The Sally Report
LC GTR Restoration 1971 The Marty Report Girl Power
1003 replies to this topic
#776 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 20 May 2022 - 06:51 AM
Awsome stuff Marty, this whole topic is a digital version of a workshop manual. Very impressive. :)
Jaso
#777 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 20 May 2022 - 09:43 PM
I'm keen to get the roof lining in. Dug out the original one and cleaned up the rods and transferred them to the new lining one at time.
Added the padding to the rear quarters and also the three stripes behind back seat. Also tried to replicate the chalk markings that were on from factory. One day someone may work out what it means.
Attached File  IMG_8426.jpeg   146.01K   10 downloads
Attached File  IMG_8427.jpeg   106.23K   7 downloads
Attached File  IMG_8429.jpeg   162.21K   11 downloads
Original markings.
Attached File  IMG_7498.jpeg   84.29K   11 downloads
Attached File  IMG_8431.jpeg   180.26K   9 downloads
I like to take my time with these. Last one took six weeks. Firstly get it unfolded and up in position.
Attached File  IMG_8433.jpeg   135.86K   8 downloads
Using the old pinch weld to hold the lining in place.
Attached File  IMG_8432.jpeg   229.52K   8 downloads
Marty
#778 rodomo
  • 18,037 posts
Posted 20 May 2022 - 10:09 PM
Edited by rodomo, 20 May 2022 - 10:10 PM.
#779 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 21 May 2022 - 03:35 PM
Just realised I've got to get the wiring in for the interior light before fitting roof lining. Dug that part of the harness out, cleaned and tested it.
Attached File  IMG_8448.jpeg   317.09K   9 downloads
Had some serious gunk stuck to it. I used thinners and a rag to wipe over the wires, wire brushed the connections and tested with volt meter for continuity.
Attached File  IMG_8449.jpeg   163.39K   8 downloads
If it's ok to go on the dining room table it's got to be clean enough.
Attached File  IMG_8483.jpeg   214.3K   11 downloads
Un-wrapped the stainless trim for the gutters, the glad wrap had stuck so I used thinners again to help clean it off.
Attached File  IMG_8393.jpeg   208.93K   9 downloads
Attached File  IMG_8394.jpeg   227.67K   8 downloads
Attached File  IMG_8479.jpeg   119.08K   9 downloads
Attached File  IMG_8480.jpeg   157.91K   12 downloads
Marty
#780 jd lj
jd lj
  • 2,113 posts
  • Name:James D
  • Car:LJ SVO
Posted 21 May 2022 - 08:16 PM
Hey Marty,
Have you got a photo of the clips that hold the hood lining bows in place? I forgot to take that photo when I pulled mine apart. I'll be fitting my hood lining soon too.
Thanks in advance.
#781 Indy Orange
Indy Orange
  • 2,938 posts
  • Name:Paul
Posted 21 May 2022 - 08:23 PM
That was probably a LJ thing James,stops the rods from flipping over, not mentioned in the LC manual, probably not needed.
Edited by Indy Orange, 21 May 2022 - 08:27 PM.
#782 Indy Orange
Indy Orange
  • 2,938 posts
  • Name:Paul
Posted 21 May 2022 - 08:57 PM
Here ya go.
#783 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 21 May 2022 - 09:30 PM
Hey Marty,
Thanks in advance.
Hi James, No clips on this LC. Thanks for posting that pic Paul.
#784 gad05
gad05
  • 421 posts
  • Name:Graham
  • Car:73 lj 2 door , 74 lj sedan.
Posted 21 May 2022 - 11:22 PM
Hi Marty,
Car is coming along beautifully, l always love your attention to detail.
Can I ask what you used to polish your gutter trims,l have 2 sets to restore.
Cheers Graham.
#785 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 22 May 2022 - 10:18 AM
Hi Marty,
Cheers Graham.
Hi Graham, on page one of this thread - post #11 are some pictures.
Depending how bad they are you either start with dent removal (tapping out with flat punch) Then file flat, wet & dry thought the grades to 3000 then use the polishing wheel like in pics.  Two wheels used and the grey and white polish bars. Don't let the stainless get to hot or distortion can occur.
I'm going to run the polishing wheel over it again while it's on the car, it's a lot easier to keep it secure.
Marty
#786 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 22 May 2022 - 09:11 PM
Both window winding mechanisms are in.
Attached File  IMG_8415.jpeg   165.93K   7 downloads
Attached File  IMG_8417.jpeg   160.92K   7 downloads
Door mechanism in and working.
Attached File  IMG_8416.jpeg   166.65K   9 downloads
Bit by bit, getting there.
Marty
#787 jpxu1
jpxu1
  • 571 posts
Posted 22 May 2022 - 09:34 PM
Hate to be the bearer of bad news, but pretty sure the glass has to go in before the mech :-(
#788 Indy Orange
Indy Orange
  • 2,938 posts
  • Name:Paul
Posted 22 May 2022 - 09:51 PM
Don’t forget the weather strips.
#789 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 23 May 2022 - 09:30 AM
It's been a long time since doing this. I thought it was winder then glass in then quarter window???
I thought they went in last??
#790 Indy Orange
Indy Orange
  • 2,938 posts
  • Name:Paul
Posted 23 May 2022 - 10:59 AM
Yeah , whilst the glass is still sitting in the bottom of the door.Then I could still get my arm up inside the door to push the clips up to secure the weather strips .
Edited by Indy Orange, 23 May 2022 - 11:02 AM.
#791 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 23 May 2022 - 01:02 PM
I know it's a prick of a job. Can't wait!
#792 Indy Orange
Indy Orange
  • 2,938 posts
  • Name:Paul
Posted 23 May 2022 - 01:31 PM
Sure is ! I suggest maybe use some rubber wedges to open the door glass gap to get the quarter glass frame in and the window glass, and use tape along the edges .I know you’ll do that anyway.👍
#793 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 23 May 2022 - 01:35 PM
Finally got the heater box in. took a couple of attempts. First time I fitted it I noticed the back seal didn't fit well against firewall. Pulled it out and cleaned up all the shitty mastic. Checked some original rear seals and noticed they're about 3mm thicker than after market.
Attached File  IMG_8521 (1).jpeg   51.01K   7 downloads
This time I used an original seal and it looks better.
Attached File  IMG_8526.jpeg   213.15K   13 downloads
Attached File  IMG_8525.jpeg   163.25K   8 downloads
Attached File  IMG_8548.jpeg   199.36K   11 downloads
Noticed the accelerator rod was rubbing on heater box. Realised the throttle bracket was bent up a bit so straightened it out and it now clears, Just.
Attached File  IMG_8530.jpeg   201.24K   7 downloads
Attached File  IMG_8529.jpeg   181.39K   3 downloads
Realised this car never came with the heater box cable clip. If anyone has a spare I would gratefully accept it.
Goes here.
Attached File  IMG_8551.jpeg   185.25K   6 downloads
Looks like this one
Attached File  IMG_8542.jpeg   169.73K   3 downloads
Clean up the venting and installed those. I was missing some of the heater box nuts which are an unusual thread to the rest of the car. Found out they're 5mm metric and got some from my local nut and bolt store. Look similar but not exact.
Attached File  IMG_8522.jpeg   187.74K   5 downloads
Attached File  IMG_8524.jpeg   129.56K   4 downloads
Attached File  IMG_8539.jpeg   125.91K   7 downloads
I was given this as a gift, one of the nicest and handiest ratchets you'll find. Well worth the money.
Attached File  IMG_8540.jpeg   127.07K   5 downloads
Marty
#794 Heath
  • 18,385 posts
Posted 24 May 2022 - 09:50 AM
Slow down mate. You're making us look really bad.
Exciting times! Very fun part of the build.
#795 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 26 May 2022 - 10:25 PM
It's a good feeling unwrapping all these parts I restored a couple of years ago. Also glad I marked what they are and where they go.
Attached File  IMG_8537.jpeg   170.18K   4 downloads
Attached File  IMG_8538.jpeg   220.99K   4 downloads
Attached File  IMG_8536.jpeg   135.59K   5 downloads
Attached File  IMG_8553.jpeg   145.91K   5 downloads
I hooked up a battery to test the fan and cable set-up is working.
Attached File  IMG_8555.jpeg   205.93K   4 downloads
Also managed to get the glovebox in with-out to much trouble this time. There is a technique to it so you don't break it.
Attached File  IMG_8558.jpeg   145.39K   7 downloads
Marty
#796 jd lj
jd lj
  • 2,113 posts
  • Name:James D
  • Car:LJ SVO
Posted 27 May 2022 - 07:40 PM
Marty,
Could you share the technique for fitting the glove box insert. I'll be doing my soon enough and recall that it's an awkward task.
#797 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 27 May 2022 - 08:41 PM
Marty,
Insert the left hand side first pushing it in as far as you can. This should give you just enough room to get the right hand side in. Next work on getting the top lip in behind metal. I used a plastic trim remover tool (Basically a plastic flat blade screwdriver). Lastly using the tool to lever the right hand side lip behind the metal edge. The bottom card stays on top of metal lip.
Good luck James.
Marty
#798 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 27 May 2022 - 09:19 PM
Time to clean up and repair the main wearing harness. I'll try and describe all the little fixes and photograph.
Attached File  IMG_8572.jpeg   315.55K   3 downloads
This connector was discoloured and cracked. I have a spare harness which I have salvaged the missing and broken bits. Definitely worth having a butchered harness to get spares from.
Attached File  IMG_8573.jpeg   164.01K   4 downloads
I used a home made tool to release the clips from the plugs. The tool is made from a street sweeper metal bristle, I've found many sitting in the street gutters.
Attached File  IMG_8575.jpeg   173.31K   4 downloads
Re-fit the new plug.
Attached File  IMG_8577.jpeg   174.84K   4 downloads
This indicator plug had been butchered
Attached File  IMG_8586.jpeg   110.9K   5 downloads
I found some matching wires and joined and soldered further up the harness to be hidden by wrap.
Attached File  IMG_8587.jpeg   106.27K   5 downloads
Attached File  IMG_8588.jpeg   130.23K   5 downloads
The tool I made in top left corner.
Attached File  IMG_8589.jpeg   220.88K   5 downloads
Drill out the old wire from clip, fitted new wire and soldered.
Attached File  IMG_8604.jpeg   82.68K   6 downloads
#799 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 27 May 2022 - 09:34 PM
Apon inspecting and cleaning the harness I noticed this tan wire had been cut. It's on the drivers side between headlight and brake booster. Worked out its the brake valve indicator. I have a spare and will fit that once harness is in so I know the length.
Attached File  IMG_8591.jpeg   128.92K   7 downloads
Attached File  IMG_8592.jpeg   92.51K   6 downloads
Once I had cleaned and repaired it was time to fit the rubber grommet. You'll need plenty of lube for this job as you stretch this tiny hole over many large bits. Rubber grease is king for this task.
Attached File  IMG_8605.jpeg   161.73K   7 downloads
A better picture of the tool. Removing clips I'd just put on.
Attached File  IMG_8606.jpeg   168.95K   7 downloads
Attached File  IMG_8610.jpeg   128.61K   6 downloads
Heres a bunch of clips attached to a pull wire and taped up, with plenty of lube.
Attached File  IMG_8611.jpeg   170.69K   6 downloads
Attached File  IMG_8612.jpeg   176.86K   4 downloads
Attached File  IMG_8613.jpeg   175.47K   4 downloads
#800 GTRMaxhunter20
GTRMaxhunter20
  • 48 posts
  • Name:Ben
  • Car:LJ
Coming along well Marty. Hydrogen peroxide may well whiten up the connectors like new. Worked a treat on my interior
Light lense.
Also tagged with one or more of these keywords: LC GTR, Restoration, 1971, The Marty Report, Girl Power
