My LC/J Torana Coupe
130 replies to this topic
#1 Gatti
Gatti
  • 344 posts
  • Car:LJ 2 Door
Posted 06 November 2019 - 05:20 PM
Hi,
I thought I'd start a new thread for my new Coupe that I picked up last week and drove back to Sydney from Hobart  :D
It's an LC that has been mocked up as an LJ.
The paint is new and it just needs a bit of a tidy up in the interior with new door cards and retiming the seats.
I drove it back over two days and fell in love with it on the way.
Bloody stoked with her.
That Idle :)
Edited by Gatti, 06 November 2019 - 05:24 PM.
#2 Liz Clare
Liz Clare
  • 683 posts
  • Car:LJ GTR XU1 and LX SS
Posted 06 November 2019 - 05:51 PM
Looks and sounds great.
Love red cars
Cheers,
Liz :)
#3 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
  • Car:1971 LC 4 door
Posted 06 November 2019 - 06:11 PM
It’s a ripper
well done
#4 claysummers
claysummers
  • 3,600 posts
  • Name:Clay
Posted 06 November 2019 - 06:52 PM
Well done Matt
Sent from my SM-A705YN using Tapatalk
#5 jd lj
jd lj
  • 2,112 posts
  • Name:James D
  • Car:LJ SVO
Posted 06 November 2019 - 08:20 PM
It looks great, enjoy it.
JD
#6 Ice
  • 15,193 posts
Posted 06 November 2019 - 09:02 PM
Great looking Torana you done well
#7 71xu1
71xu1
    Dave
  • 1,274 posts
  • Car:LC GTR XU1
Posted 07 November 2019 - 01:39 AM
Very nice.
#8 Cook
Cook
  • 1,525 posts
Posted 07 November 2019 - 08:01 AM
Nice one Matt.  I bet you kept a close eye on it on the way over on the boat.  Enjoy. Ron
#9 RallyRed
  • 8,111 posts
Posted 07 November 2019 - 08:22 AM
Very nice....sounds the goods too!
#10 gtrboyy
gtrboyy
  • 3,208 posts
Posted 07 November 2019 - 02:34 PM
Miss the sound of a nicely worked 6cyl.Nice pickup.
#11 Gatti
Gatti
  • 344 posts
  • Car:LJ 2 Door
Posted 01 February 2020 - 11:45 AM
I haven't posted for a while so I thought I'd share some updates.
I've done a few things to the car since I bought it.
I added a Bocam rocker cover and fitted a catch can
I also fitted a new VDO oil pressure gauge and sender as the one in it didn't work (I'm keeping an eye out for a genuine gauge)
I took my daughter and her best friend to the Year 6 Formal in the Tory
I have also joined the Sydney Torana Club and attended a few events
Finally I picked up some 3.55 diff gears so I can swap out the 3.08 to make it a bit more fun to drive. I'll fit them next weekend when the gasket kit arrives.
#12 Heath
  • 18,378 posts
Posted 01 February 2020 - 01:55 PM
What a sweet looking car.
Sits well etc... really not much you need to do. Just make it drive as well as possible.
Might need to throw a decent slippery in that 3.55 gearset while you've got it apart.
#13 Ice
  • 15,193 posts
3.55 s get ready for another clutch lol
#14 Gatti
Gatti
  • 344 posts
  • Car:LJ 2 Door
Posted 01 February 2020 - 09:30 PM
Thanks mate.
The seats are.buggered but I’ll get them sorted out soon then she’s a great little car.
I want to fit these gears to try and if I like them I’ll try and get a truetrac LSD the same ratio to fit
#15 S pack
  • 15,689 posts
Posted 02 February 2020 - 08:43 AM
Don't forget to change the speedometer driven gear in the gearbox to suit.
If you do a fair bit of highway/motorway cruising the engine will be revving its ring off with a 3.55:1 diff.
3.36:1 would be my choice.
#16 Gatti
Gatti
  • 344 posts
  • Car:LJ 2 Door
Posted 02 February 2020 - 10:06 AM
Can you still buy the speedo gears new?
Also below is what I’ve worked the RPM would be at 100k’s with my 205/60/13 tyres
3.08 would be 2700rpm (and it is with the current centre)
3.36 would be 3100rpm
3.55 would be 3300rpm
I don’t think 3300rpm is too bad and it doesn’t do a heap of highway driving.
#17 Ice
  • 15,193 posts
Posted 02 February 2020 - 10:44 AM
Mine was sitting at 3000 rpm at 100 kmph i had same size tyres as you
3300 rpm is reving pretty high
#18 Gatti
Gatti
  • 344 posts
  • Car:LJ 2 Door
Posted 02 February 2020 - 12:05 PM
Was that with 3.55’s?
#19 Ice
  • 15,193 posts
Posted 02 February 2020 - 02:56 PM
Yes 3.55.LSD
#20 caterham2
caterham2
  • 348 posts
  • Location:Mansfield North East Victoria not the other one in QLD
  • Car:Ford Focus RS AWD Gone over to the dark side .. Mercedes-Benz SLK350 Ford Cortina 2 door MK1 Twin Cam
Posted 02 February 2020 - 03:51 PM
Just a tip on fitting the centre back I..............  throw the gasket in the bin, use a good quality sealant if you want to avoid the leaks. ( tip given to me by one of H Firths lads)
#21 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 02 February 2020 - 07:20 PM
Use the gasket & a smidgen of 3 bond each side. The gasket is there for a reason.
#22 claysummers
claysummers
  • 3,600 posts
  • Name:Clay
Posted 02 February 2020 - 07:30 PM
Obviously you’ll have to change to shortbottom bolt and stud. Be sure and use brass washers on these or it is guaranteed to leak.
The axles will hope your rear tyres aren’t too sticky.
#23 Gatti
Gatti
  • 344 posts
  • Car:LJ 2 Door
Posted 02 February 2020 - 07:41 PM
Thanks fellas.
Can anyone tell me the length and thread size of the two short bolts on a banjo diff when changing from a long bolt 3.08 casing to a short bolt 3.55 casing?
I want to source them before I do the swap.
Edited by Gatti, 02 February 2020 - 07:41 PM.
#24 Ice
  • 15,193 posts
Posted 02 February 2020 - 08:07 PM
Thats the go anna
#25 Gatti
Gatti
  • 344 posts
  • Car:LJ 2 Door
Posted 01 March 2020 - 06:46 PM
So I’ve fitted the 3.55’s and the centre is good with no whine or excess backlash etc
It’s made the car feel better and works well with my big cam.
I can deal with the higher highway rpm as it’s not that bad. I just might need earplugs due to my exhaust
