The Sally Report
#576
Posted 05 October 2021 - 12:49 PM
#577
Posted 09 October 2021 - 11:19 PM
Painted the internal side of doors red oxide.
Fitted the rubbers to boot and doors then bolted them on the body.
Boot took a fair bit of time adjusting and trialing spacers etc. The bonnet was a PITA and I was just about to rip the Rare Spares hinges out when I worked out how the get the back of bonnet down.
IMG_6119.jpeg 171.23K
12 downloads
IMG_6120.jpeg 105.64K
9 downloads
IMG_6153.jpeg 212.78K
11 downloads
I found the rares instructions useless.
IMG_6158.jpeg 154.9K
10 downloads
Made sure I fitted the window stops before doing the bodywork. Helps support the panel while blocking back.
IMG_6159.jpeg 95.67K
11 downloads
IMG_6160.jpeg 97.81K
9 downloads
Checking the doors are flat with body.
IMG_6161.jpeg 77.27K
9 downloads
Getting into the boot adjusting.
IMG_6162.jpeg 85.1K
9 downloads
IMG_6163.jpeg 145.29K
9 downloads
IMG_6165.jpeg 169K
11 downloads
Took about two hours of going around in circles to get bonnet flat and gapped.
IMG_6167.jpeg 107.09K
13 downloads
IMG_6171.jpeg 60.3K
11 downloads
IMG_6172.jpeg 176.06K
10 downloads
Door gaps all good. Until Sally walked in and started picking little bits that wern't to her satisfaction.
IMG_6169.jpeg 96.87K
13 downloads
IMG_6170.jpeg 76.95K
11 downloads
And finally all panels on and gapped.
IMG_6173.jpeg 152.45K
14 downloads
Marty
#578
Posted 10 October 2021 - 06:18 AM
awesome work, can you get the rubbers off without damaging them for paint
#579
Posted 10 October 2021 - 09:30 AM
Hi Danny, I hope so! I only clicked them in one notch so should be able to use long nose pliers to assist.
Marty
#580
Posted 10 October 2021 - 12:07 PM
How hard are the bonnets to line up hey.
One of my hinges was a little loose so I put it in a press and it seems to work better but I am contemplating buying the resto country remakes as it needs an extra push once it closes to get the bonnet completely flat.
So bloody fiddly.
I see you using builders packers aswell great stuff
Sent from my SM-G965F using Tapatalk
#581
Posted 10 October 2021 - 02:19 PM
(Quoting) - "Door gaps all good. Until Sally walked in and started picking little bits that wern't to her satisfaction."
Thats Quality Assurance/Control
#582
Posted 11 October 2021 - 06:06 AM
Hey marty, any tips or tricks you can pass on with rares hinges, as i cant get mine to fit properly either, great work on ther build mate! Paul
#583
Posted 13 October 2021 - 10:07 PM
Hi Paul,
Rares hinges are made from a thicker metal therefore causing a few challenges.
I made two modifications, grinding back the back edge where it touches the drip tray (make it half thickness) and slotting the rear hole to allow more downward movement. I also had to remove washer from rear bolt to get maximum movement.
Best to fit hinge and take note of where it touches the drip tray.
Marty
#584
Posted 14 October 2021 - 10:59 AM
Thanks Marty, appreciate that, will try what you said and see how it goes, paul
#585
Posted 26 October 2021 - 07:00 PM
Did you do any reconditioning to the heater box fan motor other than cleaning it and rezincing it?
The same with the wiper motors, is there any reconditioning of these motors that can be done to make them run like new with a bit more speed?
#586
Posted 13 February 2022 - 08:47 PM
Hey Marty,
Hi James, Haven't been on for a while, Just cleaned the internals, greased bushs on ends and sprayed cover silver. Didn't re-zinc due to magnets attached to cover.
Full body rub down, mask-up and hi-fil again.
IMG_6309.jpeg 146.17K
8 downloads
IMG_6368.jpeg 139.09K
9 downloads
IMG_6378.jpeg 153.48K
8 downloads
IMG_6398.jpeg 109.98K
8 downloads
IMG_6405.jpeg 146.35K
9 downloads
IMG_6406.jpeg 168.19K
8 downloads
IMG_6431.jpeg 138.24K
7 downloads
IMG_6432.jpeg 96.34K
7 downloads
IMG_6433.jpeg 184.7K
8 downloads
Marty
#587
Posted 13 February 2022 - 09:10 PM
#588
Posted 13 February 2022 - 09:15 PM
#589
Posted 14 February 2022 - 03:15 PM
Once the top half is rubbed back another piece of guide tape is applied and the lower half sanded.
IMG_6434.jpeg 81.55K
8 downloads
IMG_6435.jpeg 139.04K
8 downloads
IMG_6436.jpeg 125.71K
8 downloads
IMG_6438.jpeg 117.64K
8 downloads
IMG_6439.jpeg 103.57K
9 downloads
High points hit with the speed file.
IMG_6440.jpeg 78.42K
8 downloads
IMG_6441.jpeg 158.52K
8 downloads
IMG_6442.jpeg 111.08K
10 downloads
Marty
#590
Posted 15 February 2022 - 07:09 PM
Another round of high fill then a final test fit of bits with a few adjustments made.
IMG_6489.jpeg 145.36K
9 downloads
IMG_6490.jpeg 154.82K
9 downloads
IMG_6497.jpeg 75.68K
8 downloads
IMG_6498.jpeg 159.83K
8 downloads
IMG_6500.jpeg 151.97K
7 downloads
IMG_6502.jpeg 107.73K
7 downloads
Marty
#591
Posted 15 February 2022 - 07:29 PM
#592
Posted 15 February 2022 - 07:43 PM
It's looking good Marty, well done.
Thanks James.
I had a set back on the troublesome rear quarter.
While checking the lines I could see it wasn't quit right so put a bit more bog on. Then i realised the bog was getting over 2mm thick and I needed another 2mm there so I decided to grind it off and pull the guard more. You can thank Heath for making me do this, after I read he pulled his engine out and rebuilt it after noticing something minor.
IMG_6503.jpeg 119.51K
10 downloads
IMG_6504.jpeg 157.76K
8 downloads
IMG_6505.jpeg 97.39K
7 downloads
IMG_6506.jpeg 108.72K
7 downloads
IMG_6508.jpeg 112.74K
7 downloads
IMG_6529.jpeg 53.52K
8 downloads
IMG_6530.jpeg 109.23K
7 downloads
IMG_6531.jpeg 107.42K
8 downloads
IMG_6532.jpeg 92.56K
8 downloads
IMG_6534.jpeg 105.47K
10 downloads
IMG_6536.jpeg 99.08K
7 downloads
Marty
#593
Posted 15 February 2022 - 07:57 PM
2 mm you bloody perfectionist
This will be straight as an arrow this body
#594
Posted 16 February 2022 - 08:54 AM
What are you looking at when you have the pvc pipe down the side? Just hollow sections under it?
#595
Posted 16 February 2022 - 02:16 PM
Hi Laurie, the pvc is used to get the line curve correct, I couldn't see the error at this stage. Not until I blocked it back and did some checks against the other side I noticed the problem. It was a case of almost there then having to take a few steps back.
Marty
#596
Posted 16 February 2022 - 05:52 PM
Sanded and primed and I think it's pretty close now.
IMG_6677.jpeg 103.14K
7 downloads
Sally set me up a little spot to watch Bathurst so I wouldn't get too much dust every where.
IMG_6680.jpeg 141.26K
8 downloads
Decided to get some foam panels to insulate the garage door. Faces west and gets super hot in the arvo. Seems to make a big difference.
IMG_6693.jpeg 116.93K
7 downloads
IMG_6700.jpeg 152.56K
9 downloads
Marty
#597
Posted 17 February 2022 - 06:46 PM
Hi Gene, I hope it is, but it's easy to miss something working in garage conditions.
I've been slowly progressing on the fuel tank. It's been something that when I have some bog left over or primer it gets a bit of work done to it.
Sprayed it with silver and clear and apart from the runs it came out sooo smooth. Hoping I can get this sort of finish on the car too.
IMG_6730.jpeg 149.68K
8 downloads
IMG_6731.jpeg 121.36K
8 downloads
IMG_6767.jpeg 80.06K
8 downloads
IMG_6809.jpeg 155.31K
8 downloads
IMG_6812.jpeg 94.07K
8 downloads
IMG_7173.jpeg 117.2K
8 downloads
IMG_7174.jpeg 112.48K
8 downloads
IMG_7175.jpeg 122.82K
8 downloads
IMG_7176.jpeg 62.06K
8 downloads
IMG_7178.jpeg 83.91K
9 downloads
I'll see if I can sand these out and polish it up otherwise I'll give it another go.
IMG_7183.jpeg 107.02K
9 downloads
While the silver was in the gun I sprayed the mirror stem.
IMG_7179.jpeg 59.78K
8 downloads
Marty
#598
Posted 17 February 2022 - 07:39 PM
Bodywork coming along nicely. I don’t mind it once I get in to a rhythm.
Your tank looks a similar finish to what I did in my FB ute. I didn’t bother with boxing it. It’s only an FB after all. I found a urethane silver to go straight over Epotec that doesn’t need clear coat like most metallics do. First go I got a lot of runs but went to a 1.4 touch up gun that worked a lot better. The single application urethane had a great finish and saved me a lot of effort. I ended up doing a lot of little detail pieces with it.
#599
Posted 18 February 2022 - 04:03 AM
#600
Posted 18 February 2022 - 08:17 AM
Hi Marty,
Hi Clay, I was using a 1.4 but on my big gun. I've got a touch-up gun but that only has a .6 tip. Clearing does take more work but I look at this as practice sessions for the big dance.
If you're painting the mirror stem did you do the sunvisor mounts too?
Hi James, I did think of that. I painted a few sets 7 years ago for the LJ so they're already on the visors and packed away ready for install.
Marty
Also tagged with one or more of these keywords: LC GTR, Restoration, 1971, The Marty Report, Girl Power
Holden Tech →
Electrical →
LC rear indicator screwsStarted by dacastle , 06 Apr 2024 ![]() |
General →
General Discussion →
What can you identify from stamped body number onlyStarted by 70 XU-1 , 21 Dec 2018 ![]() |
General →
Resto Rage HelpStarted by Rainman , 16 Sep 2017 ![]() |
Holden Tech →
General LH-LX-UC →
LH Torana rear windscreen SpecificationStarted by _Pjabrown_ , 06 Sep 2016 ![]() |
Holden Tech →
General LH-LX-UC →
Best paint to buyStarted by _toranaheath_ , 27 Oct 2015 ![]() |
