What suspension set up is this.
LH LX UC A9X
32 replies to this topic
#1 _Daryl34_
_Daryl34_
Posted 20 June 2019 - 06:52 PM
Images of what previous owner has done, and need to know what he’s used for working out power steering. Pretty shore disc brakes stud pattern are early commodore but don’t know what the stub axle is.
Attached File  3E1FA2E1-B599-4FB5-BEEE-B262ECB30CF5.jpeg   196.14K   17 downloadsAttached File  DE7CDD68-B520-4788-AB3E-9D24A4F7A490.jpeg   165.15K   18 downloadsAttached File  A9FD4B2D-FEC5-4479-8FED-199FC90AC9F0.jpeg   170.22K   19 downloads
#2 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 20 June 2019 - 07:20 PM
Power Steer? I don't think I see any, and what looks like a standard Torana rack.
Discs, don't look like early commodore? Early commodore has quite a deep disc, those look like they are a separate Hub and Hat, like say VT commodore, BUT, VT has a deeper hat.
I'm kind of thinking they are a falcon disc, BA perhaps? and maybe also a BA caliper, due to the mounting adapter plate, looks pretty much like a Hoppers Stoppers kit at a guess, and the standard disc spindles swapped side for side to put the caliper out the back.
Might need some more pics to be certain.
#3 Cook
Cook
  • 1,530 posts
Posted 20 June 2019 - 08:02 PM
I'm no expert but do have a Hoppers kit and looks like it.  Also they supply the braided hose with the kit like that and it is run behind the stub axle.  I also think I have read that they do sometimes recommend/supply the BA caliper but not 100% sure.  Cheers Ron
#4 dattoman
  • 16,487 posts
Posted 20 June 2019 - 09:41 PM
I think he wants to convert to P/Steer
In which case... get a Lenny rack
And yes looks like a Hoppers kit
Easy way to tell what caliper (looks like AU2 to me) is to check the pad shape
DB1375 for AU2/3. 169mm long
DB1473 for BA... 190mm long
https://www.bendix.com.au/catalogue
And disc diam 287mm for AU2 , 298mm BA
#5 Bigfella237
Posted 20 June 2019 - 11:09 PM
The main thing you'll need to confirm for a power steering conversion is what stub axles and steering arms have been fitted.
There should be part numbers cast into them that will identify what you have. Steering arms need to match the spindles and may need to be reamed to accept a conversion tie rod end.
#6 _Daryl34_
_Daryl34_
Posted 21 June 2019 - 02:45 AM
Thanks for the comments, Well didn’t even consider hopper stopper, looks like I’m going to have to do a uc and hq conversion with Wilwood brakes all round. Does any one know where to get all these parts from?
#7 Bigfella237
Posted 21 June 2019 - 05:01 AM
Just be careful when selecting Wilwood calipers.
Australian Design Rules require caliper pistons to have additional dust seals while the American design rules apparently don't, so with Wilwood being an American brand there are only a few model calipers that actually comply with Aussie rules.
I have a list somewhere but haven't updated it for 12 months or so, there may well be more of a range available now?
#8 axistr
axistr
  • 1,212 posts
Posted 21 June 2019 - 07:31 AM
Hi Daryl, no reason you can't run those Brakes. I thought hoppers kits still mounted on the front of the axle. Just check you have good clearance with your brake callipers on full lock. With power steering you get a bit more lock over the standard manual rack. It's hard to identify what stub axles you have from the photos but I am leaning towards HQ. Part numbers will help you easily identify or with a front hub removed its easy to see if it LH,UC or A9X/HQ stubs. You really need to get part numbers for the steering arms to check what you have. Unless you have all the different model arms side by side you won't pick the difference.
#9 Bigfella237
Posted 21 June 2019 - 08:28 AM
Also it looks like those Lower Control Arms are from a UC Torana (earlier models don't have the steering stops).
I can't see the Upper Arms well enough in those photos to tell whether they're UC or not, if you can take a picture from the top it will be easy to tell as the ball joint is set further rearward compared to earlier models (plus they're stamped left & right).
The K-member appears to be an earlier version with the rubber-bush-mounted rack, but again, it's hard to tell without better photos. I notice the glovebox photo in your build thread has an RTS badge so assuming it's original then you possibly have an LX post-RTS K-member?
Edited by Bigfella237, 21 June 2019 - 08:30 AM.
#10 _Daryl34_
_Daryl34_
Posted 26 June 2019 - 06:33 PM
More pics from different angles.
Attached File  94B32324-CD5A-4D54-87D4-DBB4ADBAEB8A.jpeg   148.9K   7 downloads
Attached File  9BEAF539-E35A-4C5B-9C80-5B3CA73AA143.jpeg   99.42K   5 downloads
#11 Bigfella237
Posted 26 June 2019 - 10:00 PM
Those are just the standard LH/LX upper control arms.
Seems weird that the guy has fitted LCAs from a UC but not the UCAs (which are the most desirable).
I still can't read the casting numbers on the stub axles, where you've scratched is the correct spot but I can't make it out, it should have "HOLDEN" followed by some numbers...?
The steering arms you also need the casting numbers from, there's a few different arms but unless you're looking at them side-by-side you'd be hard pressed to tell the difference...
#12 _Daryl34_
_Daryl34_
Posted 26 June 2019 - 10:26 PM
Yer i cant make out the numbers either, but i can see Holden, so what casting numbers am i looking for in regards to stub axle part, is HQ the way to go, and would i better of getting the whole UC k frame and LCA & UCA or just replace the UCA it says on the dash its RTS but i cant be sure if its the original dash, the car was built 09/76 if that helps, and i think i know where i can get A9X steering arm copies
#13 Bigfella237
Posted 26 June 2019 - 11:07 PM
If the car started life as a Sunbird then a Sept '76 build could be RTS (the changeover was in 09/76), but non-Sunbird models didn't get RTS until sometime in Feb '77
Except that the engine mounting points welded to the K-frame were different for the Opel-engined Sunbird, so unless you can see where they've been re-welded, either the K-frame has been replaced or the dash has (or both).
It's not a UC K-frame because the UCA pivots are too low and it's missing the upper shock mount washers. And seeing how low the UCA pivots are it could be a late LX RTS K-member, but that's just a guess?
Unfortunately Sept '76 was the same time that the stub axles changed with the introduction of the alloy calipers, the later LX Torana stub axles had "HOLDEN 42926" (RH) and "HOLDEN 42927" (LH) cast into them, and the UC stub axles had "HOLDEN 163P" & "HOLDEN 164P". But considering it could also have HQ/J/X/Z stub axles there's half-a-dozen other variations to choose from too!
And of course the steering arms need to match everything else, considering you don't have the A9X / UC UCAs you can't run the Harrop repro arms as they'll be the wrong height.
Clear as mud?!
#14 _Daryl34_
_Daryl34_
Posted 27 June 2019 - 12:28 AM
Cheers. Never was a sunbird that I am sure of as it started out as a 4.2ltr, the stub axle are Definitely not lx then because there is to many numbers and letters, so most likely there UC stub axles, and possibly HQ, SO is it best to source the UC, UCA and HQ stub axle so I can use the Harrop repro arms, and what are the handling changes if I run UC UCA on a non UC K frame, also as I’m going to run bigger brakes most likely willwoods unless you know of other options I will need to use HQ STUBS to fit the brake kits. I’m open to suggestions.
#15 Bigfella237
Posted 27 June 2019 - 07:16 AM
There are many threads here already on the subject but very briefly...
Operationally, the only difference between K-members are:
 - 4 cylinder Opel engine mounts are different to all the Holden engines (including the Starfire 4)
 - LH & LX have a slight difference in the steering rack mounting than UC
 - the position (height) of the UCA pivot bolts / studs varies from pre-RTS, to LX RTS, to UC RTS
Note that I'm not including genuine L34 & A9X K-members here, these have some specific one-off variations of the above.
There are pro's & cons to each type of stub axle. The A9X used the strongest version of any, which was a HX 1-tonner variant, but I've never seen a stub axle from any model break anyway and it does add considerably to the unsprung weight (which is a bad thing).
The HQ/J/X/Z stub axles have the axle spindle set roughly 1 inch higher than the Torana models. So the car will be 1" lower, but needs to have 1" less suspension travel (hence the extended bump stops).
The Torana stub axle has a "Steering Axis Inclination" (SAI) of 9° whereas the HQ/J/X/Z stub axles have a SAI of 7°. This will affect the camber adjustment with the Holden spindle requiring roughly ½" less shim thickness at the UCA pivot. If you don't already have ½" of packing in there then you may struggle with excessive negative camber.
SAI also has an effect on Scrub Radius (SR), the lower SAI of the Holden stubs will push the SR out (more positive SR), and considering how much "dish" Torana folk like on their rims already, that's a bad thing. A larger scrub radius means the wheels swing in a bigger arc with steering input, this will transfer more "feel-for-the-road" to the driver but make the steering heavier and more resistant to change of direction.
Also the greater the SR, the more grip is lost as the steering angle increases. A larger SR can also give problems with tyre-to-body clearance, again because the tyre is steering through a larger arc. And the larger the SR, the less static positive caster you can dial in because the combination of the two will have a 'jacking effect' as the steering is turned
This is really just the tip of the iceberg, we haven't even mentioned camber and caster gain, which is also affected by SAI but I did say "very briefly" back at the start and it's such a complicated subject!
Basically, keep the K-member you have, look for some UCAs from a UC Torana (they are marked "L" & "R" so make sure you get a pair), and if it was me I'd keep the Torana stub axles (assuming you have UC stubs and steering arms) and save the (not inconsequential) money that Harrop charge for repro steering arms. You're gonna need to make some custom caliper brackets for the Wilwood gear anyway so it's the same either way and you're better off with the lower SR, especially if you're planning on fitting flares and wide rims!
Edited by Bigfella237, 27 June 2019 - 07:21 AM.
#16 _Lazarus_
_Lazarus_
Posted 27 June 2019 - 10:51 AM
If they are Torana stubs then why not keep the set up you've got ? The stud pattern is more likely to be HQ than Commodore because of wheel offsets. The difference is tiny but important.
Or if you want a different stud pattern find out who did the kit and buy some more rotors.
#17 _Daryl34_
_Daryl34_
Posted 28 June 2019 - 12:46 AM
Thanks guys, i agree, I’m going to find some UC UCA and stubs, I’m pretty sure it’s commodore stud pattern, I’ve tried both types of wheels and the commodore rims fit better, I’ve tried to find measurements for both using vernier across multiple directions Burt have had no luck. I really would like to know for certain what they are.
#18 Bigfella237
Posted 28 June 2019 - 06:42 AM
Measure any two wheel studs and refer to the following diagram...
These measurements are centre-to-centre but that's really easy to do with a pair of vernier calipers, just measure from the outside of one stud to the outside of another, then measure the thickness of one stud and subtract from your first measurement.
It's probably worth repeating on different studs / hubs just to make sure the hubs / axles were drilled accurately and none of the studs is in cockeyed.
Edited by Bigfella237, 28 June 2019 - 06:45 AM.
#19 Bigfella237
Posted 28 June 2019 - 07:11 AM
And just to clarify, UC Torana stub axles should have either "HOLDEN 163P" / "HOLDEN 164P" or "GM 163P" / "GM 164P" cast into them as mentioned above.
And UC steering arms should have "GM7248" / "GM7249" cast into them.
#20 _Daryl34_
_Daryl34_
Posted 28 June 2019 - 02:43 PM
Awesome info, cheers, definitely have UC stub axles had to repaint them and sand tops to see part number, i cant see a part number on steering arms, where are they normally located?
#21 Bigfella237
Posted 28 June 2019 - 03:03 PM
The number is on the outside face of the steering arm, you may need to remove the disc rotor to read it. You can just make it out in this photo...
Note that the lower of the three arms pictured (marked "A9X") is a Harrop reproduction item.
#22 _Daryl34_
_Daryl34_
Posted 28 June 2019 - 07:32 PM
So I recall some one suggested that the stub axles where on the wrong sides which places the brakes to the rear, will this affect handling and braking, also if I go the wilwood brakes should I then swap them to there correct side.
Attached File  814D8C34-D3EC-4E32-BC4B-CD288F079E25.jpeg   196.14K   4 downloads
#23 sgo90
sgo90
  • 17 posts
Posted 28 June 2019 - 08:54 PM
Hoppers suggest calipers go to the rear if clearance with the steering tie rod is a problem.
#24 Bigfella237
Posted 29 June 2019 - 07:02 AM
As far as I'm aware stub axles are symmetrical except for the caliper mounts, so swapping them shouldn't have any effect on geometry. Aside from that, I guess you could argue that calipers get more cooling at the front, but weight distribution-wise they're better on the back side so... six of one, half a dozen of the other.
The more important thing is to have caliper clearance through full suspension and/or steering travel. Finding a sweet spot where they clear both control arms and the K-member can be tricky. I'd suggest mocking everything up without the coil springs fitted so you can more easily test for caliper clearance under full compression and at full lock.
This would also be a good time to rough-out the ride height, wheel alignment and check for bump steer & camber / caster gain, as well as tyre to mudguard / flare / firewall clearance.
#25 axistr
axistr
  • 1,212 posts
Posted 29 June 2019 - 09:21 AM
Depending on the type of caliper used, but more often than not I have found placing the calipers to the rear will give you more clearance issues. The calipers generally hit the top control arms, so you will not get full steering lock without bending or cutting parts to gain the extra clearance needed. I defently don't like buggering around and cutting control arms to gain the extra clearance needed. I have seen many top control and steering arms buggered all for the sake of people saying I have got big ass brakes.
Also tagged with one or more of these keywords: LH, LX, UC, A9X
