The Sally Report
LC GTR Restoration 1971 The Marty Report Girl Power
1003 replies to this topic
#826 GTRMaxhunter20
GTRMaxhunter20
  • 48 posts
  • Name:Ben
  • Car:LJ
Posted 31 May 2022 - 08:36 PM
I used inner tube on the front of LJ, only for the purpose of not scratching the paint, theres not water ingress to worry about. The rear section where the brackets mount is not a high finished paint area, so Mastic only is my recommendation.
#827 GTRMaxhunter20
GTRMaxhunter20
  • 48 posts
  • Name:Ben
  • Car:LJ
Posted 31 May 2022 - 08:47 PM
The company I work for manufactures non-skinning butyl mastics amongst other technologies like polyurethane, silicone, ms polymer etc. The butyl mastics are great as a sealant between components because they have no bond strength in an assembly sense; they don’t cure and so have no cohesive strength which would impede disassembly. Only short coming is dirt collection and the won’t cushion anything or have vibration resistance/gasket properties. Only thing to use for tail light housings, scuff plates etc. Marty is right - put it every where you can to stop leaks (except engine or cooling system.)
#828 gad05
gad05
  • 421 posts
  • Name:Graham
  • Car:73 lj 2 door , 74 lj sedan.
Posted 01 June 2022 - 10:30 AM
Thanks for the info Marty.
I will brake out the KBS on the weekend.
Cheers Graham.
#829 dacastle
dacastle
  • 107 posts
  • Car:LC gtr
Posted 01 June 2022 - 01:41 PM
Marty
can I take you back to page 23 of your post - has all been great reading by the way - where did you get the replacement foam and heater box flap material .
I have purchased a gasket set and are waiting for rezincing of parts to rebuild my heater box
#830 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 01 June 2022 - 07:52 PM
Marty
Hi Dave, Foam kit was from Muscle Car parts on eBay. The flap material came from Clark Rubber from memory, left over from the LJ build.
I wouldn't use the foam in kit that joins heater box to fire wall. It's too thin compared to original.
Marty
#831 dacastle
dacastle
  • 107 posts
  • Car:LC gtr
Posted 03 June 2022 - 03:18 PM
Marty
Thanks Marty- what adhesive did you use to stick foam to radiator etc
#832 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 03 June 2022 - 09:58 PM
Contact adhesive
Started stripping the steering column down and have found a few things that need fixing.
Upper bearing seems good, just needs a new 'o' ring. Lower nylon bushes seem ok too.
Attached File  IMG_8650.jpeg   130.05K   6 downloads
One of the inner fixing tabs has completely broken off, I hope to make another and glue it in position.
Attached File  IMG_8652.jpeg   87.24K   6 downloads
A bit of rust to remove so soaked them in rust remover.
Attached File  IMG_8656.jpeg   114.84K   8 downloads
Attached File  IMG_8657.jpeg   106.45K   7 downloads
Attached File  IMG_8659.jpeg   136.46K   6 downloads
Attached File  IMG_8674.jpeg   114.62K   6 downloads
Attached File  IMG_8675.jpeg   118.06K   6 downloads
Gave these bits a rust blast.
Attached File  IMG_8678.jpeg   207.85K   6 downloads
Attached File  IMG_8679.jpeg   156.19K   3 downloads
This bit is stuffed, cracked screw holes, big chunk of plastic missing and one of the terminals on the harness is broken. I'll be looking for another one of these.
Attached File  IMG_8653.jpeg   76.97K   4 downloads
Marty
#833 Shiney005
  • 9,586 posts
  • Car:Toyota Mirai
Posted 07 June 2022 - 09:31 AM
This is better than a Haynes manual. When are you starting the LH restoration Marty?
#834 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 08 June 2022 - 10:12 PM
Roof lining is coming along slowly, I'ts been 4 weeks since I first fitted it. Takes a bit of mucking around, I took it down after a week and adjusted to bow wires, the canvas was getting caught on the wires or roof. Slit the ends of the canvas loops to get a better fit. If the canvas gets caught it pulls on the seams and can cause bows to flip.
Attached File  IMG_8519.jpeg   111.16K   6 downloads
Be confident it's in the right place before cutting and only cut small bits at a time. Roof lining should have a centre mark front and back and use that to line up with centre of screen openings.
Attached File  IMG_8549.jpeg   192.29K   5 downloads
Attached File  IMG_8554.jpeg   85.33K   6 downloads
Attached File  IMG_8636.jpeg   77.51K   6 downloads
Fitting the screws first, easier to find a screw rather than a hole.
Attached File  IMG_8637.jpeg   151.85K   5 downloads
Attached File  IMG_8738.jpeg   100.22K   6 downloads
Attached File  IMG_8740.jpeg   87.54K   5 downloads
Heat gun helps in the weird corners, material goes soft and pliable.
Attached File  IMG_8741.jpeg   113.08K   6 downloads
Attached File  IMG_8747.jpeg   78.96K   4 downloads
After fitting the stainless trim tops I had to try the door skins. Also fitted the pinch welds to see how it pulls in on the lining.
Attached File  IMG_8752.jpeg   101.93K   8 downloads
Still got a few creases to get rid of. I'll remove pinchweld and use heat gun to pull tight.
Attached File  IMG_8754.jpeg   177.4K   17 downloads
Marty
#835 Indy Orange
Indy Orange
  • 2,934 posts
  • Name:Paul
Posted 08 June 2022 - 10:58 PM
It’s going to so nice ,Marty.
#836 claysummers
claysummers
  • 3,629 posts
  • Name:Clay
Posted 09 June 2022 - 09:47 AM
Very nice job. You’re a brave man.
#837 Heath
  • 18,385 posts
Posted 09 June 2022 - 10:04 AM
This trim and paint colour combo is to die for.
#838 claysummers
claysummers
  • 3,629 posts
  • Name:Clay
Posted 09 June 2022 - 11:52 AM
Back in the day wife’s cousin, newly ordained Catholic priest. His family bought him a brand new Charger in gratitude for giving his life to the church. It was purple with white vinyl roof and interior.
#839 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 19 June 2022 - 07:42 PM
I'm struggling with the last of the creases at back of the roof lining so getting frustrated and leaving that for another week or two.
Time to start the second K-Frame strip down after the first one was bent.
Attached File  IMG_8670.jpeg   293.43K   12 downloads
This time I'm going to make a spring compressor, think this was from Robs thread.
Attached File  IMG_8694.jpeg   166.6K   9 downloads
Attached File  IMG_8761.jpeg   189.86K   10 downloads
This K-Frame has damage at the bump stop but hopefully I can fix it.
Attached File  IMG_8755.jpeg   202.03K   11 downloads
Attached File  IMG_8757.jpeg   209.3K   9 downloads
Attached File  IMG_8760.jpeg   218.95K   8 downloads
These bushes were a real struggle to work out how to get out.
Attached File  IMG_8771.jpeg   164.94K   8 downloads
Attached File  IMG_8773.jpeg   131.88K   6 downloads
Marty
#840 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 20 June 2022 - 09:50 AM
Used to just bash those bushes through with a nut on the end to prevent thread damage.
Rob
#841 IanC
IanC
  • 605 posts
  • Name:Ian
  • Car:LJ XU-1
Posted 20 June 2022 - 10:29 AM
This is what I bought. Worked awesome."10pc Ball Joint Press Service Kit Remover Separator Adaptor 4x4 Garage Tool | eBay" https://www.ebay.com...5IaAqWfEALw_wcB
#842 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 20 June 2022 - 03:17 PM
Who's door trims are they Marty ?
#843 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 20 June 2022 - 05:33 PM
Rob
I tried many different ways, each getting them out a little more.
That looks the goods. Might have to get that. Thanks Ian
They're from Cools Auto Trim.
#844 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 20 June 2022 - 08:07 PM
Okay, thanks Marty.
#845 IanC
IanC
  • 605 posts
  • Name:Ian
  • Car:LJ XU-1
Posted 22 June 2022 - 06:14 AM
Marty. I did have to modify the clamp a little. Cheers mate. https://photos.app.g...hQLJN5L9iRT6qEA
#846 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 26 June 2022 - 08:18 PM
I've had a set-back with the engine. A quick re-cap.
I took a 300km round trip to purchase a fully re-cond 173 with a CD prefix. Paid $1500 and it came with receipts for about $4000.
The guy I bought it off had purchased a HR which came with this engine and he wanted to fit a bigger motor so had no need for it.
I took the engine to my engine builder to check it over, see if the cam is suitable etc. The head was low comp and needed to be high comp for my car. The block looked all good at this stage and it sat in his workshop for over a year. As I started to push for it to be finished he pulled it apart and found it was bored to 186 and had heli-coils fitted for three head bolts and they were crooked. He recommended we find another block. This motor was defiantly recond but buy a shonky builder.
He then managed to source another 173 Q motor which had standard pistons but on measuring he realised they were 179 standard so this block was no good either.
So I'm on the hunt for a Perth 173 block which hasn't been bored out too much. I think 40thou would be fine for me to go to 60thou.Not too fussed about the engine prefix but would prefer it be a pre 74 so it has the neoprene rear mains seal then I can use the good crank I have.
A bit of a kick in the guts but this is all part of playing with these old cars.
Marty
#847 Ice
  • 15,200 posts
Posted 26 June 2022 - 09:50 PM
Hey Marty Im going to see a mate of mine tomorrow he has a few engines i will look to see if he has one spare
Not sure if he has a 173 though you but never know
cheers G
#848 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 27 June 2022 - 10:18 AM
i have one ,it's a 73
has been bored no markings for how much
yours if you want it
#849 LJ RB30
LJ RB30
  • 1,035 posts
  • Name:Trevor
Posted 27 June 2022 - 08:26 PM
Think I've got a couple in the shed. Will go & see what bore they are shortly
#850 LJ RB30
LJ RB30
  • 1,035 posts
  • Name:Trevor
Posted 27 June 2022 - 09:36 PM
Only have 1 but its a rope seal.
Standard bore, been refreshed at some stage going by the extra stamps on the pad, bearings look like its done very little work.
Cast date pic not great but it's 22K4.
Can barely feel the step at the top of the bore, it would hone out if you really wanted too.
Still has fiber cam gear  :blush:
Attached File  IMG_5599.JPG   296.81K   8 downloads
Attached File  IMG_5600.JPG   285.43K   8 downloads
Attached File  IMG_5604.JPG   393.28K   7 downloads
Attached File  IMG_5601.JPG   222.62K   7 downloads
Attached File  IMG_5605.JPG   396K   8 downloads
Attached File  IMG_5606.JPG   316.95K   7 downloads
Also tagged with one or more of these keywords: LC GTR, Restoration, 1971, The Marty Report, Girl Power
