The improvements to this "budget build" track car were on going with lap times falling each outing. The next step was to fatten up the mixture but it never got there as I sold the car. I still have the engine set-up but it will be going in a road car with a road going exhaust so we may never know?
GMH LX8
#326
Posted 05 January 2023 - 11:03 PM
#327
Posted 06 January 2023 - 07:43 AM
Shitstr, the “headers by Ed” site has some more interesting exhaust theories, he seems to go against the grain a bit, and has claims to back his ideas too.
Look in the header design section, there might be something in there for you while you’re designing something different
- If you haven’t seen it already, that is
#328
Posted 10 January 2023 - 12:33 PM
Just make sure that you don't have any big flat areas on your exhaust (I'm looking at that middle section, triangular in shape on the drawing)
Everything has to be curved, or at the very least, bead-rolled, or you'll have structural issues.
That is why my big expansion chamber (V1.0) vibrated apart and why the car has V2.0.
#329
Posted 10 January 2023 - 12:57 PM
I've already thought of that and put a slight fold line down the centre of the flat sections to give it some strength and to stop vibration.
Only raiit 10mm max in the centre but more than enough to give it some ridged strength and stop vibration.
Edited by Shtstr, 10 January 2023 - 01:02 PM.
#330
Posted 10 January 2023 - 01:04 PM
Sweet. It's hard to know how carried away to get, but mufflers seem to survive forever with a constant radius in the metal, and my flat one lasted less than 100km, so somewhere in the middle is probably fine.
#331
Posted 10 January 2023 - 05:58 PM
Fold like is down the centre line so it's rigid and stops it fluttering up and down causing stress on the welds.
#332
Posted 14 February 2023 - 11:57 AM
I decided toget a flat sheet of stainless steel rolled to make it in one peice to eliminate twist from end to end.
After having no luck finding anyone who could roll it even after they said they could.
I decided to give it a crack on my home made pan brake for the hell of it.
I think it turned out fairly good for a home made pan brake job and not a proper one. I overlapped the seam to get a better weld join. As it will have more strength than a but weld on 1.5mm stainless. If it was 3mm or larger I would have done a butt join full pen weld.
Now to build the exhaust system.
#333
Posted 14 February 2023 - 12:02 PM
I wedged a bit of alluminium in between the rear 45 bends to hold them in place so ignore that haha.
Posted 17 February 2023 - 10:09 AM
Unfortunately, it is hard to find anyone to make custom parts these days. It looks like you have done as good a job of it anyway.
#335
Posted 17 February 2023 - 01:48 PM
Started tacking the exhaust in place.
Have a bar across under the mufflers to hold it up at the rear atm until I decide to go over or under the diff.
I know under will be easier and less hassle. But nothing in this car has been easy to work out and build so far🤣🤣🤣.
So that's it now till I get some more time in there.
Posted 18 February 2023 - 09:35 AM
I gained a noticeable amount of power when I ditched the 2.5" tail pipes.
#337
Posted 18 February 2023 - 05:50 PM
#338
Posted 19 February 2023 - 10:14 PM
90 degree from muffler pointing up.
180 degree bend over the top of the diff parrerel to the top diff arm. 170mm inbetween legs
90 degree facing outwtowards towards the wheel.
60 degree bend turning to run pipe parrerel to the side of my drop tank.
Straight pipe back to a 30 degree bend turning towards the rear of the car to exit the rear of the car with a Straight pipe.
Plenty of room and clearance all round. As my tank is different from others as I have a lot of modifications under the car with the awd system and wheel tubs mini tubbed.
#339
Posted 20 February 2023 - 08:44 AM
Anyone considered using donuts for the tight clearance places instead of mandrel bends?
You can get a lot tighter radius using donuts than a mandrel bend will ever give you.
Rob
#340
Posted 20 February 2023 - 11:48 AM
Yes that's true. But you need a minimum of 160mm inbetween the legs down each side of the diff to have clearance. Have found a 180 degree bend that has 172mm between legs so it is perfect for the task at hand. It also happens to contour the diff tunnel almost perftoo. So can set and forget it.Anyone considered using donuts for the tight clearance places instead of mandrel bends?
Rob
The stainless will expand at a rate of 2.54 inches per 100 feet. So at the length of the exhaust it will expand about 6mm over 10 feet.
It all has to be taken into account for clearance of diff and tunnels.
#341
Posted 07 March 2023 - 10:31 PM
So I can move onto the next issue of running the wiring harness in the engine bay to the cabin on both sides of the bay.
#342
Posted 14 March 2023 - 11:54 AM
Got one side up over the diff.
Posted 15 March 2023 - 09:38 AM
Well done. I'm running a 2.5" system over a 9" diff and I know the exhaust guy had a lot of fun getting it over. Cheers Ron
#344
Posted 16 March 2023 - 10:58 AM
Posted 22 March 2023 - 10:31 AM
Just tacked together atm. Still have to run it to the rear behind the diff but the hard part is done.
20mm between exhaust pipes and body. Roughly 3 inches of suspension travel at ride height. So will set the bump stops to a height where nothing hits.
Posted 22 March 2023 - 06:14 PM
#347
Posted 25 March 2023 - 01:02 PM
Great work,
I wish I had used the V clamps.
It make so much sense.
Hindsight is grand.
There are so many things I've see the guy's on this forum do, that makes me stop and think "why didn't I think of that"
Regards Mando.
#348
Posted 29 March 2023 - 08:41 AM
That is a pretty difficult bit of exhaust work. Nicely done!
I'm gonna stick with my reduced droop rear suspension and pipes under the diff hahaha.
#349
Posted 12 April 2023 - 04:39 PM
Twin 3 inch stainless steel with mandrel bends over the diff.
Decide to run it up high at the rear. Will be fine that close to the rail as there will be a mounting bracket to hold it from hitting the rail. There is about 12mm between the pipe and the rail.
Over the diff I have 20mm plus between pipe and floor and 65mm between diff and pipe. So should be fine once I make my bump stops to suit.
Edited by Shtstr, 12 April 2023 - 04:41 PM.
#350
Posted 12 April 2023 - 08:31 PM
Great work,
I love the way the pipes follow the shape of the tank.
Regards Mando.
4 user(s) are reading this topic
Facebook (2)
