Aftermarket wiring harnesses kits
Wiring harness kit
8 replies to this topic
#1 71xu1
71xu1
    Dave
  • 1,275 posts
  • Car:LC GTR XU1
Posted 06 August 2019 - 09:10 AM
Has anyone used a Proflow wiring kit, EZ wiring kit or painless wiring kit? I am doing a rewire soon and I am just wanting people's experiences in using them and which one they used.
Cheers Dave
#2 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 06 August 2019 - 09:52 PM
Why would you want to put an obviously aftermarket wiring harness, in an xu1 ? You still have to terminate half the ends, mount it all ect. When you could reproduce the gmh harness, withmall new connections from all auto creations, or whatever Aaron calls his business and it looks correct & is new & reliable. Gary
#3 71xu1
71xu1
    Dave
  • 1,275 posts
  • Car:LC GTR XU1
Posted 06 August 2019 - 10:42 PM
Thanks for the reply but not for my XU1.
#4 jpxu1
jpxu1
  • 571 posts
Posted 06 August 2019 - 11:16 PM
Whew  :wacko:
#5 _Drag lc_
_Drag lc_
Posted 07 August 2019 - 08:01 AM
i have used a painless kit for my car its far from std but took a little bit to graft in but was one of the best things i did to it get rid of the old gtr wiring and dash as like most things over the years everyone had added and played around with the original harnesss. original harness and gtr dash is all packed away.
as mine is efi i just used the painless for the general lights and ign.
cheers H
#6 myss427
myss427
  • 1,636 posts
Posted 07 August 2019 - 08:39 AM
Used the EZ Sportsman loom, quite easy to install, but you still run the Holden loom. Worst thing is the EZ loom is a little long in most areas, requires winding it upp and tapping it, makes it bulky under dash. If your a good sparky you could cut it.
#7 Cook
Cook
  • 1,531 posts
Posted 07 August 2019 - 11:40 AM
I was going to use a painless kit before my auto elec. suggested I stay with the original due to good condition.  One thing with the Painless, as I understand it, it is made for the US market and you need to adapt it.  I think there are a couple of things but one is they only have a single wiring for rear brakes and indicators (run as one) if my memory is correct.  Cheers Ron
Edited by Cook, 07 August 2019 - 11:41 AM.
#8 myss427
myss427
  • 1,636 posts
Posted 07 August 2019 - 02:21 PM
Also with the painless, its wires are heavier gauge and when tapped up like a loom they are bulkier around the instrument cluster etc.
#9 _Drag lc_
_Drag lc_
Posted 08 August 2019 - 08:23 AM
yeah i adapted the painless one it wasn't that difficult for my application, i could imagine things could get difficult if your using a gtr style dash.
cheers H
