Hi all,
Posted 23 June 2019 - 10:29 PM
Hi all,
Posted 23 June 2019 - 11:42 PM
Posted 24 June 2019 - 12:07 AM
Posted 24 June 2019 - 08:38 AM
When you see what some people's projects start out like, your one looks pretty good. I can't believe there are still GTR's lying around in paddocks.
Posted 24 June 2019 - 09:13 AM
Posted 24 June 2019 - 01:14 PM
Wow, how the hell did those seats come out of that car?
If I drop my car of to your place could you make the interior look like that?
Regards Mando.
Posted 24 June 2019 - 03:47 PM
Posted 24 June 2019 - 11:04 PM
Posted 25 June 2019 - 09:09 AM
Posted 26 June 2019 - 10:30 PM
Well for those in Perth you'll know its been raining its nuts off for the last few days, so we've managed to start...and finish a job - the steering wheel.
It was broken and flapping in the breeze. M was looking at getting another one, but heh I'm not called the handbrake for nothing...Can't we just fix it I asked? So that's what he's done!
I'll let M explain the details...
IMG_7636.jpg 362.06K
37 downloads
Cut the top half off the metal ring, bottom half is molded into metal and very hard to remove.
IMG_7771.jpg 205.61K
34 downloads
Lift the metal up to level then grind a 1mm gap for weld penetration.
IMG_7772.jpg 412.15K
32 downloads
Grind weld back smooth.
IMG_7773.jpg 332.72K
33 downloads
Glue back together with Araldite.
IMG_7791.jpg 109.15K
35 downloads
Mask off edges and fill gap with black polyeurthane and smooth off.
IMG_7794.jpg 93.41K
35 downloads
Not perfect but good enough.
IMG_7833.jpg 191.9K
37 downloads
Finished wheel.
And hey, it's turned out good enough for me! Bless him.
Posted 26 June 2019 - 10:37 PM
Forgot to add, M has polished some of the trims and here's the pics of how he did it.
IMG_7553.jpg 171.57K
37 downloads
IMG_7655.jpg 177.43K
35 downloads
IMG_7866.jpg 328.67K
34 downloads
IMG_7874.jpg 343.78K
36 downloads
IMG_7877.jpg 248.67K
33 downloads
IMG_7878.jpg 92.06K
35 downloads
Sally, is there anything Marty can't fix?
Posted 26 June 2019 - 11:00 PM
Posted 28 June 2019 - 05:03 PM
Off to a flying start Sally
Posted 28 June 2019 - 05:38 PM
Posted 28 June 2019 - 09:17 PM
Posted 28 June 2019 - 09:34 PM
Hi Guys,
Sallys out tonight at an Enjo Party (maybe to clean car parts with)? so thought I'd sneak an update in.
Entered into unknown territory with my first guard removal, it's been a bit tricky due to the brass braising welds every where. The cars been pranged badly at some stage, had a few new parts fitted to the front end a long time ago. Then since then its been damaged again but I want to re-use the damaged guards. I did buy a set of unused GM guards and nose cone which I'm using as reference. Have started the paint stripping and sand blasting myself. After doing the LJ I swore I'd never do this again unless I had more room, well I don't have any but just a short memory. I remember sandblasting for days and what a mess! But after getting spooked by a high quote to blast the body I thought stuff it, here we go again. When they want about $3500 for the body and then you think of all the other bits that need blasting throughout the build I may has well buy new sandblasters again.
A couple of weeks ago I did a metal shaping course and spent a heap of money on tools and equipment, sort of kidding myself that they will pay for themselves if I make my own panels. Well, let me tell you, it's not that easy. I've decided to buy the important external panels and fabricate the hidden bits myself.
Tools so far purchased;
Sand blaster pot
Sandblaster cabinet
Metal shears
Hammer and dolly set
Shrinker/stretcher
Spot welder/dent puller
150mm offset vice.
IMG_7716.jpg 96.95K
31 downloads
IMG_7720.jpg 275.2K
32 downloads
IMG_7741.jpg 607.25K
28 downloads
IMG_7744.jpg 480.3K
33 downloads
more to come, just run out of image space.
Posted 28 June 2019 - 09:41 PM
Looks like a fun project Marty, I am sure it will end up as perfect as the last one. what brand and where did you get your spot welder dent puller from?
Posted 28 June 2019 - 09:46 PM
IMG_7676.jpg 425.67K
28 downloads
IMG_7677.jpg 189.58K
28 downloads
IMG_7678.jpg 161.49K
29 downloads
IMG_7680.jpg 126.58K
28 downloads
IMG_7735.jpg 245.04K
31 downloads
The front set of GM guards
IMG_7736.jpg 433.47K
30 downloads
The NOS Guard I'm trying to match.
IMG_7825.jpg 278.74K
32 downloads
Template made from good guard to check profile, still work to do here.
Feels great to be back restoring a GTR.
Marty
Posted 28 June 2019 - 09:51 PM
Well done with the seats. People pay good $'s to have them redone and not end up with them looking as good as that!
M has been brilliant with the wheel too- just goes to prove, nothing ventured, nothing gained. If you're missing the stainless trim ring that goes around the outside Brad Merrick has them. Will hide the outside join, not that it looks ugly anyway.
If you can spit and polish the rest of the car like the parts so far it's going to be the best survivor in history.
For my two bobs, I like red, especially if it proves to be the original color when you rub it back (polish it??), they're supposed to go faster and there's not that many of them.
Good luck with the project, I'm sure it's going to be a good read.
JPXU1
Posted 28 June 2019 - 10:00 PM
Well, while I was posting so were you M. Starting with the HEAVY cutting compound on the polishing job I see...haha
Posted 28 June 2019 - 10:14 PM
She's still not home so another update.
The sand blasting setup was in my trailer with some tarps to contain the mess. (catches about 85% of the sand)
IMG_7788.jpg 141.94K
31 downloads
And Shadow James this is the spot welder at work, got it of eBay for $385 with all the bits and slide hammer. So far very happy with it. It also has a shrinking tip which I think does the same job as an oxy. (heats up a small spot quickly).
IMG_7969.jpg 374K
30 downloads
IMG_7970.jpg 413.89K
29 downloads
IMG_7883.jpg 257.73K
28 downloads
IMG_7886.jpg 364.08K
30 downloads
IMG_7960.jpg 333.17K
30 downloads
Welcome to the forum Sal.
Nice work on the seats, they came up well.
At the last toranafest Marty was talking about this car being left as a survivor, is that still the plan?
I didn't see Gibo helping in any of photos, he must be getting a bit lazy in the cold weather.
JD
Hi James, this is the car I was talking about but it's not going to be a survivor, there's too much structural rust to do and the cars a bitza with no tags. Cheaper to do it right the first time.
Marty
Posted 01 July 2019 - 11:44 PM
Looks like the colour could cause a controversy. Rally Red, or not, or something else...
Anyway I have found that I can't leave M alone for one minute - he's like an out of control energizer bunny and is pulling my car apart at break neck speed. And it no longer looks like a Torana ooohhh I like these emojis
Well I did get to do a few tasks, but why is it that I feel I am getting all the 'girlie' jobs? Like cleaning parts in the kitchen sink (no not with my new Enjo glove), and baking the door handle springs. I still don't understand why I had to cook the springs, and it was a bit weird serving them up beside my beef casserole.
IMG_8030.jpg 300.45K
29 downloads
IMG_7973.jpg 277.15K
31 downloads
I'll stop my wingeing and pass the laptop over to M now...
Sal.
Those tasty looking springs are for the drivers side internal door opener. I did this little fix-up on the LJ and this time I've taken it to a new level. Firstly I purchased some correct spring wire, made them a little better and had Sally temper them in the oven. (kitchens not my domain). On the LJ I used stainless TIG wire and it worked but not as good as this.
IMG_7975.jpg 310.1K
28 downloads
Drilling out the spot welds.
IMG_7932.jpg 170.48K
28 downloads
Dissasembled with the remains of original spring.
IMG_7933.jpeg 210.92K
28 downloads
Bending the wire around an old spark plug tube.
IMG_7962.jpg 129.04K
26 downloads
This shows the TIG wire version, original broken spring and the new Marty spring.
IMG_7938.jpg 281.71K
26 downloads
Testing the new spring.
IMG_8012.jpg 95.87K
28 downloads
Welded together, greased and ready to pack away until needed.
I've also worked out it would easy to convert a spare passenger mecanism to a drivers side by bending up the stop tab and making another on the other side.
Marty
Posted 02 July 2019 - 01:06 AM
Posted 02 July 2019 - 06:10 PM
Holden Tech →
Electrical →
LC rear indicator screwsStarted by dacastle , 06 Apr 2024 ![]() |
General →
General Discussion →
What can you identify from stamped body number onlyStarted by 70 XU-1 , 21 Dec 2018 ![]() |
General →
Resto Rage HelpStarted by Rainman , 16 Sep 2017 ![]() |
Holden Tech →
General LH-LX-UC →
LH Torana rear windscreen SpecificationStarted by _Pjabrown_ , 06 Sep 2016 ![]() |
Holden Tech →
General LH-LX-UC →
Best paint to buyStarted by _toranaheath_ , 27 Oct 2015 ![]() |
