The Sally Report
LC GTR Restoration 1971 The Marty Report Girl Power
1003 replies to this topic
#976 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 23 July 2023 - 09:36 PM
The day had arrived to start the engine.
In my mind I remember this day with the LJ and I had Forum member Dave help me and the 202 started first go. It was a very exciting moment.
Again I asked Dave to help, he's very good with electrical gremlins and I like having another set of eyes and a good brain when doing this.
Well, with Sally filming and the first time going for a start the engine gave a pufff as it sort of tryed to start. Again we cranked it - it ran longer but stopped as the key was released. The excitement was disappearing and concern starting.
We made a few alterations with timing and points and tried again. This time it ran but wouldn't idle so we manually kept the revs up for cam bedding in. I was getting nothing on the oil pressure gauge but didn't trust it as dodgy sender and lack of earths on the instrument cluster. I was relying on seeing oil at the rockers as my gauge.
I ran it for a minute with-out any oil at the top before shutting down worried I had oil pressure problems.  I was also running two pipes out of the manifold and it was noisy and uncomfortable in the garage.
We stopped the whole process here and I decided to get a exhaust and muffler and borrow a manual oil gauge.
Fast forward another 2 weeks and I had borrowed an old exhaust system and oil gauge. I chose to fire up on my own and it started well and I kept the revs up aiming for 2000rpm for 20 mins to bed the cam in. The oil gauge went straight up to around 45 but there was still no oil at the rockers. Slowly I started to see signs of oil and after about 5 mins the oil was there at the top, what a relief.
Defiantly had a concerned look on my face for this one.
Attached File  Screen Shot 2023-07-23 at 6.50.49 pm.jpeg   127.32K   11 downloads
No oil yet.
Attached File  IMG_8618.jpeg   144.04K   4 downloads
Sorting out the other exhaust system.
Attached File  IMG_2939.jpeg   188.01K   5 downloads
Seeing that gauge move was a great feeling.
Attached File  Screen Shot 2023-07-23 at 6.44.07 pm.jpeg   143.66K   7 downloads
Finally oil at the top.
Attached File  IMG_2945.jpeg   157.84K   8 downloads
Next I started getting oil every where with my dodgy clear rocker cover so it was time to fit the chrome rocker cover, vacuum hose, breather hose and air cleaner.
Attached File  IMG_2950.jpeg   230.11K   9 downloads
Next start will be when the steering column is in and the gauges can be earthed properly.
Marty
#977 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 06 August 2023 - 07:53 PM
POPULAR
I've got the brakes together but realised i'm missing the auto brake adjusters, found some in my spares box so they need to be re-zinced. Realised the front drums on toranas have all their bits the same as the rear drums. Very handy if you need springs and bits.
Attached File  IMG_2976.jpeg   124.49K   12 downloads
Glued on the inner and outer belts.
Attached File  IMG_3036.jpeg   121.79K   8 downloads
You know you're getting close when you start getting the carpets ready. There's a lot to consider when fitting carpet. Not something to rush.
Attached File  IMG_3041.jpeg   238.37K   10 downloads
Working out the handbrake position then getting the bit sewn in.
Attached File  IMG_3053.jpeg   298.72K   14 downloads
Attached File  IMG_3068.jpeg   325.09K   10 downloads
I'm pretty sure this is the correct spot for the accelerator pedal.
Attached File  IMG_3085.jpeg   263.33K   8 downloads
Seat rails in first to make it easier to cut around.
Attached File  IMG_3103.jpeg   158.73K   16 downloads
All carpets are now out until I've got all the electrics sorted.
Marty
#978 claysummers
claysummers
  • 3,716 posts
  • Name:Clay
Posted 07 August 2023 - 12:27 AM
Lovely work as ever Marty.
#979 bat 53
bat 53
  • 521 posts
  • Name:albert
  • Car:lc gtr
Posted 11 August 2023 - 10:16 AM
welldone marty as always
hanging out to get mine back :nada:
#980 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 836 posts
  • Name:JASO
Posted 11 August 2023 - 04:08 PM
Absolutely fabulous Marty, a credit to you both.
#981 dacastle
dacastle
  • 112 posts
  • Car:LC gtr
Posted 24 April 2024 - 06:14 PM
Hi Marty
what did you use to make the mould for the under dash pattern to patch up the holes - was it just resin poured onto the existing dash
Your posts are fantastic - has helped me with my very slow build
Hi Adam, I've only got a few sets left and I'm going to start restoring some dash's so until I print some more I'm not selling any more for a while.
As we're talking about dash's I'll put up some pics of a few i'm restoring at the moment. These are plastic LC ones. One was broken in half but all need strengthening in the narrow section.
Gave them a bath in the kitchen sink, much to Sallys discussed.
Drilled  holes through the fin and fitted metal strips before pouring black resin. It reminds me of grout filling a block to take out the flex.
Made a couple of moulds of the two different textures.
This is one of the holes needing repair and the results of the two patterns once I poured resin into the area.
I'll post more pictures as these progress.
Marty
#982 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 25 April 2024 - 12:07 PM
Hi Marty
Hi Dave,  I used a two part silicone product called Pinkysil then position that behind the dash hole and fill with a special resin. If you need anymore info just PM me, hopefully that still works?
Once this forum gets sorted out so threads don't jump out of sync i'll post up some more progress.
Marty
Marty
#983 dacastle
dacastle
  • 112 posts
  • Car:LC gtr
Posted 25 April 2024 - 01:49 PM
Thanks Marty
Marty
Marty
#984 dacastle
dacastle
  • 112 posts
  • Car:LC gtr
Posted 05 June 2024 - 06:51 PM
Thanks Marty
Hi Marty - I tried to PM you but received this message -The member sibhs cannot receive any new messages
I have been using a Bunnings fibreglass kit and resin to complete repairs to heater box etc-  would this suit the underdash repairs ?
cheers Dave
#985 Ice
  • 15,221 posts
Posted 16 October 2024 - 08:59 PM
Someone at Toranafest told me this was finished
How bout some pics Marty  :)
#986 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 22 January 2025 - 05:36 PM
G'day guys, due to overwhelming requests I'm doing an update. There's a lot to catch-up on because I've been hesitant to post while the threads are out of order. Hope this gets fixed one day but most members don't have the problem.
There's so many pics and sort of forgotten how to attach them but here goes.
I had headlight dramas and couldn't work it out, tried a few units and rebuilt some, not a hard task if you give it a go. Can't remember what the problem was but, hang on! Just remembered I had a wire wrong spot on fuse box.
Attached File  IMG_3135.jpeg   414.69K   3 downloads
Attached File  IMG_3138.jpeg   597.04K   2 downloads
Got the indicators working, again I had rebuilt the plastic spring bit and had it the wrong way so park was bright and indicator dull, easy fix.
Attached File  IMG_3156.jpeg   227.97K   2 downloads
Getting started on battery box lids, hope to one day make a mould so these become a one piece item.
Attached File  IMG_3190.jpeg   211.8K   2 downloads
#987 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 22 January 2025 - 05:40 PM
Had the door card badges chromed so started the masking out process. This is a PITA.
Attached File  IMG_3193.jpeg   293.16K   2 downloads
Attached File  IMG_3194.jpeg   384.11K   2 downloads
Attached File  IMG_3504.jpeg   472.18K   2 downloads
Attached File  IMG_3534.jpeg   582.48K   2 downloads
#988 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 22 January 2025 - 05:46 PM
Attached File  IMG_3539.jpeg   327.88K   3 downloads
Door card protectors in.
Attached File  IMG_3237.jpeg   322.87K   4 downloads
Rat trap re-build.
Attached File  IMG_3283.jpeg   448.25K   3 downloads
Attached File  IMG_3437.jpeg   475.65K   3 downloads
OK can't get many pics to a post, I've re-sampled them to big, gotta make a change.
#989 claysummers
claysummers
  • 3,716 posts
  • Name:Clay
Posted 22 January 2025 - 05:49 PM
Love your work, as ever, Marty. Thank you for posting.
#990 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 22 January 2025 - 05:58 PM
Rear quarter windows get masked, sand blasted, etched then painted 2K.
Attached File  IMG_3284.jpeg   396.6K   2 downloads
Attached File  IMG_3286.jpeg   332.89K   2 downloads
Attached File  IMG_3288.jpeg   409.78K   2 downloads
Attached File  IMG_3337.jpeg   430.86K   2 downloads
Attached File  IMG_3442.jpeg   333.3K   2 downloads
That'll do for now, I'll update some more later.
Marty
#991 RallyRed
  • 8,213 posts
Posted 22 January 2025 - 06:13 PM
Legend.
#992 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 22 January 2025 - 06:24 PM
Hopefully the last lot of zinc plating.
Attached File  IMG_3330.jpeg   665.68K   5 downloads
Making a mould of a good wiper motor cog, these came out better than expected and when tested I tried to lock-up the drive and break it but it didn't. I have made both styles for the Lucas.
Attached File  IMG_3341.jpeg   261.61K   3 downloads
Attached File  IMG_3420.jpeg   386.85K   2 downloads
Can't work out my picture sizing, either too small and bad quality or too big and only get a few at a time. Too long out of the game.
Marty
#993 hanra
  • 11,033 posts
Posted 22 January 2025 - 07:37 PM
I like those battery case tops. And the wiper cog that’s hectic.
#994 LJ RB30
LJ RB30
  • 1,043 posts
  • Name:Trevor
Posted 22 January 2025 - 09:06 PM
Thank you Marty😁
Much appreciated that you have given us an update.
Your attention to detail is fantastic!
As always keep up the good work 👍
#995 Ice
  • 15,221 posts
Posted 22 January 2025 - 10:56 PM
Awesome build Marty but thats what i expect out of you now
Now you teased us with some entree pics how about the main course  :)
Colour  :)
#996 MictheAussie
MictheAussie
  • 236 posts
  • Name:Mic
  • Car:LJ
Posted 22 January 2025 - 11:51 PM
Thanks Marty. It was exciting to see this thread on the list again. You do such a great job building and documenting these restorations. Nice work.
#997 bat 53
bat 53
  • 521 posts
  • Name:albert
  • Car:lc gtr
Posted 23 January 2025 - 09:21 AM
get a permit and see you on sunday
#998 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 23 January 2025 - 04:46 PM
Thanks for replies, it actually feels good to be back on here.
Be patent Gene, I've got a lot to catch up on.
Last paint of the rims, then a set of new rubber fitted. Added the redlines, (got a guy out to do it)
Attached File  IMG_3434.jpeg   612.53K   2 downloads
Attached File  IMG_3682.jpeg   433.65K   3 downloads
Attached File  IMG_3820.jpeg   462.63K   3 downloads
#999 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 23 January 2025 - 04:53 PM
Seats fitted, I just need to get the chrome seat adjusters from somewhere.
Attached File  IMG_3524.jpeg   328.18K   3 downloads
Attached File  IMG_3525.jpeg   448.26K   3 downloads
Now for the exciting part. I got to drive it for the first time in 4.5 years. It was only down the drive as it and the LJ swap positions.
Make sure you turn the volume up.
https://youtu.be/AVa...ZprjwKh3IQXEvKc
#1000 bat 53
bat 53
  • 521 posts
  • Name:albert
  • Car:lc gtr
Posted 23 January 2025 - 04:58 PM
might have a set
Also tagged with one or more of these keywords: LC GTR, Restoration, 1971, The Marty Report, Girl Power
