Bad steering wheel vibration
Posted 19 March 2019 - 04:50 PM
I've uploaded some videos of me moving the top and bottom steering shaft. Does this look normal or could the bearings need replacing?
Posted 19 March 2019 - 05:38 PM
Sounds like a balance problem. Possibly a warped disk or bent rim. 1st check is wheel balance.
Posted 19 March 2019 - 05:55 PM
I can't see those videos for some reason but it could be a heap of things.
I will assume that since the tyres are new there are no delamination problems and the wheels were balanced after the tyres were fitted?
A lot of cars were "on-car" balanced from the factory, the thing with that is, if there was an imbalance in the disc rotor it was countered with wheel weights as the whole assembly was balanced as a unit, which is all well 'n good but tyre shops typically balance replacement tyres off the car, meaning that the wheel is now balanced again but the disc rotor isn't any more.
It could also be wear in any of the suspension and/or steering components, if the coupling mentioned above was buggered then the other bushes and joints can't be far behind? And the nylon steering rack bushes were notoriously bad in Toranas, they go hard over time and simply disintegrate. Also how good / well adjusted are the wheel bearings?
You will likely find it's a combination of things, a little balance issue combined with a little slop in the suspension combined with a bad wheel alignment and there's your vibration.
Posted 19 March 2019 - 07:05 PM
Posted 19 March 2019 - 08:58 PM
Does the vibration disappear when you are changing direction at speed?
Posted 19 March 2019 - 09:13 PM
Posted 19 March 2019 - 10:55 PM
While those bearings as showing the usual wear, dont believe its the issue.
You need to look at discs/ bearings, rims, bushes , linkages, steering rack. etc..
Posted 22 March 2019 - 12:20 PM
Posted 22 March 2019 - 03:40 PM
Posted 22 March 2019 - 04:45 PM
Not yet thanks for the suggestionHave you checked the rack end bush?
Posted 29 July 2021 - 01:09 PM
I found this crack in the lower control arm wishbone. Would this be the cause of steering wheel vibration?
Posted 29 July 2021 - 01:29 PM
I'd say that's more of a symptom than a cause?
But it definitely needs to be fixed either way.
Also, I know that welding isn't allowed on any steering components, but I'm not sure if that extends to wishbones? If it was me I think I'd be looking for a replacement LCA as it all needs to come apart anyway.
Posted 29 July 2021 - 09:06 PM
Posted 30 July 2021 - 01:03 AM
Its been a few years , with all those vibrations, have your tyres shown any odd signs of wear?
Posted 30 July 2021 - 06:56 AM
A control arm is a suspension component, not a steering component.
Still needs to rectified.
Posted 30 July 2021 - 10:04 PM
Nope... :(
I've ordered new coil over shocks from the rod shop, control arm bushings and ball joints. When all the new parts arrive in a few months i'll fix it all up and report back.
Posted 31 July 2021 - 07:35 PM
I know its a old thread but did you fix the steering column ? In your original video the shaft looks collapsed and not seating on the bearing properly .
Posted 04 January 2023 - 10:48 PM
Yeah I fixed the problem! I put a new upper bearing and converted the lower bearing to a real bearing. The steering column is dead smooth now and has zero play in it. Doesn't vibrate anymore.
