtesy light in back pillar? Just trying to work ou if there is a switch similar to the ones on the doors that goes on the back hatch so when you open hatch light comes on? Thanks in advance
#2 Cook
Cook
  • 1,527 posts
Posted 12 March 2019 - 01:50 PM
Hi Mark.  I can get you a pic but not today, but light isn't in the car, it's still attached to the trim.  I'm in the process of getting my car rewired and pretty sure the auto elec said they were the same as the roof light with button mechanism when the hatch is opened.  But I'm not exactly sure where the button is located.  I will know further next week if that helps.
Mark, do you have a parts catalogue.  I just checked it and it is in the wiring harness section.  Button switch locates at the hole on the drivers side rear lower corner. Cheers Ron
Edited by Cook, 12 March 2019 - 01:55 PM.
#3 Bigfella237
Posted 12 March 2019 - 02:56 PM
You can see the switch in this picture...
#4 limo
limo
  • 2,673 posts
Posted 12 March 2019 - 04:40 PM
I believe the SS had 2, one each side
but hijacking thread
there's a vent of some sort in the pic
my car has open holes there and thought they were speakers
any one got a better pic?
#5 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 12 March 2019 - 04:57 PM
SSs had 1 like all other hatches.
#6 Cook
Cook
  • 1,527 posts
Posted 12 March 2019 - 08:55 PM
Here's a pic of mine.  There is the same hole on the passenger side. I know there is only one light in my trims (driver side) and I have a suspicion the other side has/had a speaker in it but don't know if that is original.  Cheers Ron
#7 Bigfella237
Posted 12 March 2019 - 09:29 PM
According to the parts catalog the rear compartment lamp was standard on all 8VC & 8VD LX models, and as there were no base model hatches, that should mean ALL hatches came with a lamp in the quarter trim?
RPO "U80 - REAR SEAT SPEAKER" added a single rear speaker *I think* to the quarter trim on the opposite side. If you can find the tag on your Body Wiring Harness you will know what your particular vehicle left the factory with, there were four different harnesses:
p/n 9940929 - HARNESS ASSEMBLY - Body wiring - UG,UH,VB Exc/Rear Comp. Lamp or Rear Speaker
p/n 9940930 - HARNESS ASSEMBLY - Body wiring - All models w/Rear Comp. Lamp only
p/n 9940927 - HARNESS ASSEMBLY - Body wiring - All models w/Rear Seat Speaker only
p/n 9940928 - HARNESS ASSEMBLY - Body wiring - All models w/Rear Comp. Lamp & Rear Speaker
Note that the above is only for LX, the LH models also made allowance for a Power Antenna (RPO "U75 - ANTENNA - POWER - REAR") mounted in the rear quarter panel but that option was dropped for the LX.
#8 TORLX8
TORLX8
  • 586 posts
  • Name:Campbell
Posted 13 March 2019 - 03:38 AM
Yes, only one courtesy light in SS, on driver's side.c52f666c72345d8a2d92652a51295bfd.jpg
Sent from my Moto G (5) using Tapatalk
#9 Bigfella237
Posted 13 March 2019 - 05:59 AM
It was quite a common mod back in the day to fit a second lamp on the other side, I have also seen hatches with two switches fitted...
HOLDEN-LX-TORANA-HATCH-SS-CLONE-TUFF-STR
...but I'm not sure why you would, except maybe just to fill the hole?
