Hi all. I've got a new water pump and it comes with a gasket and metal plate fixed before the impeller (as per photo) and a separate gasket. Therefore it would be installed as timing cover/gasket/plate/gasket/water pump. My question is, should/do I need to use gasket seal as well and if so where do I put it, given I can't get the first gasket or the metal plate off. Cheers Ron
Edited by Cook, 21 June 2019 - 11:29 AM.
