The Sally Report
LC GTR Restoration 1971 The Marty Report Girl Power
1003 replies to this topic
#201 Ice
  • 15,193 posts
Posted 30 April 2020 - 09:38 PM
Yes but does your horn work Marty
#202 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 04 May 2020 - 10:27 PM
Some times I think I'm retarded!
Again I'm mucking about with a patch repair panel that I knew didn't fit. I went through all this with the LJ and didn't learn my lesson. I'm talking about the passenger outer sill, cutting it to fit and making the sill end is heaps of work that needn't be done due to full sill panels being available. I was just being a tight arse and trying to save $400.
Heres some of the days of mucking about that I've done and still not happy.
Attached File  IMG_0753.jpeg   71.96K   13 downloads
Attached File  IMG_0760.jpeg   186.07K   13 downloads
Attached File  IMG_0761.jpeg   268.87K   12 downloads
Attached File  IMG_0767.jpeg   156.97K   14 downloads
Attached File  IMG_0769.jpeg   152.42K   11 downloads
Attached File  IMG_0819.jpeg   116.31K   11 downloads
Attached File  IMG_0846.jpeg   85.37K   11 downloads
Attached File  IMG_0853.jpeg   218.13K   13 downloads
Attached File  IMG_0854.jpeg   166.38K   11 downloads
The real shitfight has happened after this bit as I try and line up the bottom lower guard. It has got a bit depressing so I've stopped work on this side, bought the full sill for drivers side and getting stuck into that.
#203 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 04 May 2020 - 10:38 PM
Attached File  IMG_0849.jpeg   138.7K   9 downloads
Attached File  IMG_0855.jpeg   183.88K   9 downloads
I've also had to cut the lower guard bit to fit. I've changed the shape by trying to improve lines and curves but mucking it up at the same time.
Attached File  IMG_0750.jpeg   79.96K   11 downloads
Pulled a crease out at the rear of sill. Really enjoying this stud welder.
Attached File  IMG_0763.jpeg   105.02K   8 downloads
Sort of getting there but have stopped work on this side for now. I may cut it all off and start again. Attached File  IMG_0857.jpeg   176.49K   11 downloads
Marty
#204 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 04 May 2020 - 10:47 PM
Also got the passenger floor fitted. Happy with this but another retard moment. This is my third floor pan I've fitted and every time I trim this corner too short. Here I've had to do some bridging welds to fill gap.
Attached File  IMG_0817.jpeg   121.91K   9 downloads
Attached File  IMG_0818.jpeg   149.65K   11 downloads
Also cutting off the overlaps in the repair panel to hide the fact it is a Rares repair panel
Attached File  IMG_0832.jpeg   112.67K   9 downloads
Attached File  IMG_0834.jpeg   149.03K   9 downloads
Attached File  IMG_0835.jpeg   103.79K   8 downloads
#205 rodomo
  • 18,031 posts
Posted 04 May 2020 - 10:49 PM
I made that bit square on the end rather than original so I can push a bit if seam sealer into it after the guard is on...……...but mine is only an S :mellow:
#206 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 04 May 2020 - 10:53 PM
How much easier is it fitting full panels that are made well. I love this repair panel. Well worth the $300. Don't be a tight arse - buy it.
Attached File  IMG_0920.jpeg   193.4K   11 downloads
Attached File  IMG_0923.jpeg   110.48K   10 downloads
Attached File  IMG_0924.jpeg   87.8K   11 downloads
Attached File  IMG_0926.jpeg   147.01K   11 downloads
Attached File  IMG_0929.jpeg   163.25K   12 downloads
Marty
#207 claysummers
claysummers
  • 3,600 posts
  • Name:Clay
Posted 05 May 2020 - 08:14 AM
It’s a hard call sometimes, and depends how you value your time. Is it labour or leisure what you are doing?
Very happy result with the driver side sill panel. Yes you paid the extra dollars but don’t discount your skill, oh and luck!
#208 _LONA-CK_
_LONA-CK_
Posted 05 May 2020 - 08:49 AM
Hi Marty coming along great mate and yes the aftermarket sills are the go mate I have not turned back since I started using them, for the amount of hours you will put into making them anyway. As to the gaping and bridging next time your at a welding supply shop grab yourself some Tig wire it comes in different thicknesses perfect for them jobs.
Cheers gong
#209 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 05 May 2020 - 09:59 AM
Still looks good Rob.
This has always been a leisure build so time is not an issue. If you did this for an hourly rate you have to use good full panels for client value. But I have found there's a limit between enjoying the build and wanting to burn it! This panel is my saviour.
Cheers gong
Hi John, thanks for the tip! I have some tig wire which I'll use when adjusting panel gaps etc.
Marty
#210 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 05 May 2020 - 10:09 AM
Rebuilt the shifter on the week-end. This took a couple of attempts and is like a chinese puzzle.
Attached File  IMG_0870.jpeg   111.04K   14 downloads
Painted the drive shaft hanging it on the washing line.
Attached File  IMG_0860.jpeg   278.74K   14 downloads
Attached File  IMG_0863.jpeg   267.18K   15 downloads
Tested the wiper washer. At first it wouldn't work but pulled it apart and freed the valves by gentle pushing them with stud. All good now.
Attached File  IMG_0880.jpeg   191.55K   11 downloads
Attached File  IMG_0881.jpeg   161.18K   12 downloads
Attached File  IMG_0882.jpeg   153.72K   12 downloads
Cleaned up the brake light switch and tested.
Attached File  IMG_0886.jpeg   227.61K   13 downloads
Marty
#211 claysummers
claysummers
  • 3,600 posts
  • Name:Clay
Posted 05 May 2020 - 12:27 PM
That red paint should be worth a couple of ponies
#212 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 16 May 2020 - 09:48 PM
I've no Idea what that means Clay?
I took a big step last week and welded the windscreen cowl on. I'd been waiting until I had the bonnet and hinges that are going on the car. So with my third bonnet and a brand new set of hinges (modified Rare Spares) fitted it was time to get all the guards on and confirm cowl was in the correct spot.
I had to pull the centre of cowl toward the back of the car to even up the gap then get welding.
It was pretty dirty under there.
Attached File  IMG_0949.jpeg   134.16K   17 downloads
All cleaned up
Attached File  IMG_0953.jpeg   200.86K   13 downloads
I tried Johns tip on using wire to fill a gap. Thanks Mr Gong.
Attached File  IMG_0955.jpeg   127.41K   10 downloads
Attached File  IMG_0956.jpeg   204.75K   12 downloads
Before plug welding I run the spot weld drill over the copper coat to give me fresh metal.
Attached File  IMG_0958.jpeg   253.56K   12 downloads
Attached File  IMG_0962.jpeg   137.91K   12 downloads
It's so close to welding the guards on but so far. I'm not 100% happy with fitment so I've moved on to other areas of rust and will leave the guards til later.
Attached File  IMG_0968.jpeg   159.47K   10 downloads
Attached File  IMG_0969.jpeg   168.09K   10 downloads
Attached File  IMG_0970.jpeg   166K   9 downloads
Marty
#213 claysummers
claysummers
  • 3,600 posts
  • Name:Clay
Posted 16 May 2020 - 10:03 PM
“That red paint should add a few ponies”
Back in my day we would paint bits of driveline red to give a perceived hot up. Eg brake drums, rims, rear axle, tail shaft.
#214 claysummers
claysummers
  • 3,600 posts
  • Name:Clay
Posted 16 May 2020 - 10:06 PM
Very inspiring the way you go about the body work Marty
#215 Indy Orange
Indy Orange
  • 2,920 posts
  • Name:Paul
Posted 17 May 2020 - 11:56 AM
Great work Marty,better than new when finished!
#216 Rockoz
Rockoz
  • 4,020 posts
  • Name:Rob
Posted 17 May 2020 - 01:55 PM
If you are drilling down to fresh metal for the welds, why not use KBS or POR to paint it instead of the coppercoat?
Both of them offer far better rust protection for the rest of the areas.
When hot they tend to melt a bit before they burn off, so with quick welds, you would get better rust protection in the future perhaps?
Rob
#217 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 17 May 2020 - 09:12 PM
Thanks Clay
Now I get it.  This is just painting it to look original though.
Lets hope so, Thank-fully I don't think Holden set the bar to high.
Rob
Thanks for your input Rob.
I hate welding anywhere near KBS, it stinks, pops and farts and I don't think it has any rust protection once it's been fried. Even the copper coat piss farts around when welded over so I think clean metal at the welds gives a cleaner, stronger weld.
The key to rust protection IMO is covering the whole car in KBS Rust Blast inside and out on a rotisserie leaving a zinc rich coating. Once dry paint well into the cavities then when still on rotisserie flood cavities with cavity wax and spin the car.
Then don't get the car wet! This system has worked amazingly on the LJ's 6.5 year old paint.
Marty
#218 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 17 May 2020 - 09:35 PM
Finally got the console together. A friend insisted I get a genuine centre console rather than the Rare version which is not a good copy.  So I grabbed a second hand model that had a good base, cleaned it up and then gave it a coat of Auto Glym.
I purchased the trim and boot from Rares as they're good, then fitted. Hardest part was removing some of the old ferrules.
Firstly I tested the screw holes to the body holes, they didn't line-up which is weird because holes in body looked genuine. Not sure if the Opal centre console is different to all aussie for fixing holes?
Attached File  IMG_0932.jpeg   124.25K   12 downloads
Attached File  IMG_0284.jpeg   189.45K   9 downloads
Attached File  IMG_0286.jpeg   179.32K   9 downloads
Attached File  IMG_0285.jpeg   175.34K   8 downloads
Attached File  IMG_0985.jpeg   167.37K   7 downloads
Attached File  IMG_0984.jpeg   131.8K   8 downloads
Attached File  IMG_0987.jpeg   165.46K   8 downloads
Attached File  IMG_0992.jpeg   119.47K   8 downloads
Attached File  IMG_0993.jpeg   142.47K   7 downloads
Marty
#219 S pack
  • 15,691 posts
Posted 17 May 2020 - 09:52 PM
Nice job Marty. That console cleaned up well. Trim those metal studs off on the vinyl gear stick gaiter mount flush with the retaining nuts.. They will chew the crap out of your lower rubber shift boot if you leave them as they are.
Edited by S pack, 17 May 2020 - 09:53 PM.
#220 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 17 May 2020 - 11:11 PM
Thanks Dave, never thought of that - You're a genius
#221 71xu1
71xu1
    Dave
  • 1,274 posts
  • Car:LC GTR XU1
Posted 18 May 2020 - 12:36 AM
Yes Opel console is different not just the mounting holes, different outer surround , different construction/texture and different shifter surround. I can post a pic if you like.
#222 Indy Orange
Indy Orange
  • 2,920 posts
  • Name:Paul
Posted 18 May 2020 - 12:44 AM
Like this.Its an Opel one.
Edited by Indy Orange, 18 May 2020 - 12:46 AM.
#223 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 18 May 2020 - 08:43 AM
Thanks guys, that's a relief. I'll weld up holes and re drill at a later date.
Marty
#224 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 18 May 2020 - 06:19 PM
If you haven't got original console screws and washers Marty, i keep them in stock, as a matter of fact, i have a lot of factory style screws on hand. Just let me know if you need any. Gary.
#225 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 19 May 2020 - 09:54 PM
Thanks Gary, I'll text you soon.
Just received the last bits for the seat tilt mechanism. I got new plastic spacers and a couple more bits from the zincer.
It took about three goes and the manual and checking the LJ to get it right.  I think it's right. Used my brand new tool kit so not to get any grease on seats.
Attached File  IMG_1038.jpeg   177.33K   13 downloads
Marty
Also tagged with one or more of these keywords: LC GTR, Restoration, 1971, The Marty Report, Girl Power
