Made my own oil catch can. Didn't like anything else...
12 replies to this topic
#1 _Gunmetal LH_
_Gunmetal LH_
Posted 08 July 2019 - 12:23 AM
Couldn't find what I wanted in a catch can.  All were too big, too small, not filtered, too finely filtered, connections in odd spots or silly angles, too expensive or plain old looked like s#!t.
Modified an alloy overflow with a sight glass which used crappy push-loc connections with some plastic tube that's used on bloody fish tanks.
Never seen one more than a month old that hadn't turned so brown you couldn't see what level it was at.
Changed that to Orings and some borosilicate glass (Pyrex) cut the back open and put some mesh in to retain some SS scourers and soldered it back up- killer!
Went to put it in the car and it was too bloody big!
So I made my own.  Second attempt at aluminium soldering...
Filtered, baffled, recessed borosilicate sight glass, drain plug, removable from the bracket with just a clip, and hose barbs right where I wanted them.
Started with a bit of aluminium sheet, trimmed it up, and bashed my sight glass section into it.
Attached File  DSC_2286sm.jpg   215.12K   5 downloadsAttached File  DSC_2287sm.jpg   214.18K   3 downloads
Got it pretty even first go.  Rolled it up and soldered it before realising it was about the same size as the last one that was too big so I cut out a strip 2.5"ish and soldered again.
Attached File  DSC_2290sm.jpg   207.72K   7 downloadsAttached File  DSC_2292sm.jpg   211.4K   6 downloads
Attached File  DSC_2360sm.jpg   217.73K   5 downloadsAttached File  DSC_2359sm.jpg   225.87K   7 downloads
Attached File  DSC_2362sm.jpg   214.2K   7 downloadsAttached File  DSC_2364sm.jpg   214.09K   5 downloads
But wait, there's more...
#2 _Gunmetal LH_
_Gunmetal LH_
Posted 08 July 2019 - 12:51 AM
And then...
Attached File  DSC_2391sm.jpg   220.22K   5 downloadsAttached File  DSC_2415sm.jpg   223.2K   4 downloads
Attached File  DSC_2417sm.jpg   215.93K   3 downloadsAttached File  _20190518_144132sm.jpg   67.27K   3 downloads
Figured polished would not suit the rest of my engine bay (VY SS) so wrinkle black it is!
Attached File  _20190518_132740sm.jpg   9.01K   3 downloadsAttached File  _20190518_132609sm.jpg   19.63K   3 downloads
Attached File  _20190518_131532sm.jpg   38.32K   3 downloadsAttached File  _20190518_143559sm.jpg   14.68K   3 downloads
Was tightening the bracket and *Ting* yep, snapped at the top bend, pretzeled the bottom.
Soooo redesign that bit with a fill-in piece and full loop for the bottom bolt.  Function over fashion- not pretty, but it works.
Attached File  DSC_2444sm.jpg   212.42K   3 downloadsAttached File  DSC_2448sm.jpg   223.68K   3 downloads
Attached File  _20190523_162258sm.jpg   35.65K   3 downloadsAttached File  DSC_2536sm.jpg   302.23K   2 downloads
#3 ido09s
ido09s
  • 337 posts
Posted 08 July 2019 - 12:38 PM
no baffles inside it?
#4 _Gunmetal LH_
_Gunmetal LH_
Posted 08 July 2019 - 09:37 PM
Yes, has 1 full height, about 2/3 across. Made some vertical cuts to make 4 legs and bent almost level so it would hold itself in place while I soldered the bottom on.
Sort of jambs itself in there and also holds the SS scourers in place.  Did a "shake the s#!t out of it" test and they stayed put.
You can see the SS scourers and the bottom of the baffle through the drain plug.  It exteds to the right just past the edge of the thread.
Attached File  _20190518_143559sm.jpg   14.68K   5 downloads
2 minute MSpaint rendering...
Attached File  Baffle.jpg   8.14K   4 downloads
Sealed it to keep each side properly seperate with black silastic and a BBQ skewer 'applicator'.
#5 RallyRed
  • 8,213 posts
Posted 09 July 2019 - 08:27 AM
luv the bracket...very cool
#6 _Gunmetal LH_
_Gunmetal LH_
Posted 09 July 2019 - 11:36 PM
Didn't want to have to unbolt anything to remove.  Sort of made up the design as I went along with the stuff I had.
Would do a plate into a thin & wide C section next time.
#7 Heath
  • 18,403 posts
Posted 10 July 2019 - 12:26 PM
That is pretty trick Peter!
A lot of work went into that.
Now... Torana parts?
#8 _Gunmetal LH_
_Gunmetal LH_
Posted 11 July 2019 - 12:28 AM
Yeah, getting there.  No room, need a bigger place with a garage I can actually use then it will be full steam ahead.
Constantly collecting Torana bits and pieces in the meantime.  One day!
#9 _Gunmetal LH_
_Gunmetal LH_
Posted 11 July 2019 - 12:47 AM
Been practising techniques for now.  ^ was a first go at alloy soldering.
#10 Rockoz
Rockoz
  • 4,065 posts
  • Name:Rob
Posted 11 July 2019 - 09:36 AM
Like pretty much all types of soft soldering, you need to take into account that solder has very low mechanical strength properties.
Doesnt seem like it will be an issue with what you are doing so far though.
But keep it in mind as you experiment with your new found trick.
I started doing aluminium soldering back in 1978.
Was very frustrating back then. The new types of solder werent available.
So many bits I wanted to join just melted away into a puddle until I got the hang of it.
The new stuff is so much easier to use.
#11 Heath
  • 18,403 posts
Posted 11 July 2019 - 10:49 AM
I saw some little promo video on Instagram or whatever about this kind of solder product. I've never played with it.
But if you can fabricate all of the above kinda shit with it (and that is properly cool work you've done!) then it'll be very easy for you to step into making interesting stuff with a better gluing process (eg. TIG welding)
#12 _Gunmetal LH_
_Gunmetal LH_
Posted 12 July 2019 - 11:02 PM
Found the solder easy but the alloy difficult to work with.
It's like the oxide layer is holding things in place while the inside is aaaaaalost molten.  In low light it would just get a very dull red glow to it when it was just right.
You'll see the gray areas around where I heated it.  Too much and it would sag/blob- you'll see that too.
Bit like welding butter with the exact same butter, but you have to preheat the butter as it acts like it's on a block of ice if you don't the way it dissipates heat through itself.
So you get it juuuust right, then blob.
Have been planning to get a TIG one day.  Looks more versatile than my MIG.  Got lots of ideas to build...
#13 Rockoz
Rockoz
  • 4,065 posts
  • Name:Rob
Posted 13 July 2019 - 09:36 AM
Yep.
The oxide on the outside of the aluminium has a higher melting temp than the clean aluminium.
That is why it is always said that you need to clean aluminium properly before any type of welding operation.
And when you need to do a long run, you do it in stages.
Have seen close to a foot of aluminium weld just drop out of a join because it got too hot.
Was a rather expensive mistake too. it was about an inch wide as well. 10mm plate.
Once you get the hang of it though it doesnt seem so hard to do.
But you need lots of practice bits before you tackle the real thing.
