LC Ammeter Terminals
Posted 25 August 2019 - 03:59 PM
I am putting the wiring back in my LC after about 10 years and about to install the dash. The car had a standard loom altered to suit GTR dash.
For the ammeter I have 6mm cable from the alternator to the ignition,light switch,fuse box (previously in standard form this was fed from the fusible link) and the old fusible link cable is extended and runs direct to the ammeter.
My question is which wire to connect to which terminal on the ammeter. Ammeter has GEN and B marked so I assumed that GEN indicates generator or alternator but is this correct?
Thanks Simon
Posted 25 August 2019 - 06:00 PM
Posted 25 August 2019 - 06:04 PM
Posted 25 August 2019 - 06:12 PM
Posted 25 August 2019 - 07:18 PM
Looking at the LJ GTR wiring diagram the fusible link wire connects directly to the B connection on the ammeter and the GEN connection feeds into the RED main power wire that connects to terminal 7 on the fuse panel, the ignition switch, the headlight switch and back to the B+ or B connection on the alternator.
Posted 25 August 2019 - 07:42 PM
Alternator wire into the car feeds into the fuse box, ign switch, lights switch and is spliced to a wire that terminated at the ammeter.
Fusible link wire into the car has been extended and terminates at the ammeter no other connection on this wire.
Thanks for the assistance, I will wire as per your reply to the ammeter.
Simon
Posted 21 November 2024 - 09:40 AM
g'day all
i know its an old thread
would anyone have a photo of the back of the amp gauge
which terminal is which
can't read mine
thanks Albert
Posted 21 November 2024 - 07:02 PM
Hope this helps.
Edited by Indy Orange, 21 November 2024 - 07:06 PM.
Posted 21 November 2024 - 08:33 PM
thanks paul much appreciated
