The Sally Report
LC GTR Restoration 1971 The Marty Report Girl Power
1003 replies to this topic
#501 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 28 February 2021 - 09:13 PM
Hi Marty, I have to make imitation spot welds sometimes at work, I’ve found using a bolt ground nice and flat on the threaded end and do it in the primer. About the second or third coat you put it in and twist a bit, it seams to work well for me. Cheers
Thanks Brad, good tip.
Decided to do some bogging panel work while the cars on the rotisserie. Much easier working in a comfortable position than lying on the ground when it's on the cradle. This front beaver has had a few patch panels welded in and will be a bit swampy.
Attached File  IMG_4140.jpeg   59.19K   24 downloads
Attached File  IMG_4141.jpeg   58.3K   21 downloads
Attached File  IMG_4158.jpeg   49.54K   24 downloads
Attached File  IMG_4159.jpeg   51.13K   19 downloads
Marty
#502 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 17 April 2021 - 10:36 PM
A small update after too many Birthdays, anniversary and Easter slowing progress.
The heater core has been on hold after quotes around $550 to recore. I managed to get hold of another 6 to go with my 3 and I decided to check them all myself to see what's really wrong.
Six more to test.
Attached File  IMG_4357.jpeg   106.88K   11 downloads
Setting up the water and air at 15psi for testing.
Attached File  IMG_4378.jpeg   82.44K   12 downloads
All 9 units had some sort of leak so I picked out the easiest to repair.
Attached File  IMG_4379.jpeg   85.22K   13 downloads
Set up my gas and solder ready to give this a go.
Attached File  IMG_4380.jpeg   94.55K   14 downloads
Dremeled out to clean area and soldered the hole.
Attached File  IMG_4381.jpeg   72.32K   11 downloads
Straightened up a pipe which caused a leak around pipe. Got the oxy out to braise copper and this is where it all went pear shaped.
Attached File  IMG_4384.jpeg   104.07K   12 downloads
Blew a hole in the tank and ended up with molten solder dripping out of unit.
Grabbed another unit and took it to a radiator shop for repair. They are reluctant to fix them due to the risk of leak and difficulty removing once fitted. Managed to source a new core and re-core it for $360. I'm finally happy and can proceed to finish off the heater box assembly.
New one on the left.
Attached File  IMG_4496.jpeg   95.31K   14 downloads
Marty
#503 claysummers
claysummers
  • 3,631 posts
  • Name:Clay
Posted 17 April 2021 - 11:03 PM
Good on you for having a go at it but yes. You will sleep better with the recore I’m sure.
#504 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 17 April 2021 - 11:26 PM
Working my way through the last few bits of rust repairs. This one i've been putting off due to it's a bit tricky.
The drip rail behind quarter window was in bad shape.
Attached File  IMG_7692.jpeg   65.43K   18 downloads
There are three layers here, drip rail, roof skin and sub frame. The frame was ok but a new skin had to be made.
Attached File  IMG_4364.jpeg   43.39K   15 downloads
Attached File  IMG_4365.jpeg   44.18K   14 downloads
Attached File  IMG_4366.jpeg   45.92K   13 downloads
You have to be very careful not to pull in the roof skin when welding, I learnt this from doing the LJ. Use spacers to hold and control movement.
Attached File  IMG_4367.jpeg   45.69K   14 downloads
Attached File  IMG_4368.jpeg   44.45K   13 downloads
Attached File  IMG_4421.jpeg   46.68K   13 downloads
Attached File  IMG_4422.jpeg   48.9K   14 downloads
Attached File  IMG_4430.jpeg   54.45K   12 downloads
Clean up the old drip rail and make a new section to replicate the old style. I had to crease it and shrink/stretch to get it to fit.
Attached File  IMG_4417.jpeg   65.55K   12 downloads
Attached File  IMG_4418.jpeg   62.7K   12 downloads
Attached File  IMG_4419.jpeg   91.71K   13 downloads
Attached File  IMG_4420.jpeg   83.79K   14 downloads
Attached File  IMG_4424.jpeg   70.51K   15 downloads
Attached File  IMG_4425.jpeg   64.4K   15 downloads
Attached File  IMG_4427.jpeg   77.33K   14 downloads
Attached File  IMG_4426.jpeg   59.12K   14 downloads
Attached File  IMG_4428.jpeg   80.4K   14 downloads
Attached File  IMG_4429.jpeg   76.33K   15 downloads
Attached File  IMG_4433.jpeg   53.75K   15 downloads
Attached File  IMG_4434.jpeg   51.42K   15 downloads
Attached File  IMG_4435.jpeg   50.24K   15 downloads
Marty
#505 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 18 April 2021 - 01:06 AM
I had to do the same thing on my lc gtr when I did it years ago.
As you would have found out no one makes a replacement section for it and the lead is a pain in the arse to get out so you can weld it in.
#506 Rockoz
Rockoz
  • 4,032 posts
  • Name:Rob
Posted 18 April 2021 - 11:35 AM
Glad you got a recore done.
Back many moons ago when I had a VB Commodore, the heater started leaking.
Was a huge job to get the old one out, it was one of the first items fitted to the dash area I reckon.
The whole lower dash had to come out.
Talked to the radiator guys back then.
They told me that the heater cores were still being made from the old 7 1/2 lb cores even in the 80s.
They replaced the core with a 15 lb one. Cost about the same as a new core from Holden at the time.
About 75 bucks.
The radiator guys reckoned they could be kept in business just from replacing the 7 1/2 lb cores on their own back then.
Rob
#507 Ice
  • 15,200 posts
Posted 18 April 2021 - 04:26 PM
I had my old GTR Torana heater recored years ago
when i picked it up the guy said don’t ever bring it back
pain in the arse to fix apparently
$75 i wasn’t complaining
#508 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 18 April 2021 - 04:52 PM
Awsome work Marty, Recore heater is the way, you made the right choice.
Mine was $330, earlier in the year. :)
#509 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 18 April 2021 - 08:00 PM
Yeah! the lead just blows out and spits and farts. Hard to tell where the lead is when you're an amateur.
About 75 bucks.
Rob
It's one of those things you only want to do once.
Did he fix it or recore it?  Recore isn't hard for them.
It's all still too much but it's got to be right. I'm now going to get another 4 recored.
Marty
#510 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 18 April 2021 - 08:14 PM
Another section repaired, this was a dented damaged bit from memory.
Had some sill section left over so cut that to suit. Noticed as always it's not quite the same profile so photos show the modifications required to fit best.
Attached File  IMG_4221.jpeg   52.73K   16 downloads
Attached File  IMG_4222.jpeg   29.23K   17 downloads
Attached File  IMG_4223.jpeg   30.86K   17 downloads
Attached File  IMG_4228.jpeg   35.35K   18 downloads
Attached File  IMG_4270.jpeg   33.89K   19 downloads
Attached File  IMG_4271.jpeg   33.95K   17 downloads
Attached File  IMG_4272.jpeg   34.12K   19 downloads
Attached File  IMG_4273.jpeg   33.57K   18 downloads
Attached File  IMG_4431.jpeg   32.98K   19 downloads
Attached File  IMG_4436.jpeg   42.06K   24 downloads
Marty
#511 Heath
  • 18,385 posts
Posted 21 April 2021 - 09:12 AM
Classy work as always, Marty.
#512 Ice
  • 15,200 posts
Posted 21 April 2021 - 04:14 PM
You’re getting real good at this welding caper
#513 RynoByrnzy
RynoByrnzy
  • 7 posts
  • Name:ryan byrne
  • Car:lj
Posted 04 May 2021 - 09:19 PM
Loving all your info Marty, great write up. Im looking down the barrel of a long road ahead but exited at the same time. Giving me great enthusiasm.
I noticed you had a dremel, for the small horizontal cuts such as the one at the bottom of the rear window you did, and other awkward spots have you tried the grinding disc on the dremmel. I burn through them quick, so i cut lots of small 25mm discs from larger worn angle grinding disc with tin snips works well for me. Gets it the real tight spots the grinder cant.
#514 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 17 May 2021 - 10:07 PM
Hi Ryno, Had a quick look at your project and it looks pretty solid. (not to rusty)
It can be very rewarding when things work out. Just do as much as you can yourself or you'll waste a lot of money.
Dremel are rarely used by me. If it's in a picture it's normally the second last thing I tried then chuck it to the side. Dremels are only good for jewellers or model makers.
Marty
#515 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 06 June 2021 - 09:45 PM
After a four week holiday to Exmouth I'm gradually getting back into the LC.
Finished off the rear screen rust repair. Used some brass blocks as heat sinks and unscrewed every second tek screw to plug weld my way along.
Attached File  IMG_5082.jpeg   135.59K   18 downloads
Attached File  IMG_5083.jpeg   88.65K   17 downloads
Attached File  IMG_5084.jpeg   99.21K   18 downloads
Attached File  IMG_5085.jpeg   91.59K   17 downloads
Attached File  IMG_5086.jpeg   139.57K   17 downloads
Attached File  IMG_5087.jpeg   96.71K   17 downloads
Attached File  IMG_5088.jpeg   91.08K   17 downloads
Marty
#516 Shiney005
  • 9,587 posts
  • Car:Toyota Mirai
Posted 07 June 2021 - 03:45 PM
Bring a few Coral Trout home with you Marty?
#517 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 07 June 2021 - 05:44 PM
Hi Laurie, my high light with the fishing was getting 5 Spangled Emperor of the rocks, biggest 58cm. Kept three with the biggest being on the last cast and left them biting. I'm not a fan of over fishing a spot.
Attached File  IMG_4884.jpeg   445.1K   16 downloads
I've had another round of getting paint off the bonnet. It's been a real struggle with paint stripper and the nylon pads struggling to have little effect. A new pad is good for about two minutes then it gums up with this paint. Anyway, almost there and gave it a KBS Rust Blast to keep in good shape until etching. I'll then buzz it with the sander for final prep.
Attached File  IMG_5093.jpeg   172.87K   19 downloads
Attached File  IMG_5094.jpeg   149.01K   16 downloads
Attached File  IMG_5095.jpeg   254.46K   16 downloads
Attached File  IMG_5096.jpeg   193.03K   16 downloads
Attached File  IMG_5097.jpeg   212.04K   16 downloads
Attached File  IMG_5100.jpeg   175.15K   15 downloads
Marty
#518 claysummers
claysummers
  • 3,631 posts
  • Name:Clay
Posted 08 June 2021 - 12:11 AM
Hi Marty,
Don by know if this helps but I find the plastic discs work best at low speed about 1.5 - 2 on my cheap polisher. Any faster the paint melts as does the disc. Lucky perserverence is your forte mate.
Cheers ,
Clay
early Holden nut
#519 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 09 June 2021 - 06:31 PM
Hi Marty,
Cheers ,
Clay
early Holden nut
Hi Clay, I'll try that one day, think I've finished all the disc stripping. Disc worked fine on certain paints but not the original red oxide and this black undercoat.
I've drilled the holes for sill plates and hole blanks in floor.
Attached File  IMG_5098.jpeg   102K   16 downloads
Attached File  IMG_5099.jpeg   128.1K   15 downloads
Ran out of wire so also decided it was time to change the lining in my welding gun.
Attached File  IMG_5133.jpeg   189.4K   16 downloads
Had an extra hole near stainless trim end, got the trims out to check which one had to be welded up.
Attached File  IMG_5137.jpeg   118.9K   14 downloads
Attached File  IMG_5138.jpeg   76.81K   14 downloads
Attached File  IMG_5139.jpeg   78.08K   16 downloads
Attached File  IMG_5140.jpeg   75.68K   16 downloads
Marty
#520 claysummers
claysummers
  • 3,631 posts
  • Name:Clay
Posted 09 June 2021 - 11:27 PM
Very thorough. Agree the red lead is virtually indestructible. Unless using stripper i wouldn't bother removing it.
early Holden nut
#521 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 12 June 2021 - 10:29 AM
I've finally finished welding the body shell, a much bigger effort than expected.
Treated the welded areas with Rust Blast before rinsing off. A little tip for those that air dry stuff, get a cheap air blower, they're much better for drying large areas rather than using compressed air.
Then the next day I had to warm the room, KBS paint and body-shell before applying the rust seal.
This is what rotisserie were invented for, turning and heating/cooking.
Attached File  IMG_5146.jpeg   101.97K   15 downloads
Attached File  IMG_5147.jpeg   100.39K   15 downloads
Attached File  IMG_5148.jpeg   99.06K   15 downloads
Attached File  IMG_5149.jpeg   81.61K   15 downloads
Attached File  IMG_5150.jpeg   91.3K   15 downloads
Attached File  IMG_5151.jpeg   104.96K   14 downloads
Attached File  IMG_5152.jpeg   166.23K   14 downloads
Attached File  IMG_5153.jpeg   146.08K   15 downloads
Attached File  IMG_5154.jpeg   167.57K   16 downloads
Attached File  IMG_5155.jpeg   138.63K   13 downloads
Marty
#522 rodomo
  • 18,037 posts
Posted 12 June 2021 - 10:43 AM
Difficult to get 18deg, C in my shed at the moment for paint.  :furious:
#523 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 12 June 2021 - 09:25 PM
Once the rust seal was dry I gave it a sand and the rest of the car a bit of a rub down.
Attached File  IMG_5166.jpeg   124.19K   14 downloads
Attached File  IMG_5167.jpeg   89.68K   14 downloads
Attached File  IMG_5168.jpeg   71.97K   15 downloads
Attached File  IMG_5169.jpeg   123.64K   14 downloads
Had the heater on for a few hours and raised the temp up to 22degrees.
Attached File  IMG_5193.jpeg   142.79K   14 downloads
Attached File  IMG_5194.jpeg   139.55K   14 downloads
Then sprayed all the repairs so it's 98% rust free and all in one colour.
Attached File  IMG_5198.jpeg   76.23K   15 downloads
Attached File  IMG_5200.jpeg   69.93K   14 downloads
Attached File  IMG_5201.jpeg   119.04K   14 downloads
Attached File  IMG_5202.jpeg   71.53K   14 downloads
Attached File  IMG_5204.jpeg   124.37K   15 downloads
Attached File  IMG_5206.jpeg   133.3K   15 downloads
The rear guard lips were damaged so I cut them back and welded the cut edge so now if I want to fit my 9inch rims for a show they won't rub.
Attached File  IMG_5208.jpeg   97.72K   17 downloads
Attached File  IMG_5209.jpeg   94.81K   16 downloads
Attached File  IMG_5210.jpeg   141.78K   15 downloads
Marty
#524 LJ RB30
LJ RB30
  • 1,035 posts
  • Name:Trevor
Posted 12 June 2021 - 10:34 PM
Looking good mate😁👍
All one colour is definitely a good feeling😁
#525 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 13 June 2021 - 04:10 PM
Looking good mate😁👍
Thanks Trev. Sure is, but I'm actually looking forward to adding a couple of other colours real soon.
Todays task is apply the bitumen coating to the inner roof.
Trying to get that factory look with sharp edge masking to the roof support and a soft edge around the sides.
Attached File  IMG_3855 (1).jpeg   144.66K   16 downloads
Used a sheet of cardboard with balls of tape used to lift it up about 5mm. Applied 1 litre of product then turned the car upright to help thicken the look.
Attached File  IMG_5211.jpeg   108.76K   17 downloads
Attached File  IMG_5212.jpeg   99.69K   14 downloads
Attached File  IMG_5215.jpeg   110.88K   14 downloads
Attached File  IMG_5218.jpeg   104.11K   14 downloads
Attached File  IMG_5220.jpeg   273.36K   16 downloads
Attached File  IMG_5222.jpeg   188.72K   16 downloads
Attached File  IMG_5223.jpeg   133.43K   17 downloads
Marty
Also tagged with one or more of these keywords: LC GTR, Restoration, 1971, The Marty Report, Girl Power
