Hi Marty, I've been following the GTR build from the day one and it goes with out saying your attention to detail is exceptional.
As always looking forward to seeing this one in the flesh!.
Posted 20 April 2022 - 10:57 AM
Posted 20 April 2022 - 12:31 PM
Marty, you are a bloody weapon.
This work is just tremendous.
Posted 20 April 2022 - 10:46 PM
Hi Marty, I've been following the GTR build from the day one and it goes with out saying your attention to detail is exceptional.As always looking forward to seeing this one in the flesh!.
Thanks Aleks, It'll be good to get it out in the sun.
Thanks Heath, I can always count on you to make me feel special. Cheers
Got the doors on with some help from Sally. Thankfully no damage,
I used to wonder why restorers took pictures of these areas. I know how much work goes into getting these 3 panels to line up perfectly so I'm stoked to get a great result.
IMG_8114.jpeg 59.19K
9 downloads
IMG_8115.jpeg 191.82K
9 downloads
IMG_8116.jpeg 156.86K
10 downloads
Bolted on the bumper fill panel, centre support and bonnet catch. I've left the fill panel loose so I can adjust it when fitting the grill.
IMG_8118.jpeg 173.06K
12 downloads
IMG_8117.jpeg 108.26K
13 downloads
I think my fake spot welds in the guards came out well.
IMG_8119.jpeg 94.42K
12 downloads
Marty
Posted 20 April 2022 - 10:54 PM
When are the next masking pics?
Posted 20 April 2022 - 10:56 PM
Next week when I get the stripes stencils.
Posted 20 April 2022 - 11:30 PM
This is fantastic work Marty.
She is going to be gorgeous with the out in the sun with the chrome, stripes and blackouts.
Posted 25 April 2022 - 01:24 PM
Posted 25 April 2022 - 02:24 PM
Great work Marty. Cavity wax is the best. But don't apply over rust, like inside original doors. Fisholene will soak in to the rust where the wax sits on top.
I just painted or sprayed fisholene on/into every nook and cranny..
Posted 25 April 2022 - 02:35 PM
Posted 25 April 2022 - 03:06 PM
Posted 07 May 2022 - 11:11 AM
Fitted the boot lock. This was tricky just like when I did the LJ I struggled to get the locking plate in.
Firstly made a new rubber gasket then struggled to work out what was stopping the locking plate going all the way in. I filed bits off the new lock to match original but still no worky. Then I realised it was the L/plate catching on the edge of the hole, a few tweaks and in it goes.
IMG_8122.jpeg 152.27K
9 downloads
IMG_8123.jpeg 188.96K
9 downloads
IMG_8126.jpeg 73.08K
8 downloads
IMG_8127.jpeg 120.38K
10 downloads
Clean the rubber bungs up and fitted.
IMG_8141.jpeg 92.39K
10 downloads
IMG_8143.jpeg 131.52K
10 downloads
Marty
Posted 07 May 2022 - 08:14 PM
Did a bit more paint correction rubbing out sags and peel.
IMG_8144.jpeg 205.48K
13 downloads
Time to see some sun light on it.
Had to wait for the afternoon sun then lift the door. You can see the purple colour can look dirty/muddy in certain lights.
IMG_8147.jpeg 167.81K
10 downloads
After the black-outs while removing the masking I again stuffed up with my mask removal. You can see the colour peeled off on the lower door ridge. I'll attempt to fix this once the weather warms up and car is almost finished. Probably just paint the ridge again.
IMG_8148.jpeg 178.49K
15 downloads
IMG_8159.jpeg 232.24K
9 downloads
IMG_8160.jpeg 178.9K
13 downloads
Next is the underside of bonnet. Again rubbing out defects.
Here you can see a sag which I've rubbed flat and then compounded.
IMG_8191.jpeg 194.46K
11 downloads
IMG_8285.jpeg 206.89K
11 downloads
IMG_8289.jpeg 189.68K
9 downloads
Marty
Posted 07 May 2022 - 10:04 PM
Posted 07 May 2022 - 10:08 PM
Amethyst Maz
Posted 07 May 2022 - 10:12 PM
Edited by madtoranajzedded, 07 May 2022 - 10:14 PM.
Posted 08 May 2022 - 10:01 AM
If you are pulling the colour off with the masking tape, is the paint still too soft, or is it an adhesion problem?
Are you using low tack tape?
Rob
Posted 08 May 2022 - 10:13 AM
beautiful marty
Posted 08 May 2022 - 02:00 PM
Rob
I think it's either soft on the edge and not using low tack tape. I've been using the same tape through-out, i didn't think to use a different one for new painted areas. All other areas ok after I slowed down and changed the angle of my tape pull.
Marty
beautiful marty
Thanks Albert, you're the only one on here who's seen the car.
Posted 08 May 2022 - 02:46 PM
Posted 08 May 2022 - 08:25 PM
Excellent work as ever Marty. We pulled paint off like that in a few places painting sons subi recently but it was acrylic on blocked back original urethane. Horrifying experience.
The sags you are sanding, are they in the clear?
Yes, in the clear. I was to heavy in both base and clear. I'd love to spray it again using the knowledge and experience I have now. But that's not going to happen!
Marty
Posted 08 May 2022 - 08:49 PM
The bonnet is just about ready to put away for safe keeping until engine is in. Gave it the cavity wax treatment, cleaned it up then put it in the bedroom.
IMG_8294.jpeg 171.22K
12 downloads
Now it's time to organise the stripes. Some how I ended up with two sets of stencils, one set from Barry and another from Bat53. Thanks guys I was happy to have a spare incase I stuffed up along the way.
Firstly I had to work out how to get the correct positioning. The challenge is you can't see through the stencil to gauge where the top bodyline is. Also check that the black stripe won't drop into the door handle area.
IMG_8296.jpeg 111.16K
11 downloads
I started my positioning at the badge. I've seen many stripes miss the badge centre.
IMG_8295.jpeg 107.4K
9 downloads
Solution is to cut the top section off so you only have 4mm of stencil then this becomes your guide line for the body line to follow.
IMG_8298.jpeg 131.22K
8 downloads
Using a knife and metre rule trim it back.
IMG_8299.jpeg 130.81K
9 downloads
All done
IMG_8302.jpeg 140.2K
8 downloads
Next post I'll show how I applied them.
Marty
Posted 09 May 2022 - 10:27 PM
I've repositioned the car and started bringing in tools and cabinets as I get ready to re-assemble.
IMG_8193.jpeg 143.51K
9 downloads
IMG_8319.jpeg 186.97K
9 downloads
Tested some scrap stencil on the kitchen bench just to get a feel for how it sticks. It has a light tack - not too sticky.
IMG_8303 (1).jpeg 156.06K
9 downloads
Stencil night was actually date night so Sally was out in the shed helping. More like pointing out problems while enjoying some wine.
IMG_8325.jpeg 186.29K
9 downloads
IMG_8329.jpeg 173.65K
9 downloads
Not sure how you're meant to curve a straight bit of paper? Creases appear but I cut them out and did my own masking.
IMG_8333.jpeg 110.74K
11 downloads
IMG_8336.jpeg 116.75K
9 downloads
IMG_8345.jpeg 117.39K
10 downloads
IMG_4635.jpeg 200.57K
12 downloads
IMG_8347.jpeg 93.3K
13 downloads
IMG_8348.jpeg 98.69K
11 downloads
IMG_8351.jpeg 199.43K
12 downloads
I scuffed all the strip areas with grey scourer and masked the car up ready for paint.
IMG_8352.jpeg 195.17K
13 downloads
Marty
Posted 09 May 2022 - 11:03 PM
Posted 10 May 2022 - 09:52 PM
I’m always nervous about masking on fresh paint
Posted 13 May 2022 - 07:14 PM
Holden Tech →
Electrical →
LC rear indicator screwsStarted by dacastle , 06 Apr 2024 ![]() |
General →
General Discussion →
What can you identify from stamped body number onlyStarted by 70 XU-1 , 21 Dec 2018 ![]() |
General →
Resto Rage HelpStarted by Rainman , 16 Sep 2017 ![]() |
Holden Tech →
General LH-LX-UC →
LH Torana rear windscreen SpecificationStarted by _Pjabrown_ , 06 Sep 2016 ![]() |
Holden Tech →
General LH-LX-UC →
Best paint to buyStarted by _toranaheath_ , 27 Oct 2015 ![]() |
