The Sally Report
LC GTR Restoration 1971 The Marty Report Girl Power
1003 replies to this topic
#176 rodomo
  • 18,037 posts
Posted 18 April 2020 - 11:23 PM
I'm doing the same job on mine. What size hole are you drilling for the plug welds? I'm using 8mm
#177 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 18 April 2020 - 11:47 PM
Hi Maz,
Yeah great welder. Plug welding I set it to around your markings, butt welding old metal to new is about half that.
UPol copper weld through primer. I still like to drill out hole where primer is to get fresh metal for plug weld. I soon learnt that you may think you've done a good plug weld but it pops apart. Theres a few tips in doing good strong ones i've worked out.
Hi Clay, I was looking at the same price $1000 7 years ago when I found this one second hand with helmet, trolley gloves, apron, magnets etc for $600 and it had only been used to build a bench.
Marty
I got mine from adel tools also..ive been using the
Zinc weld through but not for the holes,just for the
back of the panel and around hole just to stop the
rusting.keen to try the copper as the zinc takes a good
24hrs before you can weld as it will just scratch off.
I drill my holes to 5mm and when i plug they end
up 8mm.try a couple on 5mm marty doing circular
motion and see what you think.
Cheer maz
Edited by madtoranajzedded, 18 April 2020 - 11:48 PM.
#178 claysummers
claysummers
  • 3,631 posts
  • Name:Clay
Posted 19 April 2020 - 07:49 AM
Bit slack I suppose but I use the zinc, spray on, clamp and drill 8mm hole well in to rear panel then weld dead centre. The zinc will melt in the weld pool and protect the weld. Exposed paint will often ignite but just squirt more on when cool.
#179 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 19 April 2020 - 01:14 PM
I drill 8mm in my welding side then use a 5mm to drill part way into receiving metal. Sometimes I drill 5mm all the way through and even put a weld on the other side to be sure.
I was plug welding 8mm holes straight onto receiver and really giving it a good filling then noticed some of them popping apart. Thats why I'm very cautious now and making sure.
Circular is the go! Quite satisfying getting a full flat weld hey Maz?  Those that don't play with metal or paint are missing some very rewarding experiences - a lot of shit ones too. HaHa
Marty
Edited by sibhs, 19 April 2020 - 01:15 PM.
#180 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 19 April 2020 - 08:02 PM
Focused on the left hand front guard that needs the most work. Replaced the rusted top sections and made up a piece for the top corner near door. This bit is tricky due to 3 panels all aligning in the one area. I seem to do work on an area then leave it for a while. Each time going back and improving the result. This area is getting close but I will do a bit more manipulation later.
Attached File  IMG_9550 (1).jpg   113.67K   12 downloads
Attached File  IMG_9551 (1).jpg   202.55K   9 downloads
Attached File  IMG_9554 (1).jpg   137.18K   9 downloads
Attached File  IMG_9549.jpg   141.24K   9 downloads
Attached File  IMG_9555.jpg   92.51K   9 downloads
Attached File  IMG_0695.jpg   151.12K   9 downloads
Attached File  IMG_0696.jpg   138.77K   10 downloads
Attached File  IMG_0698.jpg   132.85K   12 downloads
Attached File  IMG_0700.jpg   78.73K   12 downloads
Marty
#181 liswar2
liswar2
  • 1,524 posts
  • Name:Wazza
Posted 19 April 2020 - 09:03 PM
Hi Marty,
Good to see your covid-19 down time is going to a good cause.
Stay safe warren
#182 gad05
gad05
  • 421 posts
  • Name:Graham
  • Car:73 lj 2 door , 74 lj sedan.
Posted 19 April 2020 - 10:23 PM
Love your work Marty.
l always learn so much from your posts.
Great to see your dedication in restoring these great little cars.
Cheers Graham.
#183 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 20 April 2020 - 01:32 AM
Marty
Thats happened to me once too Marty.on the inner panel
the lower front guard welds to (below flutes) happened
when then surface was not sanded to clean metal and
there was abit of primer there.i only picked it up
because i wasnt happy with it and replaced it..
Love it when its flat with good penetrating welds mean
more time to do other areas than grinding grinding
grinding .the speed that your going i reckon you will
b flowing some jam come nxt summer..i like the color
you have chosen Sally.shes going to look beautiful.
#184 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 20 April 2020 - 09:39 PM
Evening All
Yesterday being Sunday is my work in the back workshop, not the front garage and no welding grinding day.
I did a bit more on the heater box assembly. Here's some of the progress pictures so far.
Stripping the box and finding it in pretty good shape. Getting that fan off was a struggle and I left the motor bolts in position because I know they're a bitch too.
Attached File  IMG_9988.jpg   188.44K   11 downloads
Paint stripping the bottom
Attached File  IMG_0133 (1).jpg   335.81K   9 downloads
Giving the top a clean and rust blast.
Attached File  IMG_0297.jpg   209.81K   7 downloads
One of the square fan cover bolt holes had rusted out. This is a new piece of metal I drilled and filed square and then welded in position. If you don't fix this you'll have trouble tightening the fan cover nuts.
Attached File  IMG_0138 (1).jpg   89.68K   8 downloads
These are counter sunk so used the ball peen hammer.
Attached File  IMG_0295 (1).jpg   104.73K   9 downloads
The fibreglass lug had busted off so that got Araldited back on.
Attached File  IMG_0274.jpg   184.09K   9 downloads
The flap was re-zinced so I replaced the tape. I found a plasterer tape to be very similar in feel.
Attached File  IMG_0623.jpg   138.42K   10 downloads
New material was required and that carpet you cover 4wd drawers and speaker boxes seems a good match.
Attached File  IMG_0626.jpg   139.23K   9 downloads
Re-zinced the base.
Attached File  IMG_0327 (1).jpg   99.39K   8 downloads
Pulled apart the motor and cleaned it all out.
Attached File  IMG_0287 (1).jpg   127.86K   10 downloads
Checking out how it goes back together against another set-up.
Attached File  IMG_0718.jpg   131.73K   8 downloads
Lubed up and testing the flap operation.
Attached File  IMG_0720.jpg   156.41K   9 downloads
I've tested the fan operation and direction is correct. Painted the motor zinc colour but left the cool cloth tape as is. I just need to sort out the heater core and fit foam to all the flaps and stuff and she'll be ready to be wrapped up and put away.
Marty
#185 claysummers
claysummers
  • 3,631 posts
  • Name:Clay
Posted 20 April 2020 - 10:09 PM
Job well done. What’s your zincing process Marty?
#186 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 20 April 2020 - 10:21 PM
Hi Clay,
clean-up the part first. Wire brush small bits then drop them off at the zinc platers.
Then pic them up before they lose anything.
Attached File  IMG_0322.jpg   193.9K   16 downloads
#187 claysummers
claysummers
  • 3,631 posts
  • Name:Clay
Posted 21 April 2020 - 07:26 AM
Thanks. Thought you were doing it at home.
#188 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 21 April 2020 - 08:32 PM
I looked into doing my own but don't have the room and some parts are too big. Plus zincing is cheap to get done anyway.
Heres some work on the passenger door I've been doing. Just cutting out the rust and welding in new steel.
Attached File  IMG_9813 (1).jpg   106.87K   14 downloads
Attached File  IMG_9815 (1).jpg   122.18K   12 downloads
Attached File  IMG_9816 (1).jpg   112.59K   14 downloads
Attached File  IMG_9817 (1).jpg   115.4K   11 downloads
Attached File  IMG_9818 (1).jpg   142.59K   13 downloads
Attached File  IMG_9819 (1).jpg   101.01K   12 downloads
Attached File  IMG_9820 (1).jpg   101.47K   12 downloads
Attached File  IMG_9821 (1).jpg   117.3K   13 downloads
Attached File  IMG_9822 (1).jpg   125.07K   13 downloads
Attached File  IMG_9823 (1).jpg   129.63K   12 downloads
Attached File  IMG_9884.jpg   164.42K   13 downloads
Attached File  IMG_0090 (1).jpg   161.4K   13 downloads
Removed the original welding dags with a cold chisel.
Attached File  IMG_0095 (1).jpg   94.27K   13 downloads
Attached File  IMG_0096 (1).jpg   106.19K   13 downloads
Marty
#189 rodomo
  • 18,037 posts
Posted 21 April 2020 - 11:34 PM
These car are a mess with welding debris :angry:
#190 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 23 April 2020 - 10:10 PM
Did a bit of light cleaning.
Firstly the tail light housing needed rejuvenating so I put them in a solution of hydrochloric acid and water for 10 mins. Seemed to work well.
Attached File  IMG_0650.jpg   279.19K   10 downloads
A bit of a before and after shot.
Attached File  IMG_0651.jpg   221.44K   10 downloads
Going through my indicator housings to hopefully make a left and right.
Attached File  IMG_0642.jpg   208.57K   11 downloads
Taking over the kitchen sink while Sally watches Poldark
Attached File  IMG_0643.jpg   204.48K   10 downloads
Managed to make up one side, I'll need to strip some light blue wire out of an old harness to make the other side.
Attached File  IMG_0672.jpg   178.98K   13 downloads
These plastic chrome housings looked very ordinary and I was cleaning them up to re-spray them with a chrome paint. I gave them a scrub with one of those stainless steel woolly cleaners you find under the sink. They came up amazing without damaging chrome.
Attached File  IMG_0645.jpg   217.02K   12 downloads
Marty
#191 claysummers
claysummers
  • 3,631 posts
  • Name:Clay
Posted 23 April 2020 - 10:41 PM
Great work. It’s amazing how good old chrome, apparently pitted and rusty, comes up with a decent clean.
Now finish those dishes.
#192 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 24 April 2020 - 08:02 PM
Heres a little tip/story about zincing.
Before I drop stuff off to my zinc platers I photograph all the bits next to their bag which has marked what it is.  Next it's all taken in bags in a box with colour (Silver, gold or Black) written on it.
I try and take them on a Monday or Tuesday so I can get them back the same week and they're not left in the factory over the week-end.  When they're ready I pick them up as soon as possible.
When home I un-wire them and using pictures sort out where they belong.
Well!   A couple of weeks ago I got some parts back and was missing the main pin from the gear selector/shifter.  I printed out my photo of the parts bag and went back to zinc platers asking if it was lying around the factory somewhere.  They couldn't find it so I left them the copy with my ph number.
I dropped by a week later and still no luck. I presumed it had fallen in to the bottom of the acid bath and dissolved.  Next day I get a call they had found it sitting on the fork lift still not zinced. They offered to zinc it and be ready tomorrow. I decided to pick it up because I was in the area and it doesn't need zincing and I don't want to push my luck.
It's worth chasing up these parts and if I hadn't left a photo or number it would of been found and they would've had no idea who's it was.
I will just wire brush the pin and it should come up ok.
Marty
Attached File  IMG_0523.jpeg   218.79K   14 downloads
Attached File  IMG_0775.jpeg   177.62K   12 downloads
Attached File  IMG_0323.jpeg   234.25K   10 downloads
#193 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 28 April 2020 - 08:18 PM
Painted the silver on to the tail lights. Little tricky getting the lines correct and avoiding over spray at the junctions.
Attached File  IMG_0300.jpeg   183.95K   12 downloads
Attached File  IMG_0301.jpeg   195.97K   13 downloads
Attached File  IMG_0820.jpeg   252.44K   17 downloads
Marty
#194 Cook
Cook
  • 1,530 posts
Posted 28 April 2020 - 08:55 PM
Good work as always Marty but I guess when it's the missus car she is keeping an eye on things.  Good point about detailing all the items sent away for plating.  Another thing I would note is that re-plating does create some brittleness.  As example I had my seat frames re-plated, which I was really happy with as they were in a really bad state, but some of the bent up tabs (if that makes sense) that wires fit to were too brittle to reuse.  You have done more work in 12 months than I have done in 6 years.  Cheers Ron
#195 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 28 April 2020 - 10:16 PM
Hi Ron,
I know what you mean about things getting brittle. I have found the clips that hold the heater box together break easily after zincing. I loose about 10% of them to breakage.
I was just going to mention it's been two years today since I started stripping the car. I picked it up last year on Anzac day and got into it a few days later.
Marty
#196 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 29 April 2020 - 08:59 PM
Celebrating one year of restoration on the car with a coffee on the deck.
#197 S pack
  • 15,722 posts
Posted 29 April 2020 - 09:50 PM
Hi Ron,
.I was just going to mention it's been two years today since I started stripping the car. I picked it up last year on Anzac day and got into it a few days later.
Marty
Nice one Marty. You don't happen to own a Delorean do you? :D
Love the coffee cups. Gotta get me some.
Dave.
#198 Ice
  • 15,200 posts
Posted 29 April 2020 - 10:24 PM
Arh now i know why your selling the Sprintys goin for the factory look on Sals car
#199 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 29 April 2020 - 11:00 PM
Dave.
BUGGER! Stuffed that up. Should of said ONE year ago.
Yep, Sals will be steelies.
#200 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 30 April 2020 - 09:31 PM
I’ve got a horn on!
Here’s some pics on getting it there.
Marty
Also tagged with one or more of these keywords: LC GTR, Restoration, 1971, The Marty Report, Girl Power
