Lc gtr 2k or Acrylic
29 replies to this topic
#26 bullitA9X
bullitA9X
  • 4,168 posts
Posted 25 May 2019 - 06:01 PM
Any of you guys used this debeer 2k highfill??
#27 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 27 May 2019 - 02:15 PM
I have before, it's not to bad, i just prefer the sikkens "personally" the main thing with high build is to get the repairs good enough, that you're just filling minor scratches or imperfections. It's only for that reason. It's not recommended to hi build twice & with a bare metal job, you shouldn't need to, sand any filler repairs out to 240 or 320 & feather to about 400 free cut, shoot a coat on the repairs first, give it a 20 minute flash time & high build the panels 3 times, with a 20 minute flash between each coat, put the first coat on just wet & the next 2 wet & you should be all good. DON'T put any form of paint on dry. If you have the time, I'd recommend leaving each epoxy, high build & paint on for a month, between stages, this will allow for the solvents to gas out fully, a proper cure & any shrinkage to Finnish, resulting in a better final result, you could cover up the surface loosely, after probably 3 - 5 days. I like to use clean flannelette sheets ect. I'd probably leave the top coat 2 weeks though.
#28 bullitA9X
bullitA9X
  • 4,168 posts
Posted 27 May 2019 - 04:23 PM
Cheers for the advice mate very much appreciated
#29 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 27 May 2019 - 05:47 PM
No problem mate, i always try to generalize in advice, so it can be used for numerous people, if it seems basic information ever, it's so it doesn't need to be repeated numerous times to different people. Nothing personal. I try to make things, simple, methodical & hopefully easy to follow. Gary.
#30 bullitA9X
bullitA9X
  • 4,168 posts
Posted 27 May 2019 - 08:15 PM
All good mate I love learning
