LH G-pak
43 replies to this topic
#26 Big_Red
Big_Red
  • 79 posts
  • Name:Aaron
  • Car:LH Torana
Posted 05 January 2020 - 10:28 AM
Original 298mm disks? Smallest wheels om a ba falcon where 16". With the smaller disk size there is good clearance, id say most 15" wheels would fit.
Even at 286mm thats still a reasonable size disk for the weight of the car. huge upgrade over original. I chose QFM A1RM pads which are rated 0-800c ive used them before and they work well enough on the street and good for a couple of hard laps at the track. My nissan is probably a smidge lighter with 280mm disks and unknown pads. Thats never came close to experiencing fade.
Edited by Big_Red, 05 January 2020 - 10:33 AM.
#27 Big_Red
Big_Red
  • 79 posts
  • Name:Aaron
  • Car:LH Torana
Posted 22 March 2020 - 05:59 PM
Has been some descent progress made on the shell.
#28 jeffblanco
jeffblanco
  • 379 posts
  • Name:Mando
Posted 22 March 2020 - 06:46 PM
Aaron,
why are there six hole for the booster?
Looks great!
Regards Mando.
#29 Heath
  • 18,380 posts
Posted 23 March 2020 - 07:55 AM
Looking good.
Sorry, what brake kit is that? Is that UPC's kit with their own hubs? What pattern are you using?
#30 Big_Red
Big_Red
  • 79 posts
  • Name:Aaron
  • Car:LH Torana
Posted 23 March 2020 - 08:16 AM
Aaron,
Looks great!
Regards Mando.
Thats a very good question. I had not taken any notice of that before.
Looking good.
Its kind of a cobbled together kit. It was ment for a hq-hz. But i found on this forum you could bolt the hq brakes onto torana knuckles, only real modification is turning down the disks to a smaller diameter. So i figured i could do the same with a aftermarket kit. I found the hubs and adaptors on ebay, i dont believe they are the UPC kit. I milled down the disks and redrilled them also. We are using chev/HQ pattern on this car.
#31 Heath
  • 18,380 posts
Posted 23 March 2020 - 08:48 AM
Cool. That's actually a perfectly good idea I think - as long as it clears what i needs to around the upper arm & steering system.
I believe that your car has at some point been fitted with a master directly to the firewall - like what I have done with my car. Only the original booster holes were not welded up.
Mine:
wdIiJbc.jpg?1
Edited by Heath, 23 March 2020 - 08:54 AM.
#32 Big_Red
Big_Red
  • 79 posts
  • Name:Aaron
  • Car:LH Torana
Posted 23 March 2020 - 11:19 AM
Asked the previous owner and he said he believes they are factory. A quick google search shows quite a lot of firewalls having 6 holes at the brake booster. Our car hadnt been messed with too much so im lead to believe they are factory on the LH. Maybe not all LH.
#33 warrenm
warrenm
  • 2,117 posts
  • Car:1972 LJ Torana
Posted 24 March 2020 - 06:10 AM
Was the LH available as a drum brake car? This may explain the other 2 holes.
#34 yel327
  • 13,608 posts
Posted 24 March 2020 - 07:29 AM
Yes it was.
#35 Big_Red
Big_Red
  • 79 posts
  • Name:Aaron
  • Car:LH Torana
Posted 25 March 2020 - 06:41 AM
So different booster? Or non assisted?
These where also sold in a heap of different markets aswell. Imagine that, a time when we actually made and exported cars....
#36 Heath
  • 18,380 posts
Posted 25 March 2020 - 10:01 AM
I've seen Toranas with stocko masters bolted straight to the firewall, but not sure if that's a factory drum brake car format or not.
Also, you would still see the other four regular brake booster bolts, so that doesn't sound like a factory configuration.
#37 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 25 March 2020 - 11:24 AM
Yep even LX's came with drum brake front and no booster if optioned. Only seen one though in my time.
#38 Big_Red
Big_Red
  • 79 posts
  • Name:Aaron
  • Car:LH Torana
Posted 13 April 2020 - 04:59 PM
Underside has now been finished. Was primed, stone guarded in some areas and painted. The paint was surposed to be a matt finish but even with putting it on dry it has come up fairly glossy. We dont intend on looking at the underside (unless i flip it haha) so in the grand scheme of things it doesnt matter that much.
#39 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 13 April 2020 - 06:06 PM
Paint sheen looks like it should as far as I'm concerned. I wouldn't keep putting it on dry though, stir it really well, let it sit for 5 minutes then shoot it, I presume it's 2 pack ? Main thing is to thoroughly stir the colour every time, for at least 5 minutes to keep the consistency.
#40 claysummers
claysummers
  • 3,601 posts
  • Name:Clay
Posted 13 April 2020 - 06:10 PM
Stirring is extra important if flattenerhas been added to the paint, otherwise it settles to the bottom and doesn’t end up on the car.
#41 Big_Red
Big_Red
  • 79 posts
  • Name:Aaron
  • Car:LH Torana
Posted 13 April 2020 - 09:54 PM
The old boy is the one doing the paint work, he sent me threw these today. I surgested trying to put it on dryer to maybe give it a bit more texture finish. Im a mechanic not a painter or panel beater haha.
#42 Shiney005
  • 9,537 posts
  • Car:Toyota Mirai
Posted 14 April 2020 - 11:38 AM
Aaron,
I have been trying to track down the date for the change from six hole to four. Brads 5000 is October '75 and his has the six, while LS1 Taxi's 76 LX doesn't, but I don't know what month his car is. It might have been at the LX model changeover.
#43 yel327
  • 13,608 posts
Posted 14 April 2020 - 12:14 PM
In a HQ-HJ when they were all wheel drum without a booster they only has the two holes with the nuts welded behind. You had to drill the holes for a booster if you wanted to add one. I would have thought Torana would have been the same, that is if it had all wheel drums without a booster it only had the captive nuts. But if it had boosted drums or front discs the 4 extra holes were drilled.
HJ became standard with front discs roughly in line with LX release, so theoretically volume production LX should only have 4 holes, but LX prior to volume production may have 6 holes if fitted with a booster?
Edited by yel327, 14 April 2020 - 12:17 PM.
#44 Big_Red
Big_Red
  • 79 posts
  • Name:Aaron
  • Car:LH Torana
Posted 16 April 2020 - 01:31 PM
While ever there is a chance that non booster was a option they would have continued with the 6 holes. When they desided to discontinue the 6 hole there would have been a surplus of several thousand firewall stamped panels. With production its cheaper to make 1 part that will fit all models rather then 2 separate parts which means doubling up on stock lines and also changing the stamping. A good example of this is when most vehicles will have factory foglights, usually only one front end loom will be made with wiring provisions for foglamps.
