XU1 header engine pipe flange plates
25 replies to this topic
#1 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 21 September 2019 - 12:45 PM
I am looking for a source for the flange plates. Unobtanium according to the guys at well hung exhausts Lonsdale.
The stud spacing appears to be 2 3/4ā€, and engine pipe 1 3/4ā€, which seems close to factory 186. I have tried searching on here. Can anyone advise please?
#2 _LC870_
_LC870_
Posted 21 September 2019 - 01:22 PM
Hi  there .
I  can  help  you  out  with  a  good  pair  of  original  flanges .
Regards  LC870
#3 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 21 September 2019 - 02:38 PM
Hey thanks LC870 Iā€™ll pm you
#4 Dr Terry
Dr Terry
  • 3,325 posts
Posted 21 September 2019 - 07:08 PM
The XU1 flanges are the same as single exhaust EH/HD 149/179, which is smaller than stock 186. Obviously they are also the same as 179/186 X2, 161S, 173S & 186S.
Dr Terry
#5 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 21 September 2019 - 07:41 PM
Thanks doc terry, I thought so as I had measured a 149 exhaust manifold stud spacing at 71mm. I since disposed of the manifold so I couldnā€™t confirm. I actually have a 186s and an 186x2 set to go in my FB ute. If all else fails I will find two used 149 units.
Interesting the guy at the exhaust shop didnā€™t know this as he had a Holden wrecking yard for ten years.
Clay
#6 dattoman
  • 16,487 posts
Posted 21 September 2019 - 11:37 PM
As far as the exhaust industry is concerned... pressed metal flange plates are a thing of the past
Now its 10mm laser cut flat flanges
Still some pressed ones about though... just takes some looking
#7 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 22 September 2019 - 01:37 AM
Thanks datto and thatā€™s what Iā€™ve seen on line. They could be made to work with a bit of chamfering. Finding the right dimensions would be the hard part. Iā€™m in no big hurry and something will turn up. Thanks to LC870 and Dr Terry I should be sorted.
#8 u1 71
u1 71
  • 478 posts
  • Name:peter
  • Car:torana
Posted 22 September 2019 - 07:56 PM
autopro next to suttons homebush had a box of them as well as other nos parts but the buildings now been sold don"t know were autopro has moved to though
#9 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 08 October 2019 - 11:54 PM
Havenā€™t heard anything from you LC870. Do you still have flanges?
Looking at the FX to HR MPC part numbers for FX to HD and HR X2 and S exhaust packing gasket are the same, indicating same 1 3/4ā€ engine pipe. There is no listing for HR X2 and S flange, but the listing for EH HD indicates 1 or two pieces. I take this to mean two flanges for the HD X2.5b2d1d75bcf30da8783aeb83426a5913.jpg
This confirms Dr Terryā€™s information, not that I doubted it. Just that my exhaust shop contact did.
I also see Brad Merrick has enlarged the pipe hole from stock on his repro XU1 systems. He doesnā€™t seem to have a listing just for the flanges though.
This information may help others I hope. Meanwhile Iā€™m still hunting.
Clay
Itā€™s only for a smelly old FB of course......
Edited by claysummers, 08 October 2019 - 11:55 PM.
#10 Dr Terry
Dr Terry
  • 3,325 posts
Posted 09 October 2019 - 07:27 AM
The reason that they don't list the flanges separately for the HR X2 & 186S engines is that the engine pipe is a 'Y' pipe & the flanges can't be removed. The same goes for the later GTR & XU1 engines.
The HD X2 had 2 separate engine pipes going to a muffler with 2 inlets.
Dr Terry
#11 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 09 October 2019 - 08:14 AM
Thanks Dr Terry. Makes sense.
#12 dattoman
  • 16,487 posts
Posted 09 October 2019 - 09:00 AM
Just find some old Holden exhausts and cut the pressed flanges off
Or better yet... get your sizes and Mr China will make you 100 and you can sell some off for a profit
https://www.liangfei...e/56439360.html
If I was still working at the exhaust place I'd grab you a few... but I don't have access to that warehouse anymore... and no-one there I know who's bright enough to find them
#13 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 09 October 2019 - 11:07 AM
Thanks for that link datto. They look a bit thin gauge. The factory ones are even a bit thin at 2mm. Like you say Iā€™ll make the trip to old duds. He must have 100 EH and HDs.
Clay
#14 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 15 October 2019 - 12:21 PM
Sent you a pm LC870
#15 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 09 November 2019 - 09:23 AM
Found these
https://sonicinjecti...der-plates-xu1/
Sonic injection flanges to suit red six cast headers $40 a pair
Cut from sheet as per current process rather than pressed like original
Should work better as the originals bend
#16 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 09 November 2019 - 09:25 AM
Out of stock doh!
#17 Cook
Cook
  • 1,531 posts
Posted 09 November 2019 - 10:12 AM
There's a waterjetting cutter in Melbourne that does flanges etc, MRC Waterjetting.  Maybe someone in SA can do it, just need to give them the dimensions.  Cheers Ron
#18 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 09 November 2019 - 11:41 AM
Thanks Ron. Food for thought.
Sent from my SM-A705YN using Tapatalk
#19 goxu1
goxu1
  • 690 posts
  • Name:Paul
  • Car:4/73 Cyan Metallic GTR XU-1
Posted 09 November 2019 - 09:02 PM
Get me some dimensions and I can laser cut some
#20 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 10 November 2019 - 08:44 AM
Paul,
Thanks for the offer.
10mm holes on 71.5mm centres.
Centre hole 49mm.
I have added 1mm to the standard hole size (48mm) per Brad Merrickā€™s suggestion for improved sealing and pipe life.
Brad states the stud centres are 72.5mm +/-0.5mm, but the two sets I have are 71.0mm.
Clay
#21 meanmachine72
meanmachine72
  • 2,036 posts
  • Name:Jono
Posted 16 May 2020 - 12:47 PM
Luke from sonic injection is making another run of flanges and should have them done by 22/5/2020
0412207547
#22 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 16 May 2020 - 01:00 PM
Cheers. I'm on it.
#23 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 23 May 2020 - 03:47 PM
Ordered a set from Luke, thanks.
Then I visited my mate with 5000 cars in the back yard and scrounged two from EH engine pipes. He socked me $5 for the pair. Mates rates I suppose.bc2056704d3d0da35b36c4d79b224a3a.jpg
#24 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 04 June 2020 - 08:55 PM
Sonic flanges came today from Barmera. Good turn around. Cut from flat sheet so may not suit purists. I'll be happy if the do the job. They're going in an FB after all.87c484d1f542c30a6bf7eed09ed7422d.jpg
#25 meanmachine72
meanmachine72
  • 2,036 posts
  • Name:Jono
Posted 05 June 2020 - 09:34 AM
yep i got mine a few days ago,exhaust guys like them so cars about to get another tow truck ride
