8 inch rim/tyre on front
Posted 21 August 2006 - 11:12 PM
if so wot tyre u running and do you know were the rim came from or the back spacing/off set.
Posted 22 August 2006 - 01:15 PM
Posted 22 August 2006 - 06:13 PM
the front is pretty low.
Edited by ALX76, 22 August 2006 - 06:15 PM.
Posted 22 August 2006 - 07:02 PM
Posted 22 August 2006 - 07:05 PM
Posted 22 August 2006 - 07:24 PM
Thankfully when you hit a bump at high speed the wheels aren't at full lock
Posted 22 August 2006 - 09:59 PM
the eights on the ive got has a 4inch dish and they do look sick.
Posted 22 August 2006 - 10:28 PM
Keep in mind how low Cohen's car is... will yours necessarily be as low or can you make it higher?
I'd just keep tyre width to a minimum, and don't make it super low; you should be safe... hopefully
I've got 225/65/R13s on my car (on the rear; nothing to do with clearance) and I doubt I'd want to go any skinnier on 8"s with that profile, I'm not sure whether different profile's would adversely affect the way a certain width of tyre behaves on a certain width of wheel, but I'd ring up your local tyre joint and talk to them about what profiles and widths would be alright if you're unsure.
Posted 22 August 2006 - 11:23 PM
Posted 23 August 2006 - 12:42 AM
205 is quoted min 6 inch and max 8 inch with around 7 to 7.5 being ideal. the wider the rim the less movement in the side wall. i would really go with 7 inch but have the 8's and as i said, they look sick esp with the 205/50/15 on them. the tread actually measures 8.5 as they are low profile and the tread only extends around the sidewall radiusabout 1/4 inch.
Posted 23 August 2006 - 08:41 AM
There's no option of you investing in some of those P76 discs? or do you have them already? Or are you running Torana stud pattern? Haven't even looked at the whole thread so excuse my ignorance. School time, see ya!
